- More power,
- Info on garret turbos
- Series 1 any one know this one
- Amal Valve - what else is it connected to?
- Christmas rear lights LOL
- sterring wheels
- need some 90 spec red and black back lights
- Blow in turbo&manifold
- 90 speck interior into my s1
- 2WD Cossie front brakes onto a S1?
- What Fuel Pump
- S2 Metering head??
- lets get it on at USC!!!!!
- injector seals, where from? pls
- Spark plug gap
- S2 Brakes
- front caliper seal kits
- To Burn or Not to Burn...
- Best plugs and ht leads
- twin fans on the FRONT
- Tips on getting my s2 red !
- how many of you are useing......
- dump valve for S2
- mk5 clutch pedal conversion parts.........
- *** AVA ROLLING ROAD DAY ***
- What oil for running in?
- Help needed with lights
- cosworth t28 turbo on a s2
- max power on........
- Are S1 and S2 sunroofs the same?
- Tminig up a ZVH Engine
- ZVH HEAD GASKETS
- Normal brake fluid container on RST master cylinder
- My RST Rear Suspension Setup! a few pic's!
- Body work
- Inlet manifold vacume pipes??
- No fuel pressure at meter head!
- Custom or Non-custom S1
- 90 spec smoked rear lights wanted
- S1 rev counter wiring, Q
- fireing order ERST
- s2 turbo on to a s1
- s1 window switches
- Series 1 advise wanted
- Rust damn rust!!!!
- lovin this cold spell
- why is the spark so weak ?
- What type of oil's you guys using on your ERST'S
- fuel pump
- look at these coolers
- Now my new turbo gone
- Let's Talk Suspension Then.....
- Guages
- what did i do wrong ?
- best springs
- s2 bodykit
- Series 1 Altenator
- Battery wires
- Actuator setup
- bonet lifters
- bhp help
- Anyone got...
- fuel pump wont prime??? please help.
- sump plug
- Electric Mirrors and front screen
- Actuator rod question
- please help with clutch problem i think
- stage 3 turbo
- What oil?
- rads
- New cam fitting question.
- Amal Valve - How to wire pls
- QUICK ONE WIRES?
- paint code for S2 mercury grey
- what other servos fit a mk 4
- Intermittent boost problems
- s1 sideskirt caps
- rear tie-bar setup
- my new rs
- what cam?
- How do you lot....
- My S1 pics. . .
- turbo oil return
- any one no this on d778 rpp
- S2 INTERCOOLER
- kent cvh34 cam
- power sapping something!!!!!!!!!!!!!!water injection?
- New pics
- 071c motorcraft plugs
- Which Turbo Timer Is Best?
- URGENT HELP!!!
- temp gauge not working
- Fuellin probs
- Rs info!
- wish i'd left the abs on!
- turbo pipes
- S2 Running probs, Please help!!
- MUK SHOW PICS UP......
- whats that plug on the amal valve for ?
- RST Problems
- Fan Switch
- Mongoose problems?
- Where is best to get wiring diagrams?
- new alloy rad with pics [ progress]
- bone idle
- Gearbox's and Engines
- holes in my head....
- oil for s2
- efi tubro engine running
- My new mod.
- series 1 parts
- omg its to dam hot
- Part number for 90 spec rear lights
- pics of me car! some more pics!!!!!!
- t3 unit surging on boost
- Water temp gauge
- which discs????
- Anyone Using The Kent cvh37 cam?
- who has the quickest s2 on here?
- amal valve
- Changing Front Seats
- S2 calipers n 2wd cossy discs what pads
- please please please help me with rising revs
- turbo coolent return?
- need an intercooler
- [b]SERIES I [/b]
- deflex bushes
- rear disk conv
- Actuator
- Noisy Fuel Pump!!!
- amal valve eek!
- Anyone know this Series 1?...
- HELP ME AVOID A DOG!
- need advice on my turbo
- wahoo
- FAO 2.1 Zvh owners
- Intermitent Temp gauge ?
- best filter for rs turbo
- Alternator charging question....
- amal question
- best place to get a stage 2 hybrid??
- Power and Gearing
- Heater pod gauges
- wide arch kit
- help please
- RST's @ RSOC day KNOCKHILL! this Sunday
- Top Boost Hose
- anti roll bar , what one to use
- Standard or Morrete?
- heres the question!
- S1 experts
- Sunroof blow out on motorway
- Newbie introducing and classic insurance question!
- Fuel Pump Relay
- Power Steering RACK FOR A MK4 ESCORT
- cossie management on ERST
- Wheel offset For S2 rst
- Oil light Flickering
- Actuator adjusting help please
- where is the idle speed screw please
- s1 rear window
- woohoo cars running!
- classic ford show at pod?
- Another fuel prob
- zvh boost
- ride hight
- rolling road with printout in yorkshire?
- Replacement Ford Expansion Tank
- Amal control? Standard ECU Please help
- Rear Strut Bracw for a s2
- Running Problem
- ***pic request please***
- FAO all of you runnin mongoose on ur s2
- Good after market ECU
- oh no, Now my Turbo's gone
- EFI Conversion
- How do you fit a ERST Boost guage??
- Help needed please
- vulcanengines
- anyone ever snapped a driveshaft
- lighter
- pic request
- Series 1 rear disc conversion!!!!!
- Which management system is the best to use?
- new comer
- rear brake line info needed (yes something else broke lol)
- Pic request of S2's with front pro-alloy intercoolers fitted
- Found something that might be interesting for people on here
- relays. oh god plz help!
- crankcase breather
- Coilover's on S1/S2 Discussion!
- 90 spec door cards
- wiring looms
- Pumaracing double valve springs
- dip stick is very lose? not good?
- head work
- Pics of s2's on sixteens please
- Boost Controller
- Deflex gearbox mountings mk2
- Car hesitating
- Replacement panels S1
- wullie young s1 spec
- S2 servo and master cylinder question....
- microdynamics 5th injecotor computer
- anyone running diamond cut rs 7 spokes
- advanteges of going efi (s2)
- Series 1 gearbox re builds
- XE OR CALIBRA TURBO PISTONS???
- IS A T25 TURBO GOING TO BE ANYGOOD FOR ME???
- newcomer
- oil/crank case pressure problem (keep killing gaskets)
- fuel pump
- What cam are plp using?
- Washer bottle rubber
- Focus Rear Discs
- Bailey breather kit fitting
- wheels rubbing arches mot fail!!!
- Brake warning lights
- Not what I wanted to hear
- dash in dash out
- S2 Problems please help
- took my car to a sprint track
- can anyone help with where to get these bits for my s2?
- Mk3 escort clear rear lights
- my cars in the mag
- Rear Disc Conversion on S2
- bloody great (box probs)
- Brakes
- Looking to buy cam and kit
- Pace Charge Cooler Fitting
- Series 2 engine bay earths, advice needed....
- RS Turbo - Too much crankcase pressure?
- project E111NWD 270bhp erst begins!!! with pics!
- Modifying in reverse, can anyone help
- Clifford cox engineering based in Reading. any info?
- What Wheels?
- can u buy rear brake cylinders new
- Fuel Pump wiring
- Will these wheels fit with this suspension?
- I was told that.....
- Does any one know what a dump valve controller is
- Brake problems also
- Standard ERST fan switch, what temps should it cut in &
- What type is the stock ERST LSD?
- A new bloody problem!
- braking on a s2
- After 2 years i can't get it to start
- new car :) need help please!
- turbo water coolin
- my car going in Fast ford (hopefully)
