PDA
View Full Version : Ford Focus Diesel
Pages : [1] 2
  1. Behind Grill Access
  2. P0299 code (underboost) 1.6 TDCi 2009
  3. Turbo issue Focus 2.0 tdci 2005 help needed
  4. 2004 TDCI with air in the fuel system
  5. TDCI Vacuum operated Turbo
  6. p0234 reconned and 3k code
  7. How long to change clutch and dmf on mk2 2.0 tdci
  8. how do i get my mileage reset >
  9. Mondeo 08 TDCI Help
  10. 2006 diesel focus
  11. Broken clutch pedal pushrod
  12. Focus mk2 2.0 tdci poor MPG
  13. Recommend code reader for 2002 TDCI
  14. D4162T Diesel engine issue
  15. TDCi Focus - limp mode now won't start
  16. Starting issue
  17. 2006 focus 1.6 TDCI
  18. TITANUIM ALARM gem ?
  19. Focus mk2 2.0 tdci alternator problems.
  20. White Smoke only on start-up
  21. Auxiliary belt tensioner pulley replacement.
  22. New fuel filter. Ran fine bust won't start next day.
  23. Removing 12v outlet
  24. Slight Loss of Power
  25. Timing belt change
  26. 2.0 tdci 2007 estate induction kit
  27. Boost gauge on a TDDi 2002
  28. loss of power
  29. loss of power
  30. Ticking noise
  31. Part ID needed
  32. Engine systems fault warning light
  33. Non start 1.8tdci 02 Ford Focus
  34. Powertrain Warning Light
  35. Intermittent no crank no start. Faulty relay?
  36. Sudden drop in MPG
  37. Limp mode
  38. focus 56 plate cutting out
  39. No start 1.6 TDCi
  40. Oil Pressure Light Flicker
  41. 2005 2,0 tdci regenerates Too often
  42. 2004 1.8TDCI Focus White Smoke on Startup
  43. Help needed - Engine, transmission malfunction, check engine and esp light on
  44. Focus Mk3 1.6 TDCi upgrade
  45. mk2 1.6 tdci lack of power
  46. Focus 1.8 TDCI 2006 turbo problems
  47. 2012 tdci power held back under heavy load
  48. 2002 1.8 Focus rear wiper and boot fob thing.
  49. 2004 tdci focus sport handbrake hell !!
  50. Pressure control valve
  51. Focus engine system fault
  52. 1.8 TDCI Alternator / Alternator Drive Shaft / Pulley
  53. Anyone good with the Tdci 1.8 110bhp?
  54. glowplug timer module
  55. Focus tddi problems
  56. Focus MK 1 tddi mass flywheel ?
  57. Mk1 TDCI Sport- Fitting ST170 Xenons & Cruise
  58. P0715 and P0701 1.6 AUTO diesel
  59. Are tuning boxing any good?
  60. Mk2 focus and tdci owners lowering spring opinions
  61. It's let me down
  62. EGR Valve !
  63. Lowering mk2 focus saloon
  64. Focus Diesel Purchase - Advice
  65. Focus 06 1.8 ltr tdci sport - power loss/limp mode, HELP!!
  66. water leak
  67. Water leak
  68. 1.8 TDCI Injectors Need Opinion
  69. tdci intercooler veins
  70. Focus 1.6 tdci turbo
  71. Variable knocking noise
  72. 2009 1.8 TDCi - BCM needs coding???
  73. Hatchback/estate seats interchangeable?
  74. Fuel consumption after service.
  75. wiring diagrams for 2009 1.6 tdci
  76. 2009 TDCI 1.6 odd problems due to duff temperature sensor
  77. TDCI possible belt noise
  78. Focus 1.6 econetic 2008
  79. 1.6 tdci battery
  80. burning smell
  81. focus flat spot
  82. 1.6 tdci slight hesitation
  83. MK1 Focus 1.8 TDI Heater Problems
  84. TUning box install?
  85. Focus 1.8tdci glow plug light
  86. 1.8 tdci mk2 2006 cough whilst driving up hills
  87. 2.0 tdci vss speed sensor question
  88. 2002 1.8 tdci Drive shaft
  89. ford focus 2007 1.8 tdci HELP ME PLS
  90. Help
  91. Mk1 Focus TDDI Sump gasket
  92. focus cmax 1.6 egr problem
  93. 2008 tdci 1.6 none starter
  94. Focus 1.8 TDCI - Intermitant Turbo Failure
  95. 1.8tdci fuel pump gear loose help
  96. air Con problems
  97. transmission u0101, p0700, p0098
  98. 2004 TDCI wont start after chargin battery
  99. St170 boot lid swap
  100. Clutch pedal vibration while pressed down (2003, 1.8 tdci)
  101. Different serial numbers on Fuel Pumps
  102. error code p0000
  103. 1.8 MK2 TDCi (2006) - occasional hesitation at junctions/roundabouts
  104. Ford focus diesel : 1.9 tddi
  105. Focus 2.0 TDCI Timing Belt & Chain?
  106. ford focus 2005 1.6 tdci low power
  107. Gearbox/differential probs?
  108. 2005 1.6 TDCI, limp mode woes
  109. Focus Estate Springs
  110. 2009 1.6 tdci engine malfunction light
  111. Flashing Glow Plug light
  112. Braking Assist too much?
  113. 2003 Focus Tdci Sport starting problem
  114. 1999 focus diesel heating problem
  115. 1.8 tdci starts fine but if I shut it off...
  116. Mk1 Focus 1.8 TDCI Cambelt
  117. 1.8 TDCi - Lots of BLUE smoke on start up. HELP!!
  118. 1.8TDDI loss of power after fuel filter change
  119. 2003 Focus 1.8 TDCi will not start. HELP!!!
  120. 03 Focus 1.8TDDI lacking power and rattling/rasping engine noise
  121. MK1 Ford Focus 1.8 TDCi lowered suspension and 17"alloys
  122. 2001 1.8 TDDI Has lost power
  123. Ford Focus 2008 1.6 Studio Eco Diesel Hose Blown Off
  124. 2009 Zetec S 2.0 136 (160) TDCi turbo trouble???
  125. ford focus 1.8 tdci new problem
  126. Focus 1.6 tdci injector seal leak?
  127. Focus 1999 Endura-DI Acceleration Problem
  128. focus 1.8 tdci zetec s
  129. 2007 1.6 tdci problem please help driving me mad
  130. Focus tddi
  131. Revving up on its own
  132. Smoke
  133. 1.8 tdci limp mode
  134. leds
  135. new to ford's!
  136. 2004 Focus Handbrake light
  137. 1.6tdci low on power
  138. description of changing turbo prosigure
  139. diesal tdci focus
  140. Focus zetec 2.0ltr tdci any good????
  141. TDDi Wagon Mods - FMIC, MBC, Decat
  142. Focus diesel tddi
  143. 4200 into a 52 plate TDCi and still won't start!!!
  144. Focus 1.6tdci's - are they as bad as people make out?
  145. Focus 1.6 TDCi EGR
  146. 1.8 tdci 2005 49k
  147. Cmax 2.0 tdci - limp mode - fuel pressure sensor?
  148. Help please! 2009 1.8tdci 35mpg and sluggish at set off.
  149. Focus Tdci starting problems
  150. 59 plate 1.8 TDCI Engine Pre-heater
  151. Lynx tdci fuel pump
  152. Focus TDDI Starting Issues
  153. 1.8 TDCi Poor fuel consumption
  154. Ford C-Max PCM issues and Egr 1.6 tdci dv6
  155. Egr blanking plates
  156. dmf to smf
  157. Gearbox type
  158. 1.8 tdci motorway problem
  159. hybrid turbo
  160. TDDi EGR Delete
  161. Focus 1.6tdci 2005 dpf problem ?
  162. Injector pump question
  163. 1.8 TDDI Flat, No Power
  164. focus tddi tuning
  165. 2003 focus TDCI pulling my hair out problem
  166. Mk1 1.8 tdci power problem
  167. 99 TDDI Focus Alternator
  168. Parrot Mki9100 - which leads do I need?
  169. 1.6 tdci with 283k?
  170. brake rock hard
  171. Proud owner of an st170
  172. Locking problem
  173. Tdci 1.6 cambelt
  174. Tdci 1.6 cambelt
  175. Tdci 1.6 cam belt change
  176. 1.8 tdci injector
  177. Mk1 focus TDCI sport ARB
  178. focus titanium tdci making weird squealing sound
  179. fan running
  180. Focus c max timing belt
  181. 1.8 TDDI Upgrade
  182. Focus tdci 1.6 05
  183. Looking to buy a TDDi, need opinions!
  184. Focus 1.6tdci strange engine noise
  185. loss of engine power on 2004 1.8 tdci focus
  186. Any ideas?
  187. Focus 1.6 TDCI 2005 - poor power below 2k
  188. Programming Remote key issue
  189. 2.0 tdci 2006 shudder in first and second gear at low revs
  190. Gearbox change
  191. radio 6000 cd
  192. Ford Focus 07 1.8 tdci. Remote opening/locking not working
  193. tdci vibrate and stutter
  194. new to forum - steering rack
  195. Smoking and missing tddi engine
  196. Focus 2.0 Diesel - Cruise Control Fault
  197. wont start
  198. Focus tdci 2002 power steering pipe help
  199. focus tdci 1.8 56 plate SORTED!!
  200. Map/boost sensor voltage too high
  201. Mk1 TDDI Focus front mount intercooler
  202. Focus TDCi's
  203. Looking to buy a TDCI
  204. '03 1.8 TDCI Glow Plug light flashing and power loss.
  205. 'Engine systems failure' ford focus 1.8 tdci
  206. Another TDCI hesitation/intermitent power loss issue thread
  207. Help! Ford Focus Tdci Cutting Out Every 3/4 Minutes.
  208. ford Focus 20 TDCI Starting Problems
  209. Tdci problem
  210. any1 help with codes
  211. ford focus 1.8 tdci boost
  212. Focus 1.8 TDCi
  213. strange sound
  214. 2003 Focus 1.8 tdci fuel shortage.
  215. 18TDCI Batt light..
  216. 08 1.6 tdci intermittent turbo
  217. 07 Focus 1.8 TDCi - Non start, and nothing else
  218. crank sensor
  219. 55 plate 1.8 tdci 'engine system failure' message & limp mode
  220. Focus Diesel 03 rattling/knocking
  221. 2003 Focus 1.8 TDCI starting problem 1000+ down :(
  222. Burst pipe, 1.8 tdci
  223. 53 plate focus diesiel dash problems
  224. Focus TDCi 2005 turbine wanted - help
  225. Focus voltage sensor location
  226. 1.8 tdi / tdci help
  227. what suspension?
  228. Exhaust
  229. ford focus tdci 07 loss of power
  230. No go !
  231. Oil in Intercooler (and air filter)
  232. Major service ?
  233. Ford Focus 03 1.8 TDci glow plug light
  234. Question for Engine masters?
  235. Focus 2006 Diesel Pump Question?
  236. wrattle/vibratingg 1.6tdci
  237. cold start problems focus 2.0 tdci
  238. need desperate help focus 1.8tdci
  239. margaret
  240. clutch vibrations, all the time 1.8tdci
  241. Ford focus Problems
  242. TDCi 1.6 Turbo charger
  243. Fault Code Help Required. Glow Plugs Flashed And Engine Cut Out
  244. Fault code 2337
  245. Focus tddi blowing blue smoke
  246. Focus TDCI 1.6 turbo issue
  247. Ford Focus Mk1 heater problem
  248. Urgent Help required with Alternator fitting to Focus TDCI 2002
  249. EGR position sensor on focus tddi
  250. Buying advice 2006 Focus 2.0 TDCI Zetec
