urgent suspension question
will the struts from a series2 turbo fit my rs16i need to know asap
ive put some on my xr3 last week they seem ok ,
you just have to use the top suspension cups ,the top rubbers and the plastic ring. hope this helps
the only thing thats wrong with my car now is that the front wheels seem to toe in but it was like that when i got it so im going to put on a s1 anti roll bar and adj track control arms to sort that out
And the pics was before i put the new suspension on !!!!!!!!!
https://passionford.com/forum/viewtopic.php?t=165154
Originally Posted by GraphiteGray
Yep thats right youve just gotta change the top mounts
rambo11 sounds like you need to get your tracking checked
had tracking done its not the tracking the front wheels seem to stick out at the top (camber or something),but not as much now ive lowered it im gona put my s1 anti roll bar on and some adj TCA mabe this may work ?
also since ive lowered it the back wheels seem to stick out at the bottom ? looks like im gona have to get adjustable everything
Wouldnt worry about it too much, the suspension on the XR3 was designed like that by fords, only to be redesigned later after problems with the handling arose
Just put the S1/RS1600i ARB setup on there with some adjustable bottom arms
SMILER258
28-09-2015 09:04 AM
