- RST Register
- Vulcan Valves
- What power do you think this spec would make
- Best oil for S1 (again)
- Free to a good home!
- G443 GWN
- Can anyone tell me what. . .
- Ebay bargain Cam!!
- Angle grinders what fun
- E989UTJ seen/know of/own it???
- Pro Alloys s2 Turbo coolant cooler...
- What do you people think
- Air Leak
- 90 spec bumper - modifying centre vent
- diesel gearbox an which clutch for my s2 ??????
- mfi into efi escort
- please find
- Wiring diagram...
- Who owned this S1, C201HON
- Problem changing clutch cable
- are ecu's interchangeable
- What Boost do you think I could run?!....
- what are the best plugs for a rs turbo
- CLUTCH ADVISE NEEDED
- FAO James Raby
- Honest opinions please on candy s1
- My dash *warning- naked lady bum*
- D590 EPO
- Tony what piston was this?
- cost of engine rebuild
- custom- non custom
- ARE THEY THE SAME??????
- please find this car for me
- 2.0 16v zetec turbo vs 2.1zvh
- ignition problems, plz help
- opening rear quarters
- injectors?? s2
- act thingy
- spot lamps
- pics of s2's in winter??
- Can an S1 passenger seat fit drivers side.
- how much play should the shaft have ?
- 2.OL ZVH/ FOUND OUT SPEC FINALLY
- rusty front wing :-(
- goodridge hoses
- GRS coolers on S1
- B245 SDF & C510 DYD
- distributor
- Why do people fit Diesel Gearbox's to RST's?
- Rs Turbo Sensors and wiring etc...
- Deary me!
- THANK YOU MR KARL NORRIS
- charge air temps
- Glowing manifold and turbo???
- What is the blue plug just below the dizzy??
- temperature guage keeps going up and down....
- Anyone had to replace....
- Do Bilstein...
- Boost gauge pod
- 16" tyre size?
- Well its gone.......
- Wheres the best place to get...
- HELLLLLP!!! I neeeeed seats!!
- MY Silver ERST-at night... NEW PICS IN DAYLIGHT!!!!!!!
- turbo boosting 2 psi ???
- E59 FFL-anyone know it?
- s1 Back lights
- cvh flywheel?
- oil cooler
- rear calipers
- help with front mount cooler
- Dodgy Turbo?
- 2.1 bottom end
- kiddies car..............
- piston,rods crank!!!
- Brakes on a S1. FAO Tony Turbo
- rst need help
- Centre vent heater control pods - help please
- when using a decomp plate ??
- tyres for 17's
- exhaust gasket
- help!!! ecu needed asap
- Been busy today
- right, how do i do this puma gear linkage???
- S1 Boost Hoses
- what brakes for my s1?
- Series 1
- Brake master cylinder repair kit
- S1 S1 S1 S1 S1
- running on 3 cyl..(help)
- Help :o(
- is it really worth it ???
- whys it doing this now???
- Steering
- Cylinder head work?
- BRAKES
- Hydraulic lifters
- HOW MANY RS TURBOS SUFFER ROOF ROT??
- TRIMMING STEERING WHEEL SHROUD??
- ADJUSTING HEIGHT OF FRONT BUMPER
- best place to get ?????
- What Battery?
- Zetec conversion
- what brakes for my series1
- Steering column bushes
- how much and was it worth it?
- DUMPVALVE PROBLEMS????
- FAO: Passionford resident Craig David impersonator
- wot is needed to convert from mfi to efi for my cabby
- I want a softer ride!
- what brakes
- FAO: Tony Nuts Rus
- oil cap
- how too.....
- front suspension
- gauges!
- DVD screens
- 90 spec
- my s2 rs turbo
- Help!
- Zetec Inlet
- Brake pads?
- looking for any former owners of G300 SUD???
- S1 parts??
- rst gearbox poping out of gear
- FITTING 17's PROS AND CONS????????
- S1 spot lights
- recaro seats wont fit!! HELP!!
- HELP. Speed signal and RPM signal
- ava
- tyre's
- check out the speed of this animal
- problem
- Rover M16 Inlet Manifold Question...
- brakes
- snapped head bolt , how to remove ?
- Heated rear screen connections
- Turbo Timers
- FAO: James Raby
- Azev A's
- inlet manifold
- RS TURBO NEED HELP!!!!!!!!!!!
- clearance problems on rear of s1
- EFI
- BRAKING...
- FAO: Julia
- braking
- Anyone know where i can get...
- DOOR POPPERS
- escort rs turbo clocks
- clutch pedal
- mk4 escort adjustable roll bar setup
- heated screen
- Running problems
- FAO Tim
- wiring diagram
- Series Two Picture Database
- Pictures
- inner rear arches
- Tuning help!
- bodywork on s1
- what oil should i use in my series 2??
- screamer pipe
- ABS removal hoses......
- chatter
- Choices choices choices
- G883 WWC
- cooling issues
- series1 backlights
- New wheels for our S1
- ??? Konis or Coil-overs ???
- BOTTOM CAM BELT GUARD
- live mapping in scotland
- S2 arch guards onto a S1
- B69 AOL
- s1 offsett
- bonnet lift
- turbos
- rear roll cage dimensions???????
- insurance
- Time / Clock
- NEW T3/T4 FITTED (PICS)
- not good news!!!!!!!!!
- My RS
- water seals on a pillars
- rebuild or find cheap motor ???
- What wheels for S1
- series1 leak?
- s1 turbo on s2
- Tuners ,Rolling road in Kent?
- bad news!!!!!
- 17" BK 166 Alloy wheels on a s2??
- tonight i mapped my own car
- s2 door/boot seals
- spec r header tank
- Anyone know of my old s2
- Adjusting the metering unit
- Where can i get my turbo reconditioned???
- What size silicon hose
- Identifying -31 and Chipped ECU.
- the s1 might have to go
- Measuring ACTs
- 17x8 on series 2??
- running lean???
- Gotech Management...
- power
- does this look like a Piper camshaft??
- Cossie management
- help esrt s2 not starting????
- S2 90 spec brakes
- NEWBIE
- gearbox or clutch?
- black rs on white compomotives
- Series1 wot mod next
- cam kits
- FINIS coce required please, any one know?
- ABS REMOVAL
- boost probs
- right...
- chips
- Hi my RS S2
- Whats it worth ?
- Mk3 Cab to Turbo Conversion
- Oil pressure ? Question
- car pulls all over road when on boost
- 2.1 questions
- Help.....Needed asap!
- Just won this.............
- Brake master cylinder and t-connection thread size
- Places for a new/re-conditioned standard t3 for an S1?
- parts wanted
- Rocker Arms
- 1800 pulley and CPS
- Newman Adjustable Tappet Settings
- quaife A.T.B
- my new rst
- Help with alloys header tanks
- Opinions......if you please
- What's the best direct fit intercooler for my s1?
- Cosworth brakes on a S2
- knock sensor
- ROT
- Best place to get arch repair panels???
- Fitted boost guage, now dump valve is delayed?
- parcel shelf
- Fitting a Pro Alloy Intercooler
- ZVH Engine management
- 2.1 ZVH Build.....parts required....
- Some Pics of my new S2
- correct offset for erst??
