- s1 rst bodykit wanted
- cam belt cover
- Duratec is in :)
- anyone useing c20let pistons on here in there zetec turbos?
- amal valve
- fuel and brakelines(EFI)
- Steereing column change
- Classic insurance. . .
- Crank oil seal
- cars just bn written off!!
- ADJ TCAs PROS????
- zvh engine mount
- Final drive ratio
- EFI Conversion on Escort Rs turbo - help!
- Fuel Mixture Screw
- 2 STAGE BOOST ISSUES....
- Breathers!
- Just pulled the RS out for summer
- AP 4 PADDLE FITTED AT LAST
- Data post s1
- MPG after chip
- S2 BREATHER
- D309 UJN
- done a little work on the car
- clutch help need to buy one soon help please
- Looking for a Black S2 for someone - D452 DMS
- gear linkage
- cossie injectors
- RST help urgent
- FAO: RICK
- Car Info
- Problem with Brakes!
- QUOTE FOR SPRAY WORK.....
- S2 RS Turbo Advice
- diameter of samcos
- Who has drilled their block to take a CPS?
- Fuel Pump bracket/hosing on a Series 1????
- Removing ABS
- popping
- best way...to clean calipers
- anybody know this car
- why are these different? which is best?
- engine help
- Few pics of my car
- series1 custom or not?
- erst to efi
- *GROUP BUY* MEF MOTORSPORT ADJUSTABLE TCA'S
- ARRGHHH! which plug champ c57c or c59c!?!?
- erst s2 clutch cable probs
- Headlights (Not working)
- SOME PICS OF MY S2ERST......
- series one decals
- MK5 clutch conversions
- where's the best place to get hold of a recon dizzy??
- Non Starter
- Turbo service kits on ebay
- Beware! Series 1 for sale...
- group buy for adj TCAs?
- how do u adjust your gear linkage????
- Stud Conversion......
- project uncertain now :wall:
- Clean and Tidy Engine Bays
- mercury grey s2????
- POWER DELIVERY DIFFERENCES CVHvZVH???
- FITTING STRUTBRACE?????????
- Tyres!! A question for the techies!!!
- Oil Recommendation
- help
- nasty dent on bonnet
- Nomad A Pillar Gauge Holder
- fiesta rst loom for EFI conversion
- S1 & S2 headcloth
- S1 pics please.....
- help sealing T-peice in coolant hose
- gear linkage
- is it worth getting a paddle clutch?
- anyone ordered there zetec turbo pistons and rods from usa?
- My New Rs
- cossie fuel pump
- 2.1 zetec
- RST Wiring...
- S2 engine fooked......
- Found pics of my silver ERST when it was standard bonus!
- Help, would really love to track down my old car ...
- Anyone know . . .
- clutch pedal making funny noises
- bigger brakes question
- Will a Cossie oil breather fit my RST?
- "WoW" You must see this!!!!!!
- rs turbo fuelin problem help
- help, car won't start!!
- bleeding brakes????
- RS Turbo or RS2000?
- Sticky wipers
- s2 fuel pump? not fueling?
- no spark?
- battery cable
- S1 Stu @ MSD do you know this car? B68 RFD????
- WHATS THE BEST OIL FOR RST
- anyone got any momo arrows for a s2 17 inch
- GEAR BOX ISSUES HELP NEEDED
- steering rack
- Interior Carpets????
- What Gearbox and clutch do i need?
- standard cam
- Headlinning
- escort cosworth calipers
- I've decided
- best cams? soz prob ask 1000s of times
- 10k boost
- how wide between strutt tops in the rear
- cleaning power engineering silicone hoses?
- Crossover pipe fixings(PIC) where from? UPDATE NOT FORD!
- polybushes
- brakes on s2
- radtec cooler
- Smokey & The Bandit
- brakes dont work
- what springs?
- cheap ford parts online
- best tyres? Eagle F1's?
- GRS removal!?!?
- spark plugs & HT leads
- standard cams
- Does anyone know..........
- pic request plz
- what bore vacume hoseing?
- electrical problems
- SCS IN PETERBOURGH (HARVEY GIBBS)
- 2wd cossie brakes
- D309 UJN(mercury grey S2)
- S2 styling
- front n rear windscreen
- holding back
- I've gone to the dark side.....
- erst s2 mk5 pedal conversion
- Thread and length on front caliper bleed screw
- OFAC v OFAB
- rad and intercooler setups series 1 ???
- hall effect sensor
- Can you still get.............
- Pics of S2's on 16's
- FLUSH FIT BONNET PINS
- I can't decide
- WHAT HEAD GASKET SHOULD I BUY
- Pic Request Of Merc Grey S2
- S2 gearbox
- Gauges
- Pic Request Of Merc Grey S2 With Non Standard Back Lights
- flamer kits
- question rst
- Cosworth management....
- turbo boost
- Possible turbo problem????
- paint
- SPOILERS
- BRAND NEW COSSY [ ESCORT ]
- ignition modulator
- Which Dump Valve???
- rs steering wheel for a s2 with no horn
- fueling for over 200 bhp
- HEAD LIGHT SCOOP
- Ebay D plate S1
- How much oil?
- oh crap...!
- S1 side indicators
- most bhp on standard chip?
- Trackday tyres....
- efi convertion
- WIPERS
- STARTING PROBS
- 90spec and seat splitter pics
- * NEW S1 GRILL'S * now have another 20 in stock!!!!!!!!!!!!!
- My car looking a state! :cry:
- Mahle Pistons
- Buying sills
- Whats better for 250bhp, cvh or zvh
- FITTING ESCORT COSSIE RIMS??AND PICS PLEASE
- REALLY REALLY REALLY HEAVY STEERING???
- GEARBOX "BLOWING UP"?????
- Removing ABS (scs) system on series 2
- rs turbo cabs, vans combi's, estates etc
- cearbox or clutch?????
- focus rs brembos on my S1 ?
- fan behind radiator?
- tubular manifold
- GEAR SHIFT
- Sump Gaskets-which ones best?
- Is it worth going low comp?
- stainless bolts!
- front mount intercoolers on s1
- looking for some ideas on engine bay detailing
- where can i
- help with brakes
- Help Needed ASAP
- Convert cossie loom to fit mk4 escort
- DESPERATLEY NEED YOUR HELP !
- anybody seen my old turbo?
- Meatering Head on S1
- Whats the perfect offset for aftermarket wheels for an RST?
- front mount for s2
- radtec coolers
- original wings and bonnet
- strut caps!
- brake hose's
- my old rs turbos are....
- cams
- rusty arches
- my new s2
- Swirl Pots......Yes or No
- Newman cam timing....
- Taking oil cap off
- question about co screw on metering head HELP
- recaro wieght
- how much is YOUR insurance
- Too young too buy???????????????
- video AND question
- 17 rs7 alloys
- will they fit?
- Wire rung
- had my s1 about a month (what do you think)
- Pro alloy front mounted intercooler
- Anyone know where this beast is now??
- Diff Bearings
- Need an exhaust housing where can I get one from??????
- Fuel fitting for a bosch injecter
- Boost question
- RS turbo conversion Mk4 to Mk 3
- MEGASQUIRT MANAGEMENT SYSTEMS
- Cold start problems!!!!
- 8:0:1 compression ratio (is this suitable)
- HELP!!-just changed sump gasket, now RS wont idle !
- What spoltights for S1?
- FITTING SPARCO STRUT BRACE???
- black bead for bumper....... ?? [ where from ]
- Where's good for HT Leads?
- compression ratio
- e47lrw grey series 2
- Excessive heat
- Master cylinder
- seat splitter??
- Can someone recommend a clutch that lasts?
- G555 GWP
- tuners in north east ???
- rust eater thingie
- Stage 3 Turbo
- S1 RS Turbo Spot Lights
- S1 RS Turbo or a 3 Door Serria Cosworth?
- pic request plz
- coilovers but what make ??
