Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
Escort van help
Old 29-12-2013, 02:19 PM
Munchkin6288
Munchkin6288's Avatar
Default Escort van help
I have an 02 escort mk6 van I took the facia panel off the dash to flock it and was wondering how do you remove the airbag cover without taking the dash out
Old 30-12-2013, 09:46 AM
minder
minder's Avatar
take the glove box out mate and the air bag is held in with 4 screws undo and it will fall out then just disconnect the wires
Old 30-12-2013, 10:02 AM
Moderator
STeve's Avatar
the glove box and dash is one piece so if you have a passenger airbag you need to undo entire dash pulling it forward enough to access the 4 mentioned nuts holding airbag to dash then theres 2 screws underneath which can be seen when glovebox lid is open and also a 3rd screw above and behind the heater controls which the switch facia needs to be removed to gain access to, but if its just a blank panel (non airbag) then undo the 2 lower screws and the facia will seperate from dash with some elbow grease and brute careful force
tonicosworth
Ford Escort RS Cosworth
31-10-2015 08:40 AM
markk
09-09-2015 08:11 AM
imnoteasy
07-09-2015 09:26 PM
Ade
Alloy wheels and ICE for sale
07-09-2015 05:06 PM
Bighandsuk
02-09-2015 05:23 PM
Quick Reply: Escort van help
