water in footwell
water in footwell
ive found a serious wet patch (almost a puddle) in the passenger footwell of my mk6 rs2000 4x4, ive taken out the battery to see if the tray has rusted through but it hasnt. the door rubber seems to be fine, i know the mk6 can suffer from leaky screens but that doesnt seem to be the case here. does anyone have any ideas as to where else it is likely to be coming from? any help would be great as i need to solve this.
More than likely coming down the a pillar from the sunroof drains. Sunroof has drains that run down the Apillar straight out into the sills. I'd lift your carpet and see what your floors like.
Theres a few blokes who have done something to solve this.
thanxs for the advice nath i will check it out. if the channels are blocked is it possible to get to them or use something like a wire coat hanger to unblock them?
I had the same prob,turned out that there was some rot below the blower 4 the heater matrix took me ages 2 find this out,its located just left of the battery and is held on with 2 13mm nuts gd luck
cheers mk5rs2k i will check it out. it seems to be drying out at the mo but its some thing i need to sort before it gets to serious, also im thinking of selling it and wouldnt want to pass it on with the problem
finaly found where the water is entering, it seems to be from the bottom of the door, coming in over the rubber. im going to change the rubber but can you think of another reason why it would enter there. ive checked the drain holes in the bottom of the door asnd they seem fine.
the water was gettin in to the door through the door mirror then coming out of the bottom of the door panel over the rubber. easily cured i put another piece of foam on the mirror and its fine
Mark RS
12-10-2015 06:01 AM
