View Full Version : Ford RS Cosworth parts for sale
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41
  1. MT75 Fix IT Big Tooth Gearbox With 4.4 Drop Gear Set
  2. Cosworth 2WD Diff
  3. Escort Cosworth 6 point Roll Cage
  4. Safety Device Roll Cage
  5. MSD Wasted Spark Loom
  6. Breaking Escort Cosworth
  7. Saph cosworth genuine ford front cross member
  8. 4x4 cos box big tooth 3rd gear frozen gears uprated diff etc etc
  9. t34.63
  10. Fully adjustable top mounts
  11. Tilton bias peddle box and external w/gate
  12. Gt3076 and exhaust manifold.
  13. Turbo cooler - sold
  14. whats it worth 3dr L1 ecu with stage 1 chip
  15. Cossie 2wd mongoose exhaust
  16. es cos parts
  17. escort cosworth walbro pump
  18. MT - Motorsport
  19. Small turbo steering wheel
  20. 3 door / Saff / Escos bits
  21. escort cosworth smoked rear lights new + dashboard
  22. Cosworth Goodridge braided custom two piece rear brake hoses
  23. Cosworth Goodridge front & rear braided brake hoses
  24. 225/45/16 Avon ZZ1's
  25. Escort cosworth Boot catch
  26. MSD Fuelpump & Fan loom new
  27. 4x4 Front Diff - £90
  28. Sierra cosworth 2wd for breaking
  29. saph raven leather door cards
  30. T34 turbo
  31. 2wd saff cossie parts for sale
  32. siemens 55 black injectors, turbo
  33. Bosch grey injectrs
  34. Genuine Escort RS Cosworth Whale Tail - Imperial Blue
  35. Stack dash
  36. Turbonetics GTK550 turbo
  37. SOLD
  38. Escort Rs cosworth running gear
  39. Msd chip 55lb siemens t38.63
  40. number plate c20swh for sale
  41. 3 door grille and plastic 3 piece scuttle (other pics added)
  42. Trim bits Escort Cosworth
  43. Cosworth parts
  44. Cosworth 4x4 Throttle Body Modified For Anti Lag
  45. Garrett GT30 Turbo With 0.63 Housing
  46. Sierra Cosworth Rad, Fans and Master brake cylinder
  47. 4X4 grpN uprated front shafts, (pics now up)
  48. 4wd Cosworth front brake discs 273mm - £30
  49. -31 actuator
  50. Pectel t2 ecu and loom, pedal box, dry sump and more on ebay
  51. brand new escort cosworth door / window scapper mouldings
  52. *SOLD* Brand New GTX 3076 Tial V-band exhaust housing
  53. new bara gearbox
  54. Group A genuine 4wd steel front crossmember
  55. escort cosworth rolling shell
  56. 2wd saffire cosworth in for breaking
  57. Omp bucket seat harness side mount
  58. Escort Cosworth Rollcage 6 point
  59. saph cosworth 4x4 front koni's (still available)
  60. Push on gear knob
  61. 2wd Cosworth 4 pot Calipers - £45 delivered
  62. AP racing 4 pot brakes
  63. Nice crackle black complete inlet manifold
  64. 3dr carpeted dash, heater matrix
  65. Bailey Motorsport 2WD Header Tank
  66. T4 Turbo
  67. Pro Alloy RS500 Intercooler SOLD SOLD
  68. Cosworth Engine Parts, 3 Door Parts, LSD, Beam & Arms, Plus other bits
  69. Saph cosworth front bumper
  70. 044 fuel pump - SOLD
  71. Small turbo inlet, dark green 803 injectors
  72. Parts for Sale... T38, fuel pump, inlet etc
  73. Escort Cosworth Group A LHD Rally Car Breaking, 9" Rear Diff, AP brakes
  74. Comp MO 18x8 Old Style 6-spokes Gloss Black (A048's)
  75. 4X4 Saff breaking
  76. 3dr cosworth breaking
  77. brand new willans 3" harness on e bay
  78. Few parts. Seals and rail added 22/1/12
  79. KNOCK LINK - Engine Safegaurd
  80. Rear Quarters
  81. 2wd saph cosworth parts
  82. 2wd drive welded diff
  83. Dump valve and airbox
  84. A few 3 door/ Cosworth bits for sale, Prices lowered to shift.
  85. SOLD!!!
  86. 2wd cosworth parts
  87. 3dr cosworth rear lights
  88. Escort and Sierra Cosworth Parts
  89. Hi-Spec 6 pot Monster conversion 330mm brakes NEW
  90. A few parts for sale.
  91. 3 door breaking
  92. Battery Relocation Cabling (to boot)
  93. Cosworth oil pressure switch adaptor block
  94. Parts for sale, secs, plenum, NOW WITH PICS AND MORE PARTS,NOW ON EBAY
  95. Focus Rs front brake set for 2wd*now on ebay*
  96. 3DR doors
  97. Ultralight 789/Atec 17" alloys and new tyres. 7" front 8" rears
  98. cosworth parts escort sierra 2wd 4wd
  99. Garett GT3071R Turbo
  100. Cosworth Parts
  101. Some lovely bits for you Cosworth guys ;) UPDATED 16/01
  102. Ap 6 pots to suit 330x28 discs
  103. Apexi 60mm 2bar boost gauge for sale
  104. Aim Dash
  105. Various Parts off my 2wd!!
  106. Pectel board for l8 ecu & bt escos beru leads
  107. Rs 500 front bumper
  108. Cosworth 4x4 7" rear Diff - £160
  109. 3" bore stainless steel silencer with 3.5" rolled in tip - Pics Added
  110. Escort nomad rear lamps
  111. Garage clearout, manifold, mounts, rad, fans etc...
  112. Cosworth 2wd B&M Quickshift... SOLD
  113. Cosworth parts
  114. pro alloy radiator and rad fans
  115. Escort cosworth carbon a pillars SOLD
  116. 2wd diff..
  117. Escort Cosworth Big Spec Breaking
  118. 2wd rear cosworth CV boot kit
  119. Torques Aeroquip fuel lines / fittings
  120. Cosworth parts. Samco, Stack, Wheels....
  121. Sapph jacking point cover
  122. Reyland bells and brackets For cosworth ap brakes £185 delivered
  123. dump valve
  124. 4x4 handbrake cable wanted
  125. 380mm 6pot 2wd front Brake Kit (Reyland Bells)
  126. saph boot and spoiler
  127. Escort MAXI/F2 and Cosworth WRC/GrpA items
  128. L6 stage 4 powerchips with ecu...
  129. Suspension
  130. Bd14, Light Blues, Carcoon and other parts
  131. Evolution Chip 4x4 cos
  132. Swedish pleunm New ! Never Been Fitted !
  133. Brand New T5 5th gear
  134. 2wd cosworth front hubs
  135. 2wd cosworth rear calipers
  136. Cosworth steering wheel
  137. saph shell
  138. Cosworth Parts
  139. B&M shifter for 2WD, T5
  140. Cosworth looms and intake manifold
  141. Sierra/saff 2wd cos koni's
  142. Cosworth Seats
  143. 3 bar boost gauge - £35 delivered
  144. Carbon Timing belt cover
  145. Level8 ecu msd stage 3 chip and greens
  146. MAP sensor bracket and 3 hole dash gauge mount
  147. Cosworth wiring looms and intake price help
  148. AP RACING 4 PADDLE CLUTCH cp2583-3
  149. Throttle Body 72mm
  150. Engine Monitor For Sale
  151. AP Racing 6pots For Sale
  152. 3 door cossie Bling ( SOLD )
  153. few bits
  154. Breaking my 2WD Sapphire Cosworth
  155. New Cosworth Boot Badges and Carbon
  156. please delete
  157. Cosworth parts
  158. custom secs monitor and boost gauge holder made by twins
  159. saph 4x4 bonnet with vents
  160. Escort Cosworth Air Box - Large Turbo
  161. apexi avcr boost controler
  162. Escort Cosworth Mintex Rear Discs SOLD
  163. Brand new genuine parts left over
  164. airtec 70mm cooler and turbo pre cooler
  165. cobra bucket seats
  166. delete
  167. 3 Door Rep rollin Shell More Pics!!
  168. full cosworth running gear and engine
  169. 3DR Rear Anti Roll Bar droplinks Brand New
  170. Escort Cosworth MT75 Gearbox for sale
  171. Koni Suspension With Ahmed Bayjoo Dual Rate Springs
  172. Cosworth T38 turbo Harvey Gibbs spec NEW
  173. Pro Alloy RS500 intercooler brandew
  174. sierra cosworth t3/t4 t34 hybrid turbo
  175. SECS monitor forsale
  176. Cosworth marelli grp a coil
  177. escort cosworth parts
  178. Breaking Escort Cosworth Big Spec
  179. hart plenum* NOW SOLD*
  180. Cosworth carbon
  181. Escort cosworth interior
  182. Uprated MT75 gearbox Laygear bearings
  183. Magenta sapphire
  184. L8 Ecu green top with bayjoo stage 3.
  185. Various Cosworth parts
  186. Now sold
  187. P8 Chip and Board
  188. Few cosworth bits
  189. MSD Stage 3 Set Up
  190. rear cossie Ap 4 pot kit £500 delivered
  191. cosworth hybrid turbo for sale
  192. bailey sperator tank
  193. Cosworth T38 Turbo £650ono
  194. dash,as rad cap,poly bushes and more
  195. diff and sump on ebay
  196. AP 6 paddle clutch plate T5 box fitment
  197. whats it worth? 4x4 loom.
  198. Cosworth 2wd parts for sale...
  199. Its Xmas Sale Time. Grab A Bargain Today!
  200. 340 bhp L6 package
  201. 7.5" FFD Front Diff With Sump, Cross Shaft, Oil Pick Up Pipe
  202. Group A Mountune Engine With All Ancillaries
  203. escort/sierra cosworth crank pully (new)
  204. saff full leather interior
  205. 2wd Kent bd10 exhaust cam
  206. 2wd/grpa blue alloy brake bells to suit ap type discs - £90 delivered
  207. Carbon,Bailey,Samcos and some Bling
  208. Garret GT3076R.82 Turbo. SOLD
  209. Sapphire Cosworth Gauges
  210. Cosworth 4x4 Bara straight cut gearbox £3000
  211. 36-1 trigger wheel for Cosworth YB x2
  212. 500 BHP? YB Engine..... Keeping hold of it for now.
  213. Cosworth parts for sale
  214. sierra cosworth 3 door head lining
  215. Sapphire Cosworth Bumpers, Bonnet, Skirts etc..
  216. cosworth billet oil filler cap(screw type)
  217. WANTED:3dr abs block
  218. MT75 Strait Cut Dog Box - !!!!NEW!!!
  219. cos 500 fog lights
  220. Escort cosworth parts
  221. 3 door doors
  222. 7 1/2 rear beam 3 door
  223. 205 block, Mahle pistions & various parts
  224. Cosworth parts bailey and spec r bling carbon and lots of other stuff
  225. Cosworth Parts,Bucket Seats,Rear Strut Brace,Lots more all updated 300112
  226. 2WD Hart Inlet with fitting kit-Now Sold
  227. Quaife Gearbox
  228. Yb isky valve springs
  229. Bailey mirror image oil seperator ***SOLD***
  230. Cosworth parts (even more added)
  231. auto specialists pro series black header tank and cap £90
  232. L6 ecu Light Blue injectors
  233. SOLD! 3Dr job lot front bumper. SOLD!
  234. Group A Ignition Coil - prov sold
  235. T3 Turbo & Yellows (inj)
  236. Sierra Cosworth 4x4 Track Car Fully Trimmed Shell
  237. Sapphire Cosworth 4x4 Track Car Breaking, Group A Parts 18" Alloys
  238. Focus RS calipers for sale
  239. t34
  240. black art design 3 way coilovers
  241. ST Escos Inlet
  242. tailor made outdoor cover for 3 door + indoor cover
  243. Cosworth crank .25
  244. sold
  245. 4x4 transmission, mongoose exhaust etc!!
  246. 3dr cosworth headlights
  247. Brand new Blue Willans 3" harness
  248. intercooler and hoses
  249. sold
  250. Swedish plenum for cosworth req fuel rail lugs
