View Full Version : Ford Focus Range
- Mk2 rs on crash register
- Instrument Panel Dies Ford Focus MK1
- None start after new clutch
- Coolant temperature sensor
- Saloon tow bar
- Travelpilot FX Service CD
- ST170 Brake Booster ref number
- 1.6 upgrade
- Engine noise problem
- Focus mk2 Ghia Estate
- Cam Shaft Seals Help Please!
- Focus 2.0 zetec blacktop gear ratios
- Speedo calibration st170 mtx75 swap
- Automatic gearbox issue
- Mk1 2.0 cat converter valve?
- What year did Ford stop using the 2.0 blacktop?
- Drive Shaft Oil Seal - MkII Focus
- Mr LT
- 06 MK2 Focus Leak?
- Focus manual/electric sunroof
- RS V st170 Alternator
- 1.6 Tdci underboost problem
- Focus58 plate sunroof leak
- Why Purchasing Vehicle Form People Is the Best Choice
- Question
- Ford Focus Smart Charge Problem
- Focus 1.4 Aircon Issue
- Ford Focus first gen - service (oil)
- CC3 expert
- Ford Focus MK1 2004 - Rear Suspension (Please Help)
- Zetec lights swap
- ST170 Brake / ABS / Traction lights on after touched battery
- MK2 focus flywheel
- Electrical issues 2010 tdci
- 2006 Focus 2L TDCI - Limp Mode issue?!
- Zetec workshop manual
- Fuse Box
- Mk1 ABS fault - MOT tomo. Please help!
- Focus Mk1 RS Sandwich plate seal HELP
- Electric mirrors problem
- Focus at Help needed
- ST225 to TD04 down pipe exhaust flange adapter
- Taillight/Brake Light Issue Mk1 Focus
- ST170 Oil Gauge Scratching Sound and Dull/Flickering Cluster
- St170 Lambda sensor.
- Focus mk2 rear wheel bearing
- Rod length help
- Locking Wheel Nut Removal
- 08 focus 1.8 tdci problem
- mk1 Focus steering rack dimensions req'd
- Re-use Crankshaft pulley bolt??
- Converting US tail lights to UK
- Mk1 focus sleeper project (project stealth)
- Brake disc not clearing
- Ford focus 1.0 advice needed
- Rear window washer not working
- Duratec engine into Mk1 Focus
- No high speed wipers
- Focus flywheel and clutch dimensions
- Heated windscreen DTC Code
- FRS MK1 Duratec RS Engine
- Focus 2009 1.6 timing belt - threadlock on bolts?
- :wall:Alternator Problem?
- Focus mk1 Mods
- Ford focus cc2 esp light
- Focus saloons rare/ collectible?
- st170 value
- Focus mark 1 advise needed
- Focus mark 1 Check your sills project car
- focus 2.0 engine connector.
- iB5 gearbox
- Stuttering / Hesistation 1.6 Zetec 105k
- 2003 1.6 zetec ecu
- Help back smoke ford focus 2.0 turbo diesel
- Ford electrician needed for advice
- Steering problems AFTER alignment
- Steering Assist Message
- Water leak on st
- Could a droplink cause a clunk/knocking sound ?
- Knocking sound when slowing down/braking after hitting a deep pothole, what is it ?
- What's wrong with my car when starting from cold ? video included
- focus rwd conversion
- Turbo oil bolt topic, I am going to take your advice and get a new turbo pipe, but..
- I think this turbo oil feed bolt nightmare is over ! (last thread on this I hope, )
- Turbo Oil bolt problem update : would this work to solve the problem ?
- Should a turbo oil feed pipe contain a washer(seal) on a ford focus ?
- How difficult is it to remove EGR manifold on the 2006 ford forcus 1.8 tdci ?
- I'm really stuck. How do I tighten this bolt?! video included, please please help me
- Can spanners be cut with a hacksaw? I need to tighten bolt on car but not enough room
- Clunking noise when clutch is brought up, what could this be ?
- In your opinion how much do you think for the following list of repairs at a garage ?
- White smoke and erratic idle from cold start, then runs fine, what can cause this ?
- does the whole EGR + Manifold need to be removed to tighten a turbo oil feed bolt ?
- Do you think it's true that the head gasket on my car has gone ? please help
- Focus mrk1 shuts down
- St 170 clutch differences
- St170 power issue/ fuel issue
- T309 BFM at the beginning.....
- Zetec Billet Gear Oil Pumps
- Carpet mats; Can anyone recommend any that actually fit?
- Power folding mirrors.
- Focus mk2 bi-xenon rating.
- st 170
- Faulty petrol gauge?? 1.0 2013 Focus
- Focus 2.0 duratec engine tuning or engine swap
- Ford Focus 2008 1.6TDCI Limp mode - see ford diagnostics report attached
- Ford focus 1.8 duratorq
- ST170 eml weird fault codes. please help me
- Immobiliser Light Problem Ford Focus MK 2
- Focus 06 4d Ghia - Driver door and window Help !
- st170
- Focus Zetec-S mk2.5 2009 body help
- Ford Focus 1.4 i know there crap
- Ford Focus TDCI 1.8 2002
- Mk1 ford focus suspension
- st170 front fog lamp removal
- Focus Mk1 Problem?
- Folk don't get much help/answers here at all
- Focus Mk2 1.8tdci Error code P0222
- Cam Followers and Shims
- Focus zetec engine change
- Focus ecu list?
- St clocks fitting in a zetec mk1 focus
- st170 subwoofer
- Ford Focus 1.6 Zetec 2006 - Starting Problems
- 2004 focus 1.8 tdci sport slave cylinder replacement
- Ford 2012 titanium 1.6
- Oil temp on a focus st170
- can i add bluetooth to this radio
- mk1 rear lower wishbone bolts
- Help! How do I remove drivers leather seat cover
- ST170 Speedometer
- subframe alignment pins
- Help! Ford Focus 2002/3 1.8 Zetec Power problems
- car struggling starting in morning +
- New suspension mk1 focus
- focus ST oil leak part 2!
- ST170 Exhaust Change
- Help Please Someone, ST170 no power 😞
- Ford Focus 1.6 Petrol 2002 Clutch Replacment
- Focus ST 225 MK2 mods, which ones to get?
- Ford Focus Juddering/Hesitating
- ford focus 2010 1.8 petrol
- Engine / Model Advice
- Mk2 focus tailgate interchangeability
- Ford focus 1.8 engine problems
- rear axle beam
- mk1 focus tdci 1.8
- focus 1.8 pin outs for rev counter. I'm fitting omex
- Beeping indicators?
- 09 focus limp mode
- Is there a gasket between the oil pan and engine? HELP PLEASE!!
- hunting idle
- Cold running
- Mondeo IMRC on Focus?
- Will Ford Focus Door Match Ford Focus Ghia?
- Please help ford focus mk1 will not start!
- Strange Indicator Problem. Please Help Asap
- Focus cutting out
- what focus diesel engine is best
- which diesel engine
- Focus CDTI wont start
- Running with the engine light on?
- st170 dct p1131 help
- Notchy Gear Changes/'Baggy' shifts - Advice
- anyone know the size of the bleed nipple focus
- Getting rid
- Changing vin on PCM (ECU)
- 04 Mk1 Focus 1.6 Zetec - Stuttering/Hesitation at 65-75mph
- 3 door locking problem?
- Towbar electrics headache,
- focus 1.6 style
- Engine light and part id?
- Need a New Paint job
- st lights
- Disarm passenger airbag?
- Window motor and relay?
- Sub Frame
- Focus st 225 wheel spacers
- Focus mk1 .5 rattling at 3000rpm
- rear camber focus
- Focus bonnet
- anyone clued up on mk1 focus interior?
- check engine light on
- Replacing Cat C - Focus
- TOGA HV Oil Pump
- any idea what the connector is for
- USB port in Focus
- Rear Trailing Arm Bush-advice please
- Just bought a 1.8 CDTI but..
- mk1 focus exhaust flexi repair
- Focus cosworth 4x4 guys.
- Focus Mk2 1.8tdci repair time
- Common air leaks?
- 2003 focus tddi, strange behaviour.
- focus st2 not boosting
- Lack of power issue 1.8 54 plate focus
- Help please .
- focus estate rear windows
- El feil på 2002 focus 1,6tdci
- mk2 seats into mk1 focus?
- replace the subframe on my 2000 focus.
- Wheel locking nuts - removing without the socket?
- wipers stopped but motor still going?
- Please help me..
- ST 170 fog light bulb removal
- Catalytic converter - would you repair or put up with ? [mk1 focus 1.6 petrol saloon]
- Squeak from auxiliary belt [mk1 focus 1.6 petrol saloon]
- ST170 Rear suspension issue
- Renewing timing belt mk1 petrol saloon
- I need a comfier seat
- Piper MK2 Focus ST Replica Exhaust
- MK2.5 Cold Air Feed
- location of fuel filter on Tddi
- focus handbrake
- Limited revs?
- 01 Focus ZX3 chugging/ loss of power
- VERY smokey focus tdci
- Ford Focus 2008 1.6 Studio Eco Diesel Massive Engine Problems
- mk1 focus reg plate bulb blowing
- Very high revs
- mk1 focus 1.6 'hunting' engine
- Mk1 Focus Front End Conversion
- FORmiDable help
- any St170 owners, bolt on mods?
- White smoke and internal fans blowing
- Removing rear light cluster off a mk 1 focus!
- st170 clutch help please
- Wind deflectors
- fiesta mk3 xr2i calipers
- Loss of acceleration and speed
- 1.6tdci head bolt torques
- Tyre help for my st
- Sierra steering wheel on mk1 focus
- The NEW 2015 Ford Focus
- show us your Mk3 Focus
- Ford Focus Estate 4x4 cosworth
- ST170 cams into 130bhp 2.0 zetec
- Friction area mk1 focus rs discs
- standard boost
- Mk1 focus cl 2002
- 2.0l Zetec head rebuild advice.
- Focus 1.8 TDCi Coil light, cylinder 4 above knock threshold
- shades of grey?
- mk1 focus remote locking module
- 03 focus instrument cluster
- Are They The Same Engine ?
- double post please delete
- focus rs mk1 power limits
- 2012 focus rear bumper
