View Full Version : Ford Fiesta
  1. mk6 engine conversion
  2. Fiesta zetec s 1.6 exhaust
  3. Fiesta MK6 cooling fan problem
  4. Central locking drivers door
  5. Fiesta Zetec S Engine Mods?
  6. Fiesta zetec s puma conversion
  7. 2006 Ford Fiesta 1.6 Ghia
  8. Ford fiesta mk4 1.4 zetec s conversion ????
  9. Help needed with 2002 1.25 SE engine
  10. Help - Engine Management Light on
  11. Fiesta zetec S, what would you do if you bought one?
  12. Single wiper conversion
  13. Mk5 Fiesta - Engine Management Light - Loss of Power + other issues
  14. Parts for frst needed pls
  15. Fiesta mk5 zetec turbo conversion
  16. Mk4 coilovers wanted!!!
  17. Ford fiesta 1.4tdci 2006 No RPM on crank
  18. S reg 1.25 zetec
  19. mk4 1.25
  20. ford fiesta si 2.0 althernator bracket.
  21. Fiesta mk3 xr2i engine mount conversion
  22. my xr2i to 2.5 v6 conversion help has any one on here done it
  23. how to fit an omex rev limiter on a puma's zs
  24. MK3 Fiesta XR2i Upgrades
  25. Mk6 1.6l Crankcase Breather help
  26. Fiesta zetec s suspension help
  27. puma speed mk5 fiesta.
  28. Fiesta rs turbo blue injectors??
  29. Newby with an x reg zetec s :)
  30. Fiesta mk5 dashboard changes
  31. freeing up stubborn spark plugs
  32. fiesta tddi mk5 anybody tuned one
  33. Colour Coding Bumper Trims?
  34. Petrol FUEL SAFE replacement MK6
  35. Mk4 fiesta brakes
  36. HELP! Problem with Ford Fiesta 1.2cc Zetec engine
  37. MK5 revs goes up but speed is not changing
  38. MK6 ECU Wiring diagram
  39. Water inside the car
  40. Can you fit electric windows onto a MK6 finesse?
  41. Will a 1.3 KAs hubs/steering knuckles fit on a 1.2 mk5 fiesta?
  42. Requires a locksmith - Car diggi won't unlock automatically
  43. Zetec S Interior Light
  44. mk6 fiesta 1.4 - is this a gearbox or clutch issue?
  45. Failed MOT due to emmisions
  46. mk1 fiesta engine conversion to 1300 escort
  47. XR2 boot hinge
  48. XR2i Restore
  49. Water inside the car-side conductor
  50. Battery high voltage error code b1317
  51. Mk4 uprated shocks?
  52. Ford Fiesta Idle speed control valve?
  53. mk5 fiesta error codes
  54. mk4 fiesta cutting out
  55. buying a fiesta mk4 ?
  56. Fiesta mk5 heating
  57. 2003 Fiesta TDCI Turbo Pipe Blown
  58. Fiesta mk4 coilover help!
  59. Will a 1.25/1.4 bumper fit a Mk5 Zs ?
  60. Ford Fiesta MK 5 interior change
  61. Fiesta D starting wont start
  62. Bonnet Catch
  63. Fiesta 2000 - Radio Installation
  64. lowering spring problem ..
  65. 771 Engine
  66. mk1 fiesta engine change
  67. fiesta mk5 door handle problem, its broke..
  68. mk 6 zetec s et for 18" best fitment?
  69. 1400/1600 zetec
  70. puma'd zetec s fiestas..any good?
  71. CD Player Error Msg
  72. Fiesta xr2 question
  73. front suspension desperate!!!!
  74. Please help me find out the cause of this...
  75. fiesta gearbox
  76. rs1800 running bike carbs into a mk2 van
  77. 1.4tdci not starting when it's really cold
  78. Rear Bush Opinions
  79. Fiesta Mk6 1.6 Zetec S gearbox oil seal
  80. Sparks coming from the exhaust
  81. 2.0 zetec in mk2 xr2
  82. 06 Fiesta OEM radio swap
  83. Pcv hose - fiesta 1.4 2003 reg HELP!
  84. Mk6 semi auto gearbox any good?
  85. Lots of issues!
  86. Ford fiesta 1.4 zetec 2003 - crankcase breather pipe
  87. Mk2 FIESTA...ADVICE ON NEW EXHAUST...plz help
  88. Window Fiesta MK1 in à MK2
  89. 2003 ford fiesta
  90. Ford Fiesta mk6 engine swap need help
  91. fuel consumption?
  92. Fiesta discharging battery?
  93. Just got this E reg Ghia
  94. Mk5 driveshaft
  95. Brembos, MK5, Possible?
  96. mk 1 steering wheel boss?
  97. Ford Fiesta - Screech/Squealing sound from engine at higher revs.
  98. What engine should i get for my fiesta mk6?
  99. Help - advice about parking sensors
  100. ST150 B12 Suspension Fit 5 Door 1.4 MK6
  101. 09 Zetec s Throttle problem
  102. help please
  103. Fiesta vented brakes?
  104. mk4 front wheelbearing
  105. timing chain/belt
  106. Snapped under bonnet release arm.
  107. fiesta mk6 aftermarket electric windows
  108. fiesta mk6 central locking problem
  109. My crazy sleeper project!
  110. Fiesta MK 3.5 Exhaust Front Pipe Replacement. Advice needed
  111. zetec s exhaust
  112. Water coming from wrong pump
  113. 2 litre blacktop into a mk3 base model
  114. Engine swap
  115. zetec s
  116. Fiesta Mk6 facelift Bulb Upgrade
  117. mk1 fiesta hub nut size???
  118. Xrv gearbox
  119. HELP Mk2 fiesta wide arches?
  120. Which engine??
  121. thoughts on this fiesta cost to repair
  122. HELP PLEASE! Fiesta washer motor problem!
  123. Fiesta 1.3 to 1.7 puma engine
  124. need advice on this part
  125. hi can anyone help plz
  126. Zetec Zetec Timing pin location and crankshaft pulley bolt
  127. will 1.6 CVH fit in 1.1 ? (mk3)
  128. Fiesta xr2i timing belt issue
  129. mk2 fiesta XR2 body kit? any one got one and advice on fitting
  130. Puma inlet on ZS
  131. wiring colours to upgrade to remote central Locking
  132. mk6 fiesta
  133. Instrament Cluster Swap
  134. mk5 turbo
  135. Does a mk2 xr2 engine fit straight in a mk1 fiesta???
  136. Ford RS steeringwheel boss for mk1
  137. help!!!! mk2 xr2 twin 40's loss of power
  138. Mk2 xr2 arches fit mk1???
  139. Wobbley Gearstick
  140. Help!! Problems with some electrics on Fiesta Mk5 1.6
  141. Fiesta 1.25 Zetec woes
  142. 1.25l Zetec 16v Fiesta '95 conrod bearings
  143. To fix up or not to fix up, that is the question
  144. Turbo help
  145. Which AFM for Zetec 1.8?
  146. Running probs
  147. PLUGS
  148. RS Turbo Stainless Boost pipe
  149. Swapping a Mk6 steering wheel
  150. 2.0 blacktop into mk5 (zs)
  151. Fiesta zetec s or metal
  152. Thinking Of Buying A XR2, Need Some Advice
  153. Anyone know anything about H654 XTO?
  154. Mk5 Lights on warning buzzer in a Mk4?
  155. internal fuel cell help!!
  156. Fiesta zetec s turbo engine mount
  157. xr2i engine conversion
  158. types of diesel fiesta engines
  159. S1 RST wheels on a mk2 fiesta
  160. Mk6 Fiesta 2.0 duratec turbo help
  161. Where Can i go To Sort Out Rust On My MK5 Fiesta Zetec s
  162. New Fiesta Zetec-S Ideas
  163. Threads asking for Car Stereo codes are not allowed.
  164. Mk4 fiesta Mod?
  165. Mk3 Fiesta UJ
  166. 03 Fiesta Ghia remote boot lock problem
  167. 2.0 blacktop into a mk 3.5 fsi??
  168. help with my fiesta battery light
  169. Engine change fiesta mk6
  170. engine mods xr2i 1800
  171. Engine cutting out Zetec
