View Full Version : Ford Puma
- I need help installing my radio
- abs/tc problems please help
- Puma problem...
- Mk5 fez exhaust on a 1.7 puma?
- Fuse manual?
- Central locking not working.. non stop clicking trying to lock..
- Gearbox serial no
- st170 brakes on puma??
- please help, made a rookie error with cambelt change
- suspension advice
- not the normal torque limiter question...
- Heated Front Screen Fuse
- this common abs sensor fault....
- Carbon Fibre roof for a Puma
- help, valve spring collet required
- 1.7 2001 engien in to my 1.6 ztec s advice please
- 1.7 puma intermittent overheating and coolant dump
- Racing Puma A17 FRP
- Coilovers
- puma difficult to select gears
- tuning a 1.7 puma engine
- Puma 1.6 ECU question
- 1.7 vct throttle problem?
- Will it fit
- airbag removal
- No EEC fuse
- Fuel Gauge
- FRP brake set up, what are they worth?
- Advice on chassi/suspension mods
- Rear axle shims?
- ABS and TC light on my Puma ='((
- Puma central locking for Toad alarm....
- wet drivers side footwell :(
- Aircon leaking in footwells
- Ford Puma 1.4 Buying advice
- FRP Lamda sensor
- Bike Carbs
- Puma wont start : (
- What will fit
- inlet cam actuator
- my Puma Track Car
- Gearbox gasket?
- bucket seats
- pls help rear lights :(
- FRP Front Brake Disc Advice - HELP
- abs and tc light stay on
- cosworth puma
- wather temp.
- Just a few pics of the puma :)
- Ford Puma Brakes
- Help please, Keys lost for Puma
- Ford Puma has Died - Electrical Problem?
- a few puma questions
- puma ecu pin out
- Engine problem
- Coilover Springs
- 1.7 turbo
- Door ajar light on
- puma brake upgrades
- puma advice
- puma front in fiesta??
- racing puma seats for sale
- puma starting issues
- radiator fan
- question about the injectors
- Crap Puma headlights?!?!?!?!
- winter wheels
- engine swap
- head light seal
- Threads asking for Car Stereo codes are not allowed.
- Update on track puma
- Fiesta parts compatable with Puma??
- how to adjust handbrake
- Rumbling sound on front wheel area
- automatic choke/cold start
- airbag light on what could cause it ?
- are puma top mounts the same as fiesta mk5 ones ?
- what engine is in a racing puma???????
- How you call this?
- door card
- puma missfire
- anyone know if there is a difference between the puma 1.4 1.7 back box?
- puma heater controls not working?? got one today, but not gen ford??
- Someone who knows car wiring-Rev counter & Temperature gauge
- mileage on electronic speedos
- oh dear another focus rs dead
- Puma 1.7 missfire ???
- puma with idle issuse
- Puma abs fault
- Puma 1.7 cambelt/waterpump book time
- Puma...wont start electrical mayhem
- Help please for my Puma!
- Ford Puma
- Puma double locking not working
- Puma ECU's, how adaptable are they?
- Puma brakes.. no pedal - done! brutal lol
- help my puma
- What's the going rate for a 1.7 Puma lump these days?
- 2.0 zetec engine into puma
- Racing Puma cam followers
- puma 1.4
- puma 1.4 to 1.7 swap Q's
- Puma wheels on escort van
- ford puma body panels
- 2.0 duratec conversion for a puma
- Puma head unit pinouts
- Puma Linkage
- Puma engine help?
- Doing a clutch on a puma... straight forward?
- Puma Fog lights??
- Ford racing puma box fit my 1.6 focus???
- puma 1.7 vvt cam belt missalignement
- Puma 1.7 Mods..
- A few pics of my racing puma
- Pinout diagram for puma & ka ecu
- 1.7 Puma Idle
- Puma 1.7 top end rattle (loud!)
- 1.7 Puma Engine?
- ford puma kitcar pectel t3 ecu pinout
- ford racing puma
- Ford Puma
- 1997 Puma D bushes ?
- puma 1.7 head gasket??
- Info needed - on puma 4x4 wrc
- Puma engine.
- Puma millenium
- Racing Puma
- Puma engine replacement
- fast ford's puma paintjob
- Fiesta Zetec s Puma conversion
- Ford Puma - Rear tailgate brake light not working
- puma
- 1.7 Puma Died, wont start????????????
- Cossy brakes on a Puma
- Puma/Fiesta experts
- Ford Puma VVT problems (I think)
- ford racing puma,what like are they?
- A Few Problems with my Ford Puma!
- blacktop into a puma
- 1.7 vct puma engine
- Puma S1600 Independant rear arms - Photos added
- Ford Puma In need of big end shells
- Mk5 fiesta racing puma engine
- Is it possible to adjust a puma throtte cable...
- Puma Timing Belt Help urgent!
- Racing puma
- Puma engine problem
- Puma'd Fez Courier Van?
- where is the fan switch on a puma
- strange over heating problem...puma 1.7
- Puma dash removal
- puma 1.7 water lever diplaying on the dash
- Puma 1.7 vvti, solinoid location?
- PUMA engine, gearbox in fiesta question...
- fault code - octain pin ford puma 2000 (twin lambda tyoe loom)
- ford Puma 1.7i
- WTD: 1.7 Puma ECU Pin Data
- Puma 1.7 what to look for
- Ford Puma 1.7 X reg blowing hot air, not HCV!!!
- Ford puma sills help !!!
- puma 1.7 zetec into my fiesta zetec s
- 1.7 puma engine into a ka
- facing puma hub kit?
- puma rev counter
- Puma ABS n traction control lights
- Guy that does Fiesta Puma conversions on here???
- racing puma brakes, will they fit under 15" wheels
- Ford Puma, indicators
- Puma 1.7 into fiesta
- puma engine torque limiter
- oil capacity puma 1.7 engine
- Ford Puma ABS fault
- anyone can help me with a 1.7 puma
- puma 1.7 brakes behind 13inch steelies
- Temp sender on '97 Puma
- Ford Puma - Lowest mileage example?
- Info Needed Focus 1.4 engine into Puma
- Fiesta 1.3 puma conversion? Please help :)
- PUMA ABS/TC Lights
- Ford Puma's, any good? what to look for?
- FORD PUMA trasnsplant
- puma gear linkages are they the same eg 1.4-1.7
- Puma 1.7 into a 52 plate focus 1.6 se
- puma 1.7 rear stub axles, same as ka, fiesta?
- puma head on zetec s
- Puma on focus RS wheels?
- Puma Electric Windows
- puma changed ecu key and key transponder wont start
- were is the ecu on a ford puma
- Puma Dashboard Removal - Help!
- Puma heater
- Puma 1.4 idle valve fit a 1.7?
- Puma/Focus Zetec Se Engines
- Help! my puma aint runnin right!
- Changing water pump on a 1.7i Puma
- Puma clutch problem please help
- Puma alarm
- More Puma problems
- Puma boiling over
- Puma MOT pass
- iv got a racing puma engine HELP
- Puma 1.4 rev surging
- Buying the girl friend a puma for her bday... What do i look for?
- timing marks for 1.7 puma zetec
- cvh into mk5 fiesta or puma
- CVH Turbo Into Puma
- advice on puma engine 1.4 to replace
- Puma engine swap choices
- are puma/mk4> fiesta gearbox cable change?
- advice on a puma 1.4 going to buy key lost
- 1.7 Puma VVT
- Puma Racing Engines
- Fiesta ST caliper carriers on an early Puma
- Help me settle a debate - brakes for a Puma track car
- mk4 fiesta/Puma shocks
- Puma rear shocks, possible fitting issue?
- The new Puma
- opinions on 1.7 puma, track day car?
- rs turbo brakes do they fit puma
- puma inlett manifold
- Ford Puma power steering pipe help!
- ford puma head bolt help
- Puma 260 brakes on XR2i 16v
- Puma earth points.
- 1.7 Puma engine mounts
- Puma Racing original wheels, specs??
- help puma 1.7 vvt eml issue
- puma 1.7 vvt eml after belt replacement
- puma track car?
- ford puma lowerd 60mm
- Ford Puma 1.7 Lambda Sensor - Which one?
- Newbie - Just bought Puma 1.7 - Problems at 4000 revs!
- anyone done a starter on a 1.7 puma
- puma 1.7vct missfires and kangaroos
- Std. puma to racing?
- Ford Racing Puma
- 1.7 puma engined fiesta help
- Puma key fob battery?
- pectel t2 & t3 differances
- Puma timing belt gone, told i need a new engine
