View Full Version : Ford Escort RS Turbo
- zvh pistons
- CLUTCH!!!! HELPPPPPPPP!!!
- Anyone done a wheel stud conversion on the series 1??
- central locking& elec windows not working!!!!!!!!
- what next?
- escort cossie brakes and wheels
- zvh advise please!!!!!!!!!!!!!!!
- Does anyone know of The Rs Centre in Billericay Essex?
- engine rebuild advise (zvh)
- MFi injectors
- red rocker cover... wat u think?
- CHARGECOOLER ON A S1 ANY GOOD
- Pro Alloy
- 2.1 zvh whats the most boost i can run safely??
- Yet another series 1 question...
- 200bhp???
- Rear brake troubles
- oil leak
- Stock S2 wanted for Fast Ford photoshoot
- Starting on 3
- Wet carpets
- PROJECT PICS ( 3 PROJECTS ON THE GO, I MUST BE MAD )
- series1 scuttle panel
- MXV`s....what are they worth??
- s1 alloy with mxv & s2 rad
- Turbo
- piper 285t
- Which intercooler??
- Clunking Noise????
- Suspension hardness
- To spray or not to spray
- Carbon Fibre Bonnet
- Engine Questions
- I'm off to look at this s1 today
- I just nearly gave birth
- help.........been done out of money by a potencial member!!!
- S2 Tailgate into an S2?
- Pace intercooler will it fit ????????
- finally got my engine back..........
- steering column gauge pods?
- Starting up RS
- Anyone got pics of a S2 with smoothed bumpers?
- help my rattleing rst....please
- zetec turbo tubular manifold
- What Dot Brake Fluid should i be using in my erst s2
- Smelly RST
- BORING CRAP WEATHER
- What cams
- Take a looksee at this......
- need more power.
- What do you think?
- Help needed - fuel pump on S2 Turbo
- Buying an S2 with around 55k on the clock - what to check?
- Advice on silicon hoses - which brand?
- 5if injector ?
- What's the difference with 90spec and non? - Pics please!
- S1 Carrello Headlamps
- MY RS S2
- s1 mud flaps
- Blow off valve
- inner cv joints
- anyone heard of sierra cossie clocks, in an s1???
- gearbox numbers
- black turbo
- Pic re-size?
- Is there anywhere that rebuilds ke-jectronic metering heads
- Name that multi plug on ERST fuel metering head?
- 82 degree thermostat for rst *update* Needs modification
- Bonnets......
- S2 ERST 2.1 ZVH FLYWHEEL HELP.... !!
- RS Turbo website
- RS TURBO BRAKE LIGHT MOD...
- Can you still buy series 2 bumpers from ford?
- Just got an S2 rs turbo workshop manual
- mahle pistons advice!
- gearbox rebuild?
- A few pics of my '87 S2
- Just wanted to know is it true that if you have a ..........
- s2 starting prob, no spark!
- please advise my on a turbo
- va,ve stem seals
- clutch pedal needs changing to mk 5 spec ,part numbers need
- S1 or S2
- whats a ecotek valve and are they supposed to be any good
- ABS removal on S2
- dump valve/chatter????
- Series 1 Starting Problem
- Which fuel pump???
- my series 1
- Delocked tailgates
- bayjoo chips
- A few pics of my angel
- where is cold start valve
- turbo's on 16in wheels, anybody got any pics?
- Which bulb ?
- samco's??
- cold start valve
- Not original I know BUT does anyone know of G272 EUK (S2)
- People with Mongoose exhausts.........
- ARP
- What wheels for traction
- whats the brown plug on mfi s2 on the injector plate?
- Roller Bearing Turbos???
- newbie thats after a little help and advice!
- went to look at another s1 last night
- Tourqe settings for sump plz ?
- F965LVK, ANYONE KNOW THIS CAR?
- Clutch probs s2
- engine
- has any 1 had new sills fitted to there erst? help please
- Finnishing off stripped RST's.
- frst
- s2 not blowing hot air
- Not happy, AT ALL
- here we go again.. hot S2.. problem maybe solved?
- Whos is the rather nice E Reg RST going round Barnsley
- What do I need to run an EFi setup on an Escort RST?
- cossie callipers on S1. HELP!!
- loom daiagram needed!!!!HELP
- Replacing the turbo
- cars off the road
- Is it me or is there something wrong with this S1?
- What airfilter in MFI converted to EFI escort ?
- what cabe is the one for the rev guage (tacho)
- WHAT BHP
- Stage 2 Turbo - What other mods required?
- Clock removal
- handling and shaking!
- Proalloy intercooler arrived in the post today
- Tarting up the engine bay...
- Engine Rebuild Questions
- Gaz Coilovers.......Rst owners
- turning up the boost
- Electric schematics needed
- Fuel pump bracket
- Suspension opinions and advice?
- Just got back from APT!!!!
- LEAKING OIL BAD helppppp
- indicator relay
- Tracking on a S2
- Newbie needing tuning advice
- s2 front panel
- breather system
- brake pads(front of course)s2
- rear wheel twisting in?
- F978 TPY anybody know this black series 2??!!!
- G151 DHF S2 Anyone know this car??
- cossie management/webbers???
- Quick question!
- One of those look what turned up in the post threads lol
- do you run a......
- Anyone checked....
- L6 ecu with pectal board
- What's the handling like?
- JUST GOT ME SELF A CHIPPED ECU IS IT STG 1 OR 2???
- B594DEV Any one know this car????
- cold start/5th injector fuell pressure mod?
- how do you remove ERST S2 arches and slam panel?
- Just got my new engine
- Did all series 2 have front fogs?
- Quick gearbox help!
- Keeping the water cool ?? S2 Turbo
- My first RST - any advice appreciated! GOT ONE!!!!!
- Gaskets
- Rust on the roof
- MFI vs. EFI
- ford fair at donnington park!!any 1 goin??
- Battery Tray....
- Who has done an EFI conversion on his Escort ?
- seem welding engine bay over 250bhp
- RS OWNER AT LONG LAST!!! ;)
- engine wiring
- question on fuel filter removal/refit....
- S1 Front washer fluid bottle Q
- polybushing rear wishbone
- Collapsed jacking point
- Gear linkage?
- S1 Interior Pics Sorted At Last!!!
- Help me find some wheels for my rs turbo
- Pics of my S2...Just about done!!..
- Gearbox Oil?
- What Yous Think?
- Restoring My S2
- click for cheap coloured dials
- MFI to EFI conversion - Fuel tank question
- will a cossie t3 turbo fit on my s2?
- Someone pls give me a pick of fuse box
- Series 2 RS
- New Alloys = Odd Noises
- How hard is it....
- how much for a turbo rebuild?
- i think my turbo's on its last legs help
- swirl pot
- RST CVH goodies compatibility?
- how to adjust koni adjustables???
- s1 0r s2
- Series1
- what size tailpipe on my s1 3"OR 3.5" ?
- how fast does a s2 go at rev limiter in 5th gear
- What offset wheels do i need with 2wd cossie brake set up?
- any info on series 1 B144 EHK
- MFI idle co adjust guide?
- Weird starting question............
- Must be the lowest mileage s2 in existent
- need a new turbo, what do you think of this..........
- how do i get......
- can anyone help?
- Thanks to Christian and Gary @ APT
- Jacking up a S1 Question
- Post piccys of your S2 RS Turbos
- Heated Front Screens
- series 1 wheels what 17s look good
- Maximum BHP on S2 ERST
- who's been in a s2 zetec turbo then ?
- does anyone??
- still no luck
- New engine build over the summer, which one ????
- Any such thing as a none welded rs turbo?
- S2 Running problem!!
- Anyone know where i can get my s2 rocker cover powdercoated
- fuel pump prob???
- rev limiter
- ERST S2 HEAD GASKET??? FORD ONE BEST..
- Smoking?
- how rare is an 88 erst with 2 previous owners
- Find Dan an S1
- work to fit 17`s???
- rst turbo wanted
- Sparking on No.4 only - cosworth management
- what will a std s2 cost me?
- does anyone know if the gearknobs from the new focus......
- any 1 got a black bonnet for sale?
- my s1
- Amal Valve connect ERST.
- will escort cos front calipers/disks fit on a s2?
- moving
- Turboing a zetec?
- ecu `s????
- A piller gauge mount
- My S1 *pics inside*
- Benefits of an uprated breather system?
- White ERST?
- Whats the difference between the Turbo's on a S1 and a S2?
- Wanted - Original Series 1 Stereo - Analogue or ECU1/Digital
- escort rs turbo wanted
- diamond cut alloys?
- turbo wanted
- s1 chipped ecu problem
