PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 [89] 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. just wanted to no who see my car in fast ford readers sectio
  2. are s2 calipers m16's ???
  3. electrical probs.....HELP
  4. escort cabs help
  5. STEERING WHEEL SHAKE
  6. electronic boost controllers
  7. fuel relay
  8. what 17" wheels for a series 2????
  9. Anyone here own G529 VTW Red S2.
  10. North East Tuners
  11. Am i doing any good if i....
  12. Welding new panels on?
  13. fuel relay
  14. Hot start probs and blowing white smoke
  15. REMOVAL OF BADGES??
  16. vernier pully?
  17. GATSO
  18. uprated breather?
  19. gearbox rebuild
  20. how to ruin a rs turbo
  21. OIL FEED PIPE
  22. do you use different plugs on a zvh?
  23. RST fuse - fuel enrichment/cold start
  24. show me your re trims
  25. What the best way of cleaning a CVH head?
  26. oil dipstick pos??
  27. 2.1 ZVH
  28. Problems with starting the RS!
  29. newbie here. here's some photo's of my s1 cab
  30. Oil Pressure Gauge....
  31. help with me brakes
  32. garage set fire to my erst
  33. REV COUNTER CAN ANYONE HELP ?????
  34. Turbo to manifold nuts
  35. Wanted: Pics on RST S2 with 16"
  36. no hot air from heater
  37. Brakes
  38. whats going on
  39. S1 Bodykit Partnumbers
  40. S1 wheel size help 7.5 x 16ET 28 4 x 108 do they fit?
  41. What wheels???
  42. WINDOW RUBBER??
  43. Gearbox for sale+++THIS IS NOT AN ADD +++++++++++++++++++
  44. should my clutch be slipping?
  45. Series 1 Windscreen Wiper Speed Control Knob
  46. Series 1 Engine Felt Aluminium Foil
  47. Which do you prefer?
  48. fuel filter fuel flow
  49. rear washer
  50. Mystery box. What is it in engine bay?
  51. zetc pistons? bore size? makes?
  52. Correct Brake Fluid Reservoir For ABS Removal
  53. White 'H' Plate RST needs valueing....
  54. REAR SEATS??
  55. best oil?!?? i'm confused
  56. FAO all s2 rst with cossie intercoolers
  57. WHAT INTERCOOLER??
  58. GAUGES????????
  59. COOLANT CHANGE??
  60. S2 ERST NEW DOORS
  61. OIL DIPSTICK????
  62. ERST RIM REFURB??
  63. clocks
  64. how do u fit a pace double capacity intercooler to a s2 rst?
  65. Check out this interior
  66. best oil to use
  67. misty inside
  68. thinking of selling the s1
  69. My Escort Turbo Powered Ka
  70. Tubular manifold
  71. FAO r-s-turbo
  72. oil return pipe from turbo
  73. how wide are the runners on recaros
  74. wanna sell my car and get a real turbo not a replica help
  75. Mapping
  76. accralites
  77. Best exhaust for S2 RS Turbo ?
  78. s1 kit?
  79. S1 seat cloth
  80. Oil Question.....
  81. FLAT BATTERY
  82. carrier bolts
  83. newbie, pics added
  84. Brand new series 1 - NOW WITH PICS!!!! - at last....
  85. gearbox specially for the mapping r/r
  86. MK6 Escort GTI TURBO on EBAY
  87. oil temp probe fitting
  88. Front bumper
  89. Filler cap barrel
  90. engine and loom transfer
  91. interior light flashes when braking!
  92. s2 flywheel on to s1
  93. Gearbox Question
  94. escort rst turbo wheels
  95. Best front suspension/ arb
  96. where can i get a new cozzy loom.....
  97. urgent! alloys on escort rs turbo 4x108 et38.
  98. CLEANING ENGINE BAY??
  99. CLEANING CLOTH RECAROS
  100. ROOF RUST
  101. s1 bumpers?
  102. Mfi to Efi --The block
  103. help needed before a murder is committed
  104. GRS INTERCOOLER WILL THIS FIT?
  105. series 1 i,m thinking of buying
  106. Escos wheel fitment?
  107. S2 HEAD LIGHT PROTECTORS
  108. Normal Escort model and an RST
  109. Whats the Best intercooler for S1
  110. Charge pipe
  111. Power
  112. My first ERST!
  113. NOISE FROM ENGINE!!?!
  114. BOOT RELEASE??
  115. how much are these from ford?
  116. mk4 dash???????
  117. How do you fit an ignition module??
  118. 2.0 zvh compressiion ratios???????????
  119. Wana run my engine but....
  120. CLUTCH SLIP
  121. Cambelt Cover: Do you have one?
  122. NEW S2 ERST NEW DOORS???
  123. WHAT FUEL??
  124. CANT GET INTO BOOT!!!
  125. More Problems :(
  126. my s1 in febs performance ford
  127. One of my Christmas pressies...
  128. series one im very interested in B950ABW
  129. 1989 RST spark plug gap
  130. Door card `90 Spec
  131. s1 arches on van?
  132. how do i remove filler?
  133. Couple of minor problems
  134. Custom Inletmanifold
  135. HEAVY STEERING????
  136. S1 spotlights,
  137. is a 81mm cvh block is over bored??
  138. rs turbo heads are they the same as xr3i
  139. cant touch this.......
  140. check this item number out on e bay 4602094265
  141. Found this! duno y the army is in it??
  142. Pic of zvh conversions and inlet manifolds
  143. Immobiliser/Alarm Problem
  144. Stupid question
  145. what turbo ?????????
  146. wilwood calipers
  147. £17,500 S1 !
  148. zvh engine mount
  149. New Speakers
  150. engine parts
  151. whose got aftermarket mangement recently?
  152. roll bar plates
  153. Help Eagle con rods
  154. Tappet???
  155. More oil to no1 tappets
  156. Interior Pictures ( Seats and Dash )
  157. cold start valve
  158. mint series 1
  159. chrome bumper strip?
  160. Cossie Fuel Pump On An ERST.
  161. rocker cover question
  162. s1 best offset
  163. roosemotersport hoses
  164. Will I loose bhp by doing this???
  165. DESPARATE HELP NEEDED!
  166. Starter heat shield
  167. whinning
  168. battery
  169. COILOVERS ON MY COMBI
  170. Turbo
  171. Price anyone . . .
  172. my series 2
  173. WHAT SUSPENSION SET-UP?
  174. Big valve headm, were from?
  175. CVH water pump
  176. Restore, Break, or sell
  177. ???? HOW MUCH BHP ????
  178. Fule Pump
  179. What should oil pressure be?????
  180. my escort van rst have a look
  181. FITTING FIESTA RST MANAGEMENT ON ESCORT RST
  182. BUYING AN RST
  183. How much is she worth
  184. bonnet raisers
  185. boost gages
  186. after market water temp gauge and fitting kit?
  187. 2.1 zvh running hot!!!!!
  188. removing ABS
  189. oil light
  190. S1 sunroof question
  191. s1 and s2 turbo's
  192. perspex
  193. Blitz Turbo Timer Instructions
  194. Door card
  195. SUNROOF
  196. me dash
  197. Sierra 2.0 Engine - ZVH
  198. Wiper fuse keeps blowing
  199. Blitz Turbo Timer
  200. Stage 1,2,3 turbos
  201. ABS light
  202. escort rs turbo grey f68 yon
  203. what to do zvh or cvh
  204. Removing a bottom end/Gearbox, Got a prob tho..
  205. new raisers dont now if i like them
  206. ESCORT RS TURBO POLYBUSHES
  207. Rs bumper extension
  208. help need with some bits on my s1
  209. turbo water hoses
  210. hearts and diamonds
  211. mk 5 bumper on a mk 4 !!
  212. water leaking?
  213. fuse box pic
  214. WAXOYL
  215. ERST Ignition Coil, Will it fit a...
  216. Crank Position Sensor
  217. Precautionary measures????
  218. lowering & Abs
  219. RS steering wheel!!
  220. Fuel tank
  221. my xr3
  222. cossie wheels and lowering?
  223. Small number plates
  224. INSIDE DOOR HANDLES
  225. Rs kit
  226. Worrying noise from the rocker......
  227. car wont start
  228. escort mk6 turbo convertion??????????????
  229. PROBLEMS!!!!!!!!
  230. My S1 featured in RALLYE NEWS
  231. The ERST fuel mod????
  232. Opinions pleeeeze . . .
  233. warning light??
  234. Next Step - Advice Wanted
  235. zvh pistons from yankeeland
  236. Metering Unit
  237. 220-240bhp
  238. cosworth brakes
  239. ERST starting problem
  240. Bro's RS cutting out
  241. low lowering springs needed, help
  242. Fitting front poly windows
  243. ZETEC OIL FILTER
  244. alternator drive belts
  245. this abs removin malarky
  246. single wiper conversion
  247. ZVH advice
  248. My mates xr3 turbo!!!!
  249. ebay turbo
  250. Spotlights
