fan still wont work on SNP11Y :wall:
My RS16i's fan stopped working on Sunday causing my car to over heat. So I looked in the Haines manual when I got home to see what could have caused my fan to stop working and it pointed to the fan temp sender switch. I have done what it said in the manual it said how to check the fan sender switch. it said to join the 2 connectors together if the fan worked then the sender is faulty and when I connected them the fan started so I bought a new one fitted it tonight had the car running and the temperature went up to just under the red and guess what the fan didn’t come on . Can some 1 shed any light on the problem 4 me pleeeeeaaaaase
i got peeeed off trying to get mine to work mate so i just gave up and had it wired to a manual switch, even when it did work it always let the temp go too high before it cut in
Stu @ M Developments
41
21-08-2015 06:47 AM
Zoggon
10-08-2015 10:39 AM
