- Ford Focus 07 1.8 tdci. Remote opening/locking not working
- tdci vibrate and stutter
- new to forum - steering rack
- Smoking and missing tddi engine
- Focus 2.0 Diesel - Cruise Control Fault
- wont start
- Focus tdci 2002 power steering pipe help
- focus tdci 1.8 56 plate SORTED!!
- Map/boost sensor voltage too high
- Mk1 TDDI Focus front mount intercooler
- Focus TDCi's
- Looking to buy a TDCI
- '03 1.8 TDCI Glow Plug light flashing and power loss.
- 'Engine systems failure' ford focus 1.8 tdci
- Another TDCI hesitation/intermitent power loss issue thread
- Help! Ford Focus Tdci Cutting Out Every 3/4 Minutes.
- ford Focus 20 TDCI Starting Problems
- Tdci problem
- any1 help with codes
- ford focus 1.8 tdci boost
- Focus 1.8 TDCi
- strange sound
- 2003 Focus 1.8 tdci fuel shortage.
- 18TDCI Batt light..
- 08 1.6 tdci intermittent turbo
- 07 Focus 1.8 TDCi - Non start, and nothing else
- crank sensor
- 55 plate 1.8 tdci 'engine system failure' message & limp mode
- Focus Diesel 03 rattling/knocking
- 2003 Focus 1.8 TDCI starting problem £1000+ down :(
- Burst pipe, 1.8 tdci
- 53 plate focus diesiel dash problems
- Focus TDCi 2005 turbine wanted - help
- Focus voltage sensor location
- 1.8 tdi / tdci help
- what suspension?
- Exhaust
- ford focus tdci 07 loss of power
- No go !
- Oil in Intercooler (and air filter)
- Major service ?
- Ford Focus 03 1.8 TDci glow plug light
- Question for Engine masters?
- Focus 2006 Diesel Pump Question?
- wrattle/vibratingg 1.6tdci
- cold start problems focus 2.0 tdci
- need desperate help focus 1.8tdci
- margaret
- clutch vibrations, all the time 1.8tdci
- Ford focus Problems
- TDCi 1.6 Turbo charger
- Fault Code Help Required. Glow Plugs Flashed And Engine Cut Out
- Fault code 2337
- Focus tddi blowing blue smoke
- Focus TDCI 1.6 turbo issue
- Ford Focus Mk1 heater problem
- Urgent Help required with Alternator fitting to Focus TDCI 2002
- EGR position sensor on focus tddi
- Buying advice 2006 Focus 2.0 TDCI Zetec
- Focus Style 1.8 Diesel 2007
- Focus Mk1 TDDI 99 Belt
- Problem with fuel & temp gauges
- Focus 1.8tdci service issue
- problem with focus diesel
- sticky fuel gauge?
- PCM Keeps getting fried
- Focus 1.8TDDI Servicing
- Focus 1.8tdi noise on starting
- Ford Focus 1.6 tdci 2008 High rpm stuttering and stalling
- Focus 1.8TDCI...
- 1.8 tddi pump swap question
- Ford Focus 1.8 Diesel
- air con
- Where is the oil pressure switch on a 2000 Focus Diesel?
- egr cooler clamp blowing.
- Ford Focus 2.0 TDCi starting problems
- Focus 1.8 TDDI... few issues?
- Chabge a Cassette Player for CD Player?
- Looking to buy a Focus? Advice needed?
- Brake upgrade focus
- DMF changed and now engine cuts out.
- Fitting Mk1 RS Calipers to a 1.8 TDCi Edge?
- 2008 1.8TDCi - Engine management light & DTC codes...
- Focus MK1 Zetec 1.8 TDCI 115ps smoking!
- tcdi loses power, shows MIL but no codes
- Ford Focus Mk2 07 Battery Cable
- Rear Door Trim 2008
- Focus Tdci 1.6 DPF Removal And Remap To Suit
- 2004 focus . Turbo simple question
- Where to buy? Front wheel bearing?
- Front wheel bearing Focus TDCi 2005?
- Focus 1.6 tdci dpf issues
- Has anyone fitted a TDCi engine into a TDDI Focus?
- Mk1.5 1.8 tdci rattle/clonk on switch off.
- Focus Mk1 1.8 TDDI - Question about some cables
- tddi 1.8 focus 52 plate how to remove alternator
- Diesel pump problems!
- Focus 1.8tdci intercooler
- Focus TDCi 2003
- Rear trailing arm bush
- Focus 1.8tdci engine warning
- Focus 1.8 TDCI
- focus 1.8 TDCI 115 solid conversion vrs duel mass flywheel
- whirring c max
- Focus TDCi timing belt nightmare!
- Focus 1.8 Tddi
- Looking to get a remap on a 2007 2.0TDCI
- flickering oil light
- diesel rattle
- Focus 1.8 TDCi - Won't start - Help!
- engine ecu location
- Tdci 04 sport no power
- Ford Focus 1.8 TDCI
- M.O.T refusal
- 2007 focus 1.8tdci fueling problem
- can bus
- Diesel smell
- engine system warning light - glow plug?
- 56 1.8tdci focus engine failure fault any help??????
- TDCI focus 05 1.8. fuel pump,injectors
- C max 2.0 TDCI GHAI, 2005
- 1.6 tdci cmax black smoke and hesitation
- 02 tdci smoking/knocking......what next?
- Focus TDDi turbo problem
- IMV voltage
- TDCI ticking on start up
- starting problem
- 16 inch to 18 Rs Alloys
- 2005 Mark 2 Focus TDCi Clutch/Flywheel Replacement
- Best place to get a tdci turbo
- TDCI project.
- Another tdci turbo failure
- Which tdci is best for me?
- Help needed Focus TDDi
- TDCI ! and EMS lights...
- Map sensor vacuum hose
- Good price for a 52 Ghia ?
- Focus engine replacement
- Focus Sport TDCi smoking!
- tddi fuel filter renewal
- diesel adative
- tdci cuts out around 3000rpm
- Swapping a 1.6 tdci for a 2.0 lump?
- 1.8 tddi (90) dashes on mileage and wont start
- Focus mk1 tddi No power to glow plugs poor cold start
- Threads asking for Car Stereo codes are not allowed.
- Focus TDDI Little End Failure
- Performance cam kits for TDCi?
- hi guys tddi poor acceleration
- EGR blanking plate fitted (TDCi 115)
- Ticking/knocking sound from around timing belt area (Focus TDCi) Help please!
- Focus 6 Speed Gearbox
- Where exactly do you put the EGR blanking plate? Focus TDCi Mk1
- Mk1 Focus TDCi: Air intake pipe loose on turbo?
- Mk 2 focus speedo
- Mk 2 focus speedo
- Fuel consumption TDCi?
- ST3 Recaros on TDCi LHD
- any focus experts on here
- tunning 115ps diesels
- focus tddi 90 bhp no power
- Replacing the EGR - Devils own work!
- mk1 tddi no power to glow plugs
- focus 1.8 tdci mk1 glowplug light 1 second wonder
- Focus Tdci sport
- TDCI Remap
- 1.6tdci overboost problem, intake manifold and sensors
- 05 Focus 1.8 TDCI eml on and no boost sometimes.
- Help: Ignition/battery warning light on/off
- 09 focus titanium 1.8 tdci.
- Ford Focus TDCi 2005 - suspension?
- Turbo timer in Focus?
- power steering pump plugs.
- Focus TDCI – Buying advice sort after
- What are the best mods for a 51 plate diesel focus?
- focus tdci turbo failure??
- 2.0 tdci noises and vibrations
- Focus Glow Plug Light Flashing & Cut Out on Motorway
- focus tdci ..no boost!!
