- help!!!?????
- B&M quickshift-anyone have adverse effects from theres?
- waste gate solenoid
- FAO Tony Turbo
- FMIC or chargecooler ???
- rs 200 wheels
- kenwood speakers
- stage 2 advice?
- Efi
- show your pics of s2 with s1 body kits
- Advice needed
- what camshaft?
- 8"x17,s on S1
- compmotive mos in black?
- Advice needed please
- Focus RS brake brakets
- post your pics of your escort on 16" diamond cut rs 7 s
- not starting
- CVH are ZVH
- power engineering system 2 engine components?
- GAZ coilovers any good?
- rs v evo race........ who wins?????
- Prices
- BEST SUSPENSION FOR A ERST S2?
- Metering Head
- fiesta dails in a escort??
- removeing ABS
- What they like chipped?
- T3 turbo s1 /s2
- Settin up Adj. tca's....
- rs turbo brakes???????
- Few Things
- Surround???
- ADJUSTING TENSION ON CAMBELT???
- i hate konis and need help
- Why are they notoriously crap for traction?
- SERIES 1 GEARBOX!
- Dipped beam not coming on
- FAO People with Cosworth Steering Wheel (with pic)
- What power to expect!
- WHY A 3" BORE EXHAUST???
- PEDAL BOX FOR MY MK3 ESCORT?????????????????????
- s2 boot install pics
- power steering into s2 rst?????
- strering wheel bushes i think ???
- Need a parcel shelf for Series 1, Do mk5/6 fit?
- METERING UNIT
- REVcounter stopped working
- s1 can you still buy sensors new
- which relay
- s2 radio signal
- back with starting problem
- value how much
- R THERE ANY ERST PEEPS IN SWINDON??
- Bosch Alarm
- brake Problem On S2 RS Turbo??
- Induction kit or pannel filter on a series 2????
- Exhaust Gasket???
- 1/4 mile times
- FAO Safechav
- best stainless exhaust for a erst s2?
- s1 rs over fuelling
- s1 turbo towing eye cover
- white crap on my dipstick
- Do fuel additives work ie octane booster etc
- Im struggling to keep it standard!!
- Low compression do I need it
- ZVH oil breather help please
- More problems ........
- fitting mtx75 box on a rst s2
- wat clutch do u lot thinks best
- Dump valve query....
- what should my erst be charging at?
- ERST AIRBOX..WHAT BOLTS??
- zetec lovers
- help on next mods for my s2 please
- REPLACING BONNET CABLE??
- Engine price?
- s2 non custom
- Lack of oil pressure (another problem)
- KnN FILTER
- ADJ ALTERNATOR BELT??
- Cam choice???
- all paddle clutch users
- Ran out of petrol
- lowest value on a s1
- Value My RS
- oil what kind ? my first s2
- Starter motor prices...
- oil temperature question
- fitting 17'' wheels
- Engine managment
- ESCOS WHEELS ON A S2 RST
- rs500 intercooler in a s1
- converting xr3i efi loom
- fuel computer
- Gearbox question?
- escort cab screen
- my oil light dont light up no more, LOL
- Turbo pre filters- Anyone run one
- Boost Question ????
- gearbox removal
- battery warning light???
- rs turbo brakes
- RS Window Decal
- Boost gauge facia.
- HANDLING??
- Fire Extinguishers
- WHERE DO YOU SEE S2 VALUES GOING
- will s1 springs/shockers fit my s2?
- STEALIN AN RST!!
- Whats best? s1 or 1600i arb?
- Fuel Metering units
- Lambo Doors
- help please on my s1
- Front cross member suspension mount
- Diamond cutting
- s1 at field motorsport
- erst2
- erst series 2 help needed.
- strenthing a bc box
- Cossie brakes
- Boost problem...
- boost preasure
- series 1
- Seat covers
- Fcuk! - Neigbour been Car Jacked!
- Pic request - Lowered Mercury Grey S2 on Black S2 Rims
- WHATS WRONG WITH MY RST
- Fookin Rs turbos!!!!!!!!!!!!!!!
- bottom boost hose
- adjustable tca's
- Bodykit Price
- Ringer ?? You decide...
- how much will it go for??
- S2 idle when cold
- Genuine Series 1 Windscreen Question. Which one can U help?
- overheating
- PICS WANTED
- BSW Intercoolers
- Exhaust question
- Why do i have a pipe from the pressure regulator in manifold
- What Alloy Rad?
- What Rolling Road would you recommend
- SERIES 1 STARTING FAULT
- fuel mods!!
- crank quastion
- running problems
- s1 arches and s2 side skirts?
- lookin for a s2
- front bumpers
- Bonnet Badge
- G200TYL (old CAR)
- Can an xr3i loom be used for OFAB management
- do u think i will get 200 bhp?
- diesel clutches
- Recaro badges
- Fuel Leak
- Intermittant starting problem.
- strongest rs turbo clutch
- Boost gauge Question...
- steering column bushes
- how much for cossie managment
- Anyone using or tried a volvo intercooler
- is there any demand for brand new headlamps?!
- 8.5 second qtr mile @ 173.5 mph . omfg
- pistons
- Delocking a s1 yes or no?
- BHP RS
- My first ford, factory standard ERST (Pics)
- roll cage
- whats the most SUITABLE clutch for a 220 bhp escort
- Help needed
- twin plate paddle clutch
- OFAB and OFAC whats the difference
- adjustable TCA's
- Escort RS turbo Throttle Position Sensor affect cold start?
- any rsts for sale round yorkshire"ish"area
- IN THE REALISIC WORLD,WHATS BETTER ZETEC T OR CVH???
- STEERING WHEEL SHAKE UPDATE!
- Efi Mk4 H reg Petrol Tanks??????????????????????
- EAGLE Steel rods for zetec turbo??????
- Hard to find wheels needed
- does anyone have a rust free n\s door for a s2?
- boost prob????
- in car boost tap
- PROBS AFTER CLEANING ENGINE?!?!?
- HOW RELIABLE IS URS
- What is the benefit of having a trimmed compressor wheel?
- ABS STANDARD???
- ABS LIGHT IN DASH??
- FUEL PUMP NOISE??
- new problem
- 88 spec recaros and 90 spec? Difference?
- rev limiter
- head set
- Rs sideskirt rail
- what rims
- Turbo technics say i must have a D/V, ideas please?
- cold start
- OVERNIGHT PARKING??
- S2 OUT DOOR CAR COVERS
- water leak
- dodgy under breaking
- Questions need answers for ? Please
- under bonnet pics
- 1.9 conversion for s2 i need help
- rs turbo piston rings
- ZVH
- Bumper insert
- thinking about buying this what do you think please
- Which breather?
- S1 clear indicators and no spots
- bottom end rebuild
- G213 NKP
- s1 washer bottle
- S1 and S2 engine stickers on ebay
- cold start vavle
- Who using cossy Man?
- which intercooler
- series 1 or series 2
- low compression
- series 1 front bumper
- bhp?????????
- Pics of my Series 1
- what is this wire?
- Calpiers ReFurb
- flushing heater matrix
- Revlimitet - on the MFI
- Eagle rods, with Zetec 1800
- CAR BATTERY
- ZVH
- fao kossie !!!
- F*ckin sunroof
- Silly Bumper question (Mk3 & Mk4 Escort)
- Vibration through wheel
- Buggered RST Engine
- washer bottle
- FORD POWER AMP WIRING
- Kenlowe Fans
- fitting a t 34 to a s2 rst ???
- snapped a trailing arm
- Series 2 Sump
- Performance gains by MoTech?
- STEERING COLUMN BUSHES
- Cossy Man (crank sensors)
- White spark plug ends
- SPAX SHOCKS?????
- motorway driving = clutch slip
- Golf Gti
