View Full Version : Ford Escort RS Turbo
- Newbie
- Escort s2 drive shafts for focus rs conversion
- Zetec Alternator on ZVH
- Rs turbo suspension help please??
- Escort RST S2 Breather Mod Help Please
- fuel sender where can i get one, do i need one
- Mfi inlet
- where to buy quality adjustable tca's
- Exhaust hangers (S2)
- Exhaust manifold stud threads
- zetec manifold studs where from ?
- Engine Rebuild : 1st time Start Advice needed
- Roller needle rockers for cvh
- Looking for a 1990 s2 i had
- Whats the extra nipple for?
- hi I'm new
- rear spolier fittings for tailgate
- Boot gubbins!
- Double din
- Black top 2l Zetec Turbo on to RSturbo Box
- electric windows
- zvh engine with Efi
- rs turbo conversion
- rs turbo help
- Series 1 Rs turbo guru needed
- Which boot struts?
- s2 discs help
- does anyone run a twin plate clutch
- RARE bonnt protector??
- ABS light & battery light not working
- "Limited Edition" Series 2 interior.
- s2 air leak
- S2 injectors
- S2 project price help
- rocker cover gasket, cork or rubber???
- Is the t34 just a bolt in and remap??
- Mk1 focus rs engine in a S2
- Standard Radio cassette?
- Series 2 RST wanted
- To break or not to break
- Do i need my oil cooler?
- oil leaking through distributor
- mercury grey rst.
- Quick question, s2 won't start
- Pictures of your homemade big bore S2 exhausts
- s2 earthing points, how many and where
- sun roof
- Is this fitment normal?
- 283 or 300mm willwood brakes?
- s2 gearbox oil leak
- escort RST differences
- t34
- Steering wheel
- heater blower
- Where does this plug into?
- s2 seatbelt fitting, help
- Engine and gearbox change
- Which master cylinder to use with Focus RS box ?
- Liquid aroldite
- Cvh water pump...
- Silicone hoses!!
- Turbo retour into carter with EFI bottom end
- 2 simple efi questions
- Seats and roll cage
- Focus RS conversion
- S2 escort springs?
- G311 red s2 anyone know any history?
- sound deadening
- Bonnet stops..
- sport ka gear box
- Where to buy a single wiper conversion
- New S2 member from Italy
- Dave Mac Shafts for MTX gearbox ?
- Will a mk4 4 door escort roof fit a s2 RS turbo??
- Anyone know we're my old s2 is?e390lnr red with gold speelines?
- Electrical problem s2
- heated rear screen
- Anyone know the thread size for the screw in water pipe fitting on the rst inlets?
- Identify my turbo.
- Esso super unleaded, she'll vpower, tesco momentum
- Bit of advice please.
- Problem with dash/tail lights
- Having trouble with my lights
- Fuse box to battery lives
- South west or midlands rs turbo tuners?
- Has anyone made/fitted an adjustable rear?
- On the Dyno tomorrow....
- RS turbo valve sizes?
- Where to get s2 jacking point covers
- looking to swap my saph cossie for a s1 or pos s2
- standard ford stereo what to do with
- Autotint designs
- S2 sunroof issue
- Anyone own my old s2 cabby?
- Tailgate repair
- roll l cage
- Camshaft timing
- LOOKING FOR MY OLD CAR!! S2 turbo G23 GOV
- What servo and master cylinder for cosworth brake setup?
- Boost gauge reading?
- Escort RST S2 Rear opening Windows
- Airtec intercooler question
- standard or modified
- What do you use....
- Headlight
- boost monkeys
- Alternative to the rare spotlights.
- Rs turbo fuel senders
- Rs turbo boost issue
- EFi Troubles
- Pistons/ rods question
- rs turbo oil
- diff between s1 and s2 info
- Rs turbo wont start
- smoked fronts
- Drive shafts??
- Advise and opinions plz
- history
- what brake discs to use with mk3 mondy calipers?
- Advice please. RST S2
- RS TURBO S2 New member
- Red G849 JEY 90 spec s2
- Gear box identification
- mfi cold start
- Rst clutch help
- Current mods, and way forward.
- Need help with Zvh running
- Backfire
- Airtec turbo cooler
- decided to fit the 17s...
- Water in footwells
- B&M Quick Shift Removal
- mk4 escort 5 door rs skirts and arches wanted pls
- Mk5 pedal box will it fit?
- piston ring issues?
- help my s2 wont start
- New S2 collected :)
- Escort s2
- Mfi rich in idle, lean at load
- Slow seatbelt
- Going to view a S2, anyone know it.
- s2 opening rear quarters?
- Wiper stalk
- Rs s2 replacement rear arches, who can suggest a good supplier
- zetec head??
- Escort zvh is it ok
- S2 fuse box photo pls
- RS7 Alloys 17" Series 1 RS Turbo
- Quaife diff?
- piston question- help needed asap
- Oil question
- uprated fan switch - where from
- Zetec Turbo Headgasket question ?
- CVH blocks please read n help !
- Measuring voltage on ignition coil
- Mk3 Escort parcel shelf colour shade
- Does the rear wiper come on with front washer?
- post your grey s2's with aftermarket wheels, ones available in 16"
- Radiant Red Escort RS Turbo (Pic Heavy)
- Efi rs turbo starting problems
- Shes here...
- Interior light works off switch but nothing when doors open??
- RS Turbo brake conversion
- Standard suspension??
- Efi conversion show us your engine bays!
- Fuel pump
- How to remove cassette stereo
- No throttle response/engine cut out?
- zetec turbo inlet gasket best o to get ?
- Camshaft kit
- H130 kcc anyone know it
- rough running
- new servo
- do i need boost solenoid od EFI?
- Escort rs turbo s2 suspension
- 1st escort rs turbo
- 1.6 zetec conversion in mk4 escort
- headlining
- Exhaust
- F528 NLD pfben/marky-g's old rs turbo
- Master cylinder
- Exterior elements
- Identify engine
- zetec turbo oil return and oil drain from breather..
- Silvertop looms
- 17s to fit/ suspension
- Trying to track down 2 rs turbo's
- escort rs turbo ??
- Oil pressure guage.
- braided brake and hydraulic clutch lines what size ?
- FAST FORD Magazine - Readers Cars
- Escort mk4 front panel/lower section
- Restore RS Turbo or Reshell
- Limit of a standard Cvh?
- What do I need to do to a 2.0 blacktop for it to bolt it?
- RS Turbo on eBay
- IB5 and S2 LSD????
- Possible fuse board problem? ANY HELP WOULD BE REALLY APPRECIATED!!
- another electrical problem
- What ampage wire for fuel pump
- smokey rst
- Easy way to change radiator RST?
- Anybody know much about mk5 xr3i engines?
- its hard to believe the mighty s1 will be 30 next year
- no spark???
- S2 help
- Rs turbo
- Hydraulic clutch
- St170 billet flywheel
- G401 YAN - F622 KCU any info on these two cars
- Alternator bracket bolts
- Rs turbo s2 dimensions
- RS Turbo G659 JDT
- Viewing erst tomo
- RS Turbo H969 DPP
- Series 2 prob, need help
- Red s2's wheel colour?
- my beasty
- Best place to buy an oil pump
- mtx clutch?
- Devil Development Valve Springs for Silvertop Zetec Turbo
- mk3 rad fid into mk4
- Escort MK3 Parcel Shelf
- Overheating
- compomotie mo1675 or escort cosworth wheels
- Rs16i head
- Series 2 uprated rad
- OddKidd Creations Address
- Escort RST smoke issue please help!
- Getting Escort RST up to 200bhp
- Newbie with two RS projects
- Stuck on engine choice for mk4 project
- knocking/clunking driveline.
- Roof S.O.S
- wiring loom
- e581 jle
- show me your show cages
- cvh block
- Rear Disc Brackets??
- S2 master cylinder
- RS Turbo Tuners - whos best?
- side exit vs conventional exhaust systems
- Help needed
- Forged 1.6cvh or ST170 ZVH
- Series 2 escort bolts MISSING !!
- another mfi to efi question
- zetec turbo ignition leads best ones to use ?
- thread size
- Difference between bike carbs and throttle boddies??
- turbo's!
