- My new project...
- Roof skins
- s1 dash lights question
- solids lifters
- My RST - Pics at last, what do you think?? 220BHP on Gotech
- WHEELS STILL RUBBING
- in car boost control
- ZVH pistons, cheapest and best pls
- More Sunroof help please!
- s1 arches
- rear boot original Rs Turbo stickers?
- part numbers
- Steering column bushes
- cossie 4x4 calipers
- rear disc conversion
- radtech fan placement
- fuel gauge bouncing
- temperature gauge not working
- OVER RUN
- RST S1 MC-Rallying Bodykit quality question.
- Changing inner sill!
- fuel pump
- Can any one help !!!!
- how old was u??
- Please please help, im really desprate.
- ecu chip and cam??
- Mot
- Sunroof refitting
- FAO radtec intercooler owners on s2
- lowered my s2
- anyone got one of these?
- rs turbo handbrake
- MFI to EFI............
- scraper seals (weather strips)
- Mk3 heated mirror?
- advice on tunning escort rs turbo
- Carbon bonet for mk4??
- Central locking mota
- S1+S2 bits the same?
- my S1 is Naffed!!!
- starter heatshield
- Fitting a strut brace
- green relay on efi loom
- When s2 are chipped
- S2 gear box top up/ and price for rebuild
- cam bearings
- Front splitter
- boost drop
- Roose hoses
- Radtech Front mount
- mf2 injector driver ?
- Im stupid replaced bleed valve with boost controller Dohhhh
- Difference in engine mounts??
- crunchy reverse s2
- fuel filler
- help 2!!!
- Collins -31 Actuator's
- Series One rewire
- efi change
- K reg is this ture????
- Chrome Header tank...
- Best place for rods and pistons
- strange problems with boost on my s2!!
- Got my first rs
- Master cylinder size?
- My New Bling GRS
- part number help/SORTED
- efi inlet manifold
- Dash board
- idle...
- Series One Rs Turbo Decals
- fitting oil pressure gauge
- looking at buying this
- Taking engine out...
- S1 rev problem
- running in...oil pressure
- I need to repair my scuttle
- pillow post
- recaro question
- BIG PROBS NEED HELP ASAP!!!!!
- polished charge carrier
- S1 Calipers
- Rev counter stopped working on Series 1--Anyhelp
- help!!!
- central locking
- Fitting rear brakes
- worn cam causing misfire?? help
- wilwood brakes
- Genuine ford stainless exhaust ?
- fuel pump problems
- TICKING/ SCRAPPING NOISE FROM REAR HUB, DRUM BRAKES
- Indicators
- Please help fitting my pace intercooler to my series 2 turbo
- What is this?
- whats this then?
- inlet manifold gasket changing
- BYE BYE CANDY S1 PROJECT
- ZVH OIL PUMP
- failed its mot
- fancy being in the passenger seat?
- electrics
- Are these fixed rate compensators?
- ZVH Pistons
- Recaro
- help with starting my car please!!!!!
- cheap top end gasket sets at Halfords!!!
- for those wanting metering unit part numbers....
- EFI conversion
- What are these?????????????
- FRST & S1 HEADS whats the differance
- my turbo!
- Do S2 alloys fit over 2WD Cossie disc's +4x4 calipers
- Inner and outer suspension area corroded.
- where can i get a fan from? radtec intercooler
- Lost lockin wheel nut key
- Lowering a S2
- Please advice help fitting my pace intercooler...
- fuelling and idling probs(manifold leakin fuel)
- Holding back on boost s2
- rear lights?
- idle
- FRST Engine
- 2.0 litre bottom end
- Dying S1
- blue smoke
- Series 1 Panels
- Efi conversion
- side indicators
- standr s1 suspension
- Welding help....
- Got my 4x4 calipers and discs... Help with loosin 3-4mm
- Rust behind bumper
- Pic's of my new s2....
- Do i need this??
- S2 RST bottom end rebuild questions
- Whats this called?
- Turbo Rebuild
- Fitting pace intercooler
- TURBO LAG/STARTER MOTOR
- Your thoughts please
- Bhp on clutch's
- Fitting boost controller instead of bleed valve???
- Series 1 Ford Badges
- Just took the kit off the Series 1.....
- Pace intercooler, escort fiesta the same???
- handbrake problem help needed
- power and more power
- Driver seat sagged
- s2 turbo replacement
- s2 engine and gearbox in to s1
- is this clutch worth anything to anyone?
- Charger Coolers
- Oil Seperators/breathers
- Actuators
- Escort Cosworth wheels...
- S2 Timing belt
- electric water pumps as seen in P/F mag
- White wheels
- s1 arches yes - no??????
- at what piont is water temp to high
- IN CAR BOOST CONTROLLER/BLEED VALVE
- escort rst s2
- Roll cage with back seats?
- cooling temp
- car still doesnt start on the key
- who's changed their chassis rails!
- Still low oil pressure!!!!
- Intercoolers
- Recon Turbo
- ZVH compression down on number 4 pls help?
- How much do a set of lowering springs go for?
- Them Rare rims!
- Alright lad's, stepping down...
- silcone hoses help
- D shackles ?????
- Powder coating
- timing on chipped s2
- Clicking noise from engine...
- fuel ajustment on the metering unit (S1)
- Cooler & rad help needed please
- Rs turbo wheels what size to go for?
- s1 samco fitting????
- grs on a s1?
- Alloy fitment
- Difference between a bleed valve and a boost controller???
- Whats wrong?
- mk3 and mk4 RS Turbo's--What bits are the same??
- using a 3i fuel pump?will it work
- WHAT OIL IS BEST FOR A NEW ENGINE RE-BUILD???????
- Metering Head Q
- My Power s2
- ecu chipping
- Fitting sierra discs and calipers???? Confused
- ANYONE OFF HERE BUY ANY OF THE SPEEDLINES RECENTLY ??
- Hot start s2
- Traction Problems - I have non :cry:
- Mk3 & Mk4 ext. door handles
- manual to electric
- loose steering
- t3 internals
- Fast Ford Mk3 Shoot out at Brunters Today
- what air filter should i get
- Check me out :)
- Will a mongoose back boz fit a magnex system?
- Gear box...
- Rs turbo s2 front coilovers
- fuel pump priming
- Base chip
- Escort Mirrors
- gotech management
- my mk4 rs turbo combi
- Boost Facia
- quaife atb and torque steer
- electrical fault
- Which HT Leads
- Rs Four spoke steering wheel boss
- Oil everywhere
- double capacity pace intercooler
- cosworth loom
- Front windscreen S2
- What do you think
- ZVH Proplems again.... well still the same.
- eh WTF!!!! lowering car
- silicone ancillary hoses where from?
- How powerful is your RST
- Cabby owners
- electrickery
- 1900 CVH???
- recon meetering head
- efi flywheel positioning
- Site for replacement panels
- Paint codes
- is this rare?
- Brake problem....now sorted
- coilovers
- Standard Intercooler S1 vs. S2
- s1 owners!!!
- considering giving up
- racing puma brakes
- intercooler
- I Just Drove My Car Round The Block a Couple Of Times
- are new headlights available from ford?
- Fitting a pace intercooler to series 2....
- How to fit a dump valve to an escort rs turbo
- setting solid followers
- Brake conversion S2, what 4 pots will fit from other fords??
- Rotor Arm
- COSSY BRAKES ????
- Twin engined s2!!!!!!
- Oil Found in Boost Pipe
