replacing downpipe on mk 6 escort
Exhaust dropped off on the way to work and i just wondered if it was just a case of unbolting and bolting on a new piece or is there some welding involved? ideally i may just have to stump up for a new system completely.
looking at the picture would this be doable or is it whole new exhaust time?
Just buy new bolts because they will snap...
And a new down pipe gasket...
brill thats what i was thinking. probably will take it to the exhaust specialist down the road but at least its something we can do if we wanted to. cheers guys really appreciate it!
im gonna try soaking it in wd40 over night and try taking it off tomorrow. if that doesnt work i am prepared for a new exhaust which isnt the end of the world just worth finding out if its something we could attempt. again cheers for all the advice guys. will post pics once its sorted!
well i nipped to an exhaust place and they quoted me Ł350 for a full new system. so i think ill just get the parts from euro car parts and do it myself as long as i can get the bolts off the flange.
Baby Cheesus
WD40 wont do anything, its a water displacer (hence the WD)
you need plusgas or similar penetrating fluid.
either euro or www.buypartsby.com will be the cheapest
Right Update. So so close i can smell the roses but now im stuck with a bolt.
tried cutting it out and drilling it out and im a bit stuck. my next plan was to go up in drill size and just create a new hole but if there are any other options that would be good.
tried removing with a screw remover tool but it just threded it.
pics enclosed but if anyone has any good ideas before the end of the day i would be most grateful as im going to stay late at work to get it finished.
I had the same problem on mine, the bolt had rusted to the end plate. I took the whole section off and re-drilled the hole. Couldnt do it any other way myself. All done now and works a treat. Just make sure you get a new gasket and plenty of exhaust gum/paste. Its hardly the cleanest/smoothest of surfaces to get a nice tight joint!
