help - bonnet wont open!
after taking my car to a 'braking specialist' yesterday, i have discovered that the damn bonnet wont open and the bonnet release under the steering column has lost tension and cable seems loose.
I have taken out the front grille to reach under the front sill but for the life of me cannot open the bonnet. I tried pulling the cable from under the column to no avail. I think a bracket has broken and therefore has no tension to open the latch.
Apart from using a very large crow bar can anyone help?
HI VIC I AM IN AUSTRALIA ALSO IS IT AN ESCORT COSWORTH YOU ARE ON ABOUT AS I HAVE ONE AS WELL I WILL LOOK AT IT AND SEE IF I CAN HELP I WILL GET BACK TO YOU
The wire has probably broken, go to your Ford dealer and order a new wire and plastic lever.
To open your bonnet now, get some pliers and pull the wire underneath your steering column.
ossie cossie
Hi mate, I have a Sierra Cossie and live in Sydney. Whereabouts are you?
Steve Escos
Thanks for the advice, tried that, and yeah, it has worked before on a previous car of mine. No luck this time.
JHS
Yeah tried that one, and unfortunately didnt work
Good news though. I went to my friendly local mechanic who services dad's car and BINGO!
He got access under the slam panel and with a screwdriver popped the bonnet. Found out the bracket for the cable had popped out and caused a slack cable.
Thanks guys for your help anyways
Steve Escos
JHS
07-10-2015 12:56 PM
