- Water in MKIV boot lid?
- ford fiesta mk6 1.4 tdci with 1.6 tdci turbo and front mount intercooler
- Jerking and juddering at specific RPM
- ENGINE DAMAGE - REPAIR IMMEDIATELY - FORD FIESTA 1.4 TDCI Year 2010
- Mk 4 Cooling Fan Not Working
- Does anyone know if this FRST still lives????
- ford fiesta endura diesel surging problem
- how much bhp have people used on standard zetec conrods?
- Mk5 Fiesta Passengers side repeater always on
- Damaged Door
- Mk5 rear wheel bearing
- Fiesta ST injector rail
- Ignition and sidelights problem
- Help please fiesta
- Zetec s tdci exhaust/intake?
- New car -Help please
- Temperature gauge problem
- fiesta mk6 limp mode
- Ford Key Fob Sticking On Lock Door
- Xr2
- Converting MK3 Fiesta To ltr Zetec
- mk4 fiesta rear bushes
- P132B Fault
- RS Turbo/XR2i Side Skirt Clips
- 1.4tdci problem
- Mk3 fiesta water in fuel
- MK6 fiesta Rs turbo conversion help?!?
- Fiesta 1.4tdci Turbo
- correct wheels and tyres fiesta mk 4 Black
- 2007 Zetec-S TDCi Start Up Problem & Engine Cooling Fan
- Rattle under load - Zetec SE
- Ford Fiesta trend 1.6l
- Ford Fiesta Zetec Car seat
- 2010 Fiesta boot keeps popping open
- EMU unit - 'little black box'
- mk5 zetec 1.25, engine rattle help
- Ford Fiesta Mk5 (02) Rev counter
- 2006 fiesta 1.4D egr location
- Fiesta Air bag light.
- mk4 water pump
- MK5 Festa won't start. Fuel system?
- 1.6 TDCi fuel filter change, anyone done it?
- Boos kit for mk2 Ford Fiesta
- ford fiesta 1.4 zetec 2003
- engine mount needed
- Mk6 Fiesta seat tilt broken
- fiesta 1.4tdci 04 plate eac fail solution
- 01 fiesta fog lamp not working
- Will not start Ford Fiesta 1600 zetec
- Help with replacing original mk2 stereo
- ford fiesta project
- Hydraulic lifters and shims - help with shims!
- MK4 Fiesta problem, need help!
- fiesta mk3 1.8td
- fault in column switch / no side light.or dash light
- MK5 Fiesta rev counter only dead
- Ford Fiesta .18 turbo diesel 2002..help wanted please.
- Mk6 Fiesta 1.4 TD advice?
- mk5 zetec cam belt covers
- Oil leak
- Ford Fiesta 1.6 tdci econetic
- 2002-03 fiesta 1.4 water filled spark plug wells!!
- 1990 XR2i breathing problems
- Engine cutting off
- Problems with mk5 Zetec s... Help!
- mk5 fezza giving trouble
- Fiesta MK6 Bonnet Problem
- No idle when cold - fly by wire throttle.
- Rear washer
- How Do I Get To The Blower Motor Fan. Mk6
- 2.0 zetec mk5 fiesta
- Fiesta 1.4 2003 blue smoke?
- zetec s running on!
- Wheel offset
- MK5 1.25 how to change lifters/tappets
- After a cts stage 2 plus gearbox
- Fiesta 2005 TDI (I'm a newbie in need of help)
- Heating/Cooling Directon Knob MK6 2006
- Mk 6 Fiesta Zetec S clutch clicking
- Problem with the TCM - Ford Fiesta 2004 Durashift
- Speedo problem
- Fiesta mk5 1.25 squeaking noise
- Brake discs
- mk2 fiesta steering column and handling issues
- Locks and immobiliser
- Failed MOT on seat belt and headlamp alignment.
- Mk 4 Fiesta Weird Cutting out! Please help!
- New here, need some help :/
- Mk3 Fiesta 2.0 Zetec Conversion
- mk4 fiesta
- rear sidelights
- mk2 xr2 drive shafts on a mk1 fietsa?
- Mk1 parts wanted!
- Mk5 Zetec s. New puma project. Remap + +
- Ford Fiesta Automatic Transmission Malfunction
- hi all,new guy's here
- fiesta semi auto clutch
- Zetec S help
- 1.3 to 1.25 conversion?
- Mk4 temp gauge help
- lost my only fiesta van key 2001
- 97 fiesta 1.25, puma 1.7engine conversion
- Ford Fiesta semi - auto 2003
- fiesta mk4 subframe alignment
- 07 fiesta 1.4 climate rear shoes, hub puller ?
- Xr2i 16v (1.8 zetec) tuning...
- Why is this leaking again?
- fiesta mk4/5 1.3 tuning
- Fiesta 2003 Issues
- ford fiesta mk6 eac failure
- MK3 idle problem
- Mk1 xr2 with zetec engine
- Fiesta mk3 2L zetec conversion
- mk 4 turbo conversion
- A few MK6 questions
- MK2 Fiesta | Which seats fit straight in?
- Gearbox replacement??
- fiesta 1.4 tdci zetec climate
- 6.5 zs starting issues
- Help with gearbox please!!!!!!!!!!!
- MK4 Heater System
- new brakes
- alternator
- Do puma door cards fit?
- What gearbox fits into a mk5 zetec s puma engine
- Flywheel Torque?
- Gearbox change, what gear?
- New car problem
- ain't bought it yet but already modifying it lol
- ESP warning light stuck on - 2006 Fiesta ST
- Mk7 Fiesta On Cosworth Alloys
- Mk5 help
- FK High Tec Sports Suspension Kit
- 2004 mk6 5dr fiesta door panel fabric removal
- Mk 3 fiesta rear disk conversion can it be done
- mk6 fiesta heater blower replacement
- 52mm pillar gauges (speedometer) anyone??
- Air Conditioning and heaters not working
- MK6 1.4 TDCI mapping
- 2002 Fester 1.4zetec exhaust problem!
- Mk4 clock removal
- Mk5 1.4 Duratec timing Belt change Time
- tailgate and passenger door lock prob
- passenger inner arch rub
- 1.4 TDCI info please ?
- puma conversion
- Mk6 Sub/Amp ground problem
- Possible engine problem
- mk3 fiesta clear rear lights
- Ib5 gearbox info
- All the dash lights on! Please help
- fiesta si.com members
- sounds like running water
- My mk5 fiesta 1.25 upgrades
- Silver top zetec frst
- Fiesta Mk6 Engine Conversion
- 6x4" speakers in rear (mkiv Facelift)
- New XR2i owner saying hello and after a bit of advice!
- Rs1800 cult engine bay loom connector
- mk1 panel
- MK5 strip out advice
- Aftermarket ignition leads for Mk4(facelift) Fiesta with the 1.3 Endura E lump
- Ball ache !
- Mk4 fiesta - P0500 error - speed sensor
- Mk2 fiesta xr2- rear suspension issue
- what use think of my we fiesta?
- 1.4 TDCI Auxiliary belt routing diagram?
- mk6 - mk6.5 parts
- Ford fiesta 1.8 Diesel 1993 heavy vibrations
- zetec s ecu pinnout
- Rotton rs turbo. Mk3 re shell or mk5?
- Fiesta Mk V Clutch leak
- Throttle Body Gasket identification
- Replacing rear coils
- Mk5 zetec s omex rev limiter help
- your reviews on fiesta sts
- fiesta mk4 bigger front disk conversion
- first time modifying
- Mk3 1.1 HCS CFI Engine Conversion Options
- Help urgently needed.
- stripped zetec s track car issue
- fiesta mk4 laguna spliter
- Airbag Control Module - Location Please
- Fusebox Fiesta XR2i Mk3
- anybody selling or breaking a mk3 fiesta 3door or 5 door
- Fiest mk5 Bumper Trims (DRIVING ME MAD!!!)
- £1000 for a 2001 1.25 Fiesta Ghia good price?
- Where's my oil filter?
- 03 1.4 cam belt
- Fiesta mk5 with unlocking problems
- Fiesta mk3 roll cage dimensions
- mk3 2 door a posts
- Starter help
- 2004 Mk6 Fiesta Wing Replacement
- Anyone on xrtwo.com?
- Powertrain Warning Light Issue
- 2003 Fiesta 1.4 no idle
- Fiesta Puma Conversion
- FIESTA 2007 heater motor removal...
- Fiesta 1.4 tdci 2002 injectors leak-off test
- Headlight bulbs?
- Mk1 fiesta engine upgrades.
- central locking fiesta sapphire
- Mk 6 Fiesta front passenger side window
- mk5 fiesta zetec s eml light
- will this fit my mk3 fezzy?
- headlamp wiring diagram
- Fiesta Mk6 53 Plate P0400 DTC Error Code
- fiesta 1.6 tdci engine looses power??
- ford fiesta st clutch advice
- Ford fiesta Courier1.8td Injector Leak
- fiesta mk4 1.8d loss of power under load
- Wont Idle When Cold
- cold and fed up
- vacuum pipe
- No seat Wiring
- MK6 fiesta engine conversion
- Fiesta 1.8 td di is the fuel pump coded to the ecu ?
- fiesta mk5 drivers seat issue
- 2001 zetec s phase 2
- Zetec s tuning questions.....
- Ecoboost Engines
- Mk7/8 fiesta 5 stud conversion
- My Zetec S
- Fiesta mk6 spoiler removal qustion
- Ford Fiesta ZetecS help oil issue
- Ford Fiesta 2002
- focom diagnostics
- Tug
- Mk5 fiesta suspension
- Mk4 fiesta key fob not working
- fiesta st mk6 tuning help :) what gains?
- fan blower not working
- Mk2 fiesta
- Mk5 1.3 to 1.7 Conversion [Build Log + Questions]
- fiesta mk6 mirrors
- Mk3 rs1800....
- Bit confused about wheel offset.
- 1.25 zetec wiring for grasstrack racing
- Fiesta rs turbo newbie :)
- 2.0 zetec mondeo
- Hi every. One I'm new to the forum
- Fiesta Overheating Advice needed Please
- New to zetec s's
- timing issue on a fiesta 1.25 zetec
- Fiesta mk4/5 window panels
- IPhone to GPS navigation system problem
- fiesta mk5 2001 1.6 sport
- New Clutch???
- Will mk5 zetec s front bumper fit mk4
