View Full Version : Ford Escort RS Turbo
- Induction kits ???
- strutbraces
- piston measurements need please
- HELP Running on 3 holding back!!!!!!
- how many mpg?
- turbo knackered?????
- Engine
- how to clean samcos please?
- Recomend me an alloy rad pleae
- Eibach springs for s2 escort rs turbo
- 1/4mile@14.2
- Turbo noise ??
- Baileys Breather
- Turbo oil leak
- Think im losing oil pressure
- Are S2 crossover pipes made of alloy?
- where can i get
- What way round do the brake pipes go on master cylinder?
- Uprated clutch question
- Looking for a new cam
- poor starting,any ideas?...
- RS Turbo Radiator dimensions
- why did god make the s1
- turbo help
- Why why why
- Piston Rings, Valve seals or turbo????
- Zoo Rear Brake Conversion
- where can i get
- who builds Low comp bottom end
- Valve bounce
- g300 s**, do you reconise this number plate??
- Oil leaking through the distributor
- series 1 and 2
- very mad with myself
- Front mount intercoolers
- whats the best way to do a 1/4 mile run?
- Abs
- crossover pipe
- what if
- Sierra 4x4 housing on an RST
- Just me!!!!
- engine oil
- Headlampwashers, option?
- whats the difference.
- Intercooler fans?
- Feels like loads of lag :(
- sunroof qustion
- focus rs wheels
- Will a S2 diff go in a S1 box?
- Wheel hub caps
- s2 rst Pinking on high revs
- Cheap alternatives to kenlow fans
- front brakes
- what size wheels on a s2, and what arch work?
- Suspension
- Electro Pressure Watzit on the Metering Head
- Best wheels for RS's???
- zvh oil filter
- pic request
- 1.8 Zetec - Suitable for Turbo'ing and putting in ERST???
- cossie management question
- Help Question
- rear poly bushes
- wheres julia gone?
- Piper springs
- Curborough tomorrow
- Best tyre size for 7Jx16s?
- Cam Followers!?
- help what goes where !!!
- series 1 crossmembers (mk3)
- Setting the Actuator ???? advice
- Rear brakes
- whos rs turbo stink when u give it some?
- Alernator problems now,HELP !!!
- How Much Oil Pressure Should I Have
- blue smoke
- s1 Rear Lenses
- any mk3s in portsmouth ?????
- samco-sfs color difference??
- Headlamp Protectors
- 17" Wheels on Series 2
- Mk5 clutch pedal into a S2
- Engine started first time,but now wont start........
- whats it worth? s2 engine
- turbo
- stage 1 box, which ratio s1/s2
- How much work/money to repair...
- 5th injector idea
- Uprated black hoses
- What sort of charge temps are you running?
- Most power made with a completly standard CVH Bottom?
- s1 in desperate need of a gearbox!
- clutch
- GAZ Coilovers
- HOW CAN I CHECK TO SEE IF MY KNOCK SENSOR IS WORKING??
- Fitted cossie brakes ....
- Hi Everybody!! (Newbie)
- What parts are the same for both s1 and s2?
- New Guys First Post
- Indicator problems :(
- RS mud flaps
- advice/experince bout high bhp rst
- Silicone boobs.... eh.. i mean hoses..!?
- Central locking stopped working :(
- Don't forget !
- Flamer Kit
- DIY single wiper conversion on S2
- what bhp will i be at
- s2 2 engine + box in to s1
- ATB LSD?
- new samco boost hoses, problem
- what oil to use when running in?
- Max boost on standard comp 1.8 ZVH
- Different driveshafts?
- Help Needed!! PLEASE
- any pics of rs turbo,s with esc cosssie rims on
- rsoc 25th anniversary
- Any one know this bad boy.....
- where from
- ABS removal, what kind of pipe fittings do I need?
- adjustable tca's
- fookin help me
- 5th injector setup
- calibra turbo pistons ????
- Inner TCA bush
- Focus side repeaters & cossie steering wheel!!
- Chip
- Head gasket.
- How many litres?
- black bumper trims for mk4
- turbo question .
- Priming that bastard turbo grrrrrrr
- As much info as i can get on EFi conversion please!!!!
- any one got a spare s1 grill?
- Suspension: help me decide..
- brake Conversions
- metering head question! update. *ggrrr*
- Complete Saph 2WD brake conversion on RST
- Pics please
- Which Brackets for Rear Disc Conversion?
- Amal valve clicking???
- Who out there is running a saph I/C on their S2 ?
- Gear oil
- Duration of RST standard cam?
- Sump gasket leaking very bad
- Cold starting problems
- chip tuning
- S2 fuel relay (pink)
- Does anyone know anything about my S2?
- Water Pump
- bit help < flocking >
- WTB
- black as fcuk in charge carrier&throttle housing
- Efi converion anyone?
- Welding my RST
- What suspension should i get for my ERST???
- few problems
- should i raise the compression???
- Electric arial
- Genuine Rs Engine Parts
- S1 pics.. how many left???
- S1 with S2 ECU, hesitating???
- non starter
- collets for rs7 spokes, what of?
- fao, CARL RST
- help... brake bracket needed
- fitting a fuel computer to xr2 rst
- CHEAPEST PLACE FOR STAGE 3 HEAD + CAM
- Pic request please
- North West RS Day anyone ? . . . .
- burton power rear disc conv kit?
- chassis plates?
- offset
- Leaking oil..!?
- Wiring loom
- am i sad or what???
- alloy strut tops
- Blitz turbo timer
- Fuel Computer & Electric mirrors Q.
- rear tie bar!
- 4 psi....plz help
- FAO people running ap clutches
- On a C reg Custom S1...
- Hot starting
- need a sprayer
- Is it best to.............
- abs removal
- INTERCOOLER SPRAY WATER BOTTLES
- dodgy injector [ yellow ]
- hybrid?
- HAS ANYONE HERD OF EDEN PERFORMANCE IN DONCASTER.
- buying first rs
- Cant start the car now
- What clutch should i get?
- worst luck in the world.....
- Bleed valve confusion
- What colour wheels do you think i should go for?
- coil?????????????????????????
- 800 quid for a tailgate :O
- manifold paint
- silicon hoses ERST S2
- chrome suspension tops
- ******cosie managment******
- intercooler change
- no igntion lights?
- Best Quote?
- Which hose kit for a FRST engine in an ERST shell?
- why would my brake pedal go rock solid while driving ?
- help needed, efi
- mongoose or ??????
- Electrical Problem with my lights!
- ABS Removal??
- Help needed
- what do i need to do to fit escos disk/calipers to my s2?
- dumpvalve?
- Where do you place your Act Guage Sensor
- Buying my first RS - Your help is required
- rear turrets on a s2
- Oil Pump Prime Question...Help Please!
- Silly Question
- Any 1, got any idea what im going to be running?
- Coolant Sensor
- Mk 4 bits to mk3
- wiring diagram
- my new manifold
- fuel lines diagram
- What Milage is you RST?
- finally got pics of ma car
- cvh to zvh
- Car refuses to idle
- S1 dash sensor lights
- fuel
- cold start up
- Esc cos wheels
- Felpro Headgasket
- Slipping Clutch !!!
- Intercooler Question.
- Pic request - S1 rear quarters on a S2.....
- Ford long range lamp kit...worth anything????
- Fuel smell and higher idle
- arch mods? coilover shocks?
- FAO: People with NEW Pro Alloy Cooler...
- new fuel pump and still no fuel pressure at injectors!
- Series 1 car cover?
- What Boost guage ?
- fcuking fuming now!!!!
- Should i lower my car 40 or 60 mm???
- car misfiring at 5500 rpm every gear
- Pic Request - Roll cages
- LSD Gearbox???
