RS1600I ANTI ROLL BAR question
ive been thinking about the rs1600i anti roll bar tie rods.
are they really strong enough where they are bolted to the cast subframe?
its only 2 m8 bolts that hold them on and im just worried about putting 200bhp through them and more worried the big brakes i have fitted and worried they will snap!!??!!
i bought some new allen key bolts to hold the tie rods but im still worried what would happen if they ever snapped under exceleration!
also i am in need of a roll bar clamp to go over the rubber bush if anyone has one pm me
its under breaking that im worried about, ive got 300mm brakes and 215 tyres so there is going to be alot more force on them than what they had as standard
Originally Posted by NUTS RuS
No mate.. I don't run any on the front or rear.
That clip on RS1600i.net that Clare took at Llandow shows the car all over the place because it was running on Dunlop slicks which are crap on my car
you have got to have one on the front at least yes??!!??
No - not any front or rear.
all sports cars have then front and rear?!
so you just use they tie rods?
Tension/Compression Struts work just as well or better in some circumstances.....most race cars just use arbs to fine tune the roll with the compression struts doing most of the hard work
at the moment all i do is stare at it wishing i could get it finished
ive been building it for over two years now!
its one bloody thing after another with it.
just having trouble getting the megasquirt to work the engine at the moment
I'm sure they'd be fine mate. as far as I understand the RS1600i has the same set up as then S1 and mines doing that kind of power and they've been fine. also This is an extra in comparison to the likes of the S2 which doesn't even have tie bars, just the roll bar.
2050cc
1.8 ported and polished head
kent cams
kent pulleys
trust 4 branch
st170 inlet and injectors
honda 929 fireblade throttle bodies
megasquirt
magnex system
focus metal head gasket
kent cams
kent pulleys
trust 4 branch
megasquirt
magnex system
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
