PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. RS Turbo Group A prep pdf??
  2. Old fuel
  3. S2 rev counter
  4. is it possible?
  5. Had Enough...!
  6. Rear backing plates
  7. Dizzy and confused help please
  8. mfi rs turbo c0
  9. where in the east to set mfi up
  10. Temp gauge
  11. Puma linkage conversion
  12. Brake servo mk4 Escort
  13. S2 Cooling problems. Really desperate for advice now.
  14. where the best place be buy replacment panels
  15. Bad Idle? what can i be..
  16. Anyone running zetec turbo in your mk3/4 escort with dry sump set up or external pump
  17. Temp sender diiferences?
  18. Anyone using burton power adjustable bias assy
  19. No dump valve
  20. master cylinder
  21. Series 2 radiator leak
  22. Spaghetti junction
  23. Wheel fouling
  24. Gearbox mounts
  25. My s2..thots and advice required
  26. S2
  27. Dropping EFI into an MFI converted mk2 XR2
  28. Rear brakes
  29. help!!!!! bad earth
  30. Need a new fuel pump
  31. Advice needed after possible over heat.
  32. Help needed after car crash! Pls read!
  33. Rs Turbo MFI inlet studs
  34. Rs Turbo Crossover pipe sensor
  35. Mfi inlet manifold wiring - cabriolet conversation
  36. OIL?
  37. Roller rockers
  38. MFI > Zetec Turbo
  39. Ford Escort RS Turbo Heating Problem
  40. Ford Escort RS Turbo S2 Heating Problem
  41. Power steering
  42. indercator stalk
  43. Vin & paint tags
  44. Left hand oil breather
  45. Polycarbonate windows. Anyone got some for sale?
  46. 82deg thermostat and uprated switch KEEPS fan going won't turn off
  47. BREAKs let's talk !?
  48. Blacktop Inlets
  49. motorcraft filters or Mann hummel???
  50. Zetec Turbo
  51. Brake drum screw
  52. Bleed valve?
  53. S2 head tolerance and need standard cam
  54. anyone got cobra bucket seats fitted into mk3/4 escort ?
  55. Noisy BC Gearbox
  56. Relays
  57. what size hose is the pipe from the crank case
  58. removing oil pump on zetec turbo
  59. 25mm springs
  60. ST170 into Series One....
  61. what to modify?
  62. c20let pistons zvh
  63. S2 turns over too fast and wont start
  64. Can you name this Turbo?
  65. easiest way to take roof lining of my rs turbo
  66. Engine problems
  67. S1 Rs Turbo MFI To 2.1ZVH EFI
  68. s2 front panel, repair or replace???
  69. Rs turbo feels like front lifts up
  70. Mk3 Mondeo Brakes or Cossie Brake Conversion - What's Best ?
  71. Coolant boiling!
  72. Mk 4 brake kit's
  73. Engine tempsensor
  74. Efi escort Rs turbo tuning
  75. Cvh oil pump
  76. Blacktop zetec conversion help
  77. uprated fan switch
  78. Changing a series 2 tailgate?
  79. drive shaft length
  80. s2 will not turn over when hot
  81. S2 head has it been ported? See pictures
  82. Warm starting/ urgent advice needed before Dyno on Saturday.
  83. Urgent S2 advice needed please!
  84. cosworth 2wd disc conversion
  85. Fitting kit for a 6 point safety device cage
  86. stupid MFI setup
  87. series 2 in salvage yard in essex:(
  88. Anyone had problems with seat crossmember when fitting box section seat rails?
  89. Zetec sumps
  90. where can i get the upper (alloy) part of a blacktop sump ?
  91. Starter or Alternator issue?
  92. Cts2 gearbox?
  93. Help/advice needed
  94. 88 S2 colour
  95. Instrument panel bulbs... Series 2
  96. fuel pump fitments different
  97. carpet underlay / sound deadening
  98. What bhp is the limit using standard zetec valves ?
  99. Worn cam = miss fire ?
  100. What T3 Turbo is this?
  101. Fitting black top into rs turbo
  102. rs keeps going lean on the co 0.6%
  103. escort rs turbo gaz coilover fittment
  104. Fuel Pump Question For Zetec Turbo
  105. Kilen lowering springs
  106. S2 RS Engine conversion and gearbox LSD
  107. What are these injectors? Help please
  108. Rear pop out quarter windows? And how to fit...
  109. Coolant Temp Sensor.....
  110. Crank oil leak/ plastic cover?. (Pic Inc)
  111. Standard -v pace -v- airtect intercooler
  112. Locks
  113. Escort RST Series 2 manual fan switch wiring help needed
  114. Anybody know this car??
  115. Running issue on RS Turbo!
  116. What do people think of re-shelling s2 RS turbo??
  117. H561 BKP info/owner
  118. setup questions
  119. Handbrake cable issues
  120. what gauges to get and best place to mount
  121. How to set series 2 idle
  122. Sarcasm
  123. Help changing track control arm please...
  124. Shattered Con Rod...
  125. Quaife quick rack
  126. Which EFI Flywheels Can I use?
  127. Front Suspension S2 Help
  128. Remap to ofam or upgrade to stage 3 t3
  129. Which Ka Gearbox for ZT Conversion using Karlos G's ST170 Guide
  130. zetec turbo dry sump at what power ?
  131. Ed China's gearstick?
  132. Where to get my t3 stage 3
  133. rear suspension sat uneven
  134. Head porting
  135. Which wide band lambda for ofam?
  136. Modding MFi manifold to EFi???
  137. Escort RST series 2 intercooler fans question.......
  138. Escort s1 turbos prices
  139. rs turbo dump valve
  140. Want to get my Rs turbo setup on my ofam ecu
  141. boot light switch.
  142. Fuel pump relay
  143. Zetec Turbo Engine - Turbo Recommendations
  144. zetec turbo clutch problem
  145. Skirt fixing rails???
  146. Frst engine loom connector
  147. Fitting RS 7 softlines on a series 2 RST
  148. Does anyone know E616 BTW? Series 2 Mercury grey?
  149. S2 MFI Breather/Running question
  150. Escort RS Turbo Series 2 180bhp which oil??
  151. series 2 original wings
  152. rs turbo drive shaft retaining nut torque setting
  153. rs turbo loom
  154. anyone on here using fixed or adjustable top mounts ?
  155. Efi inlet manifold upper gasket
  156. Escort Rs turbo efi ecu mount
  157. curently fitting master cylindrrs to my pedalbox
  158. water leaking under fuse box
  159. EFI Conversion - Revometer and Fuel Guage Issues
  160. Efi conversion what air filter and pipe
  161. Best way to mount a rear ARB?
  162. Clutch recommendations
  163. Battery Dead ..???
  164. Engine question pistons rods block etc.
  165. Fuel pump noise
  166. Black Top Zetec Turbo Alternator Setup
  167. gromit / speedo
  168. Black series 2 rs turbo F552 TWC
  169. RESTO...
  170. CVH Steel Rods
  171. warped brake disc replacement
  172. Inlet manifold coolant leak??
  173. series 1 stuck in 3rd gear
  174. rs turbo best spec for track and road use
  175. metering head
  176. Cosworth brakes
  177. Colour for suspension parts?
  178. pedal boxes ?
  179. bosch 941 fuel pump
  180. Brake upgrade - options?
  181. Clutch master cylinder???
  182. Fitting a safety device 6 point roll cage
  183. sensor kits s2
  184. Pic of my escort rs turbo s2
  185. Having a mare bleeding brakes on mk3
  186. FRS brembo
  187. carbon compomotive centre caps where from?
  188. how to add photos
  189. MFI plumbing
  190. Rs7 alloys - 14's
  191. I'm new
  192. interxoolers
  193. mlr rst quickshift
  194. Cleaning MFi Injectors
  195. EDIS Unit Clicking...?
  196. Series 1 Dashboard repairs???
  197. Oil at bottom of metering unit
  198. spares and parts
  199. Rear suspension setup...
  200. Escort RS Turbo bonnet
  201. Series 1 inlet manifold on efi
  202. where can i get a fiesta turbo act sensor ?
  203. RS turbo conversion help
  204. poor startup
  205. Escort Rs turbo efi
  206. escort mk3/ mk4 ignition barrel surround+steering lock
  207. Rs turbo boost gauge
  208. anyone in devon area with mfi knowledge
  209. Manifold - Turbo Gasket
  210. cosworth management without bonnet raisers ?
  211. What can the RST S2 gearbox handle?
  212. Boot wiring gaitors
  213. Welder needed in Norfolk/Suffolk
  214. S2 Rear suspension bushes.
  215. rs turbo s1 fusebox
  216. what fire extinguisher colour
  217. turbo coolant leak
  218. White S2 G589 YOO 90 spec
  219. Surrey heads
  220. Stage 2 hybrid for erst s2
  221. What goes in here?
  222. S2 turbo D239 YRX
  223. S1 colour plate on slam panel
  224. boot install
  225. Vernier cam pulley worth running ?
  226. Series 1 wheels
  227. screamer pipe
  228. Standard s2 camshaft (genuine)??
  229. Series 1 Recaro Seats
  230. C916 FKR Series 1 oil?
  231. Rough idle on cold start !
  232. best brakes for s2?????????
  233. External wastegate fitting, whats needed
  234. Sunroof drainage
  235. few efi questions (sorry)
  236. airtec or grs intercooler ???
  237. Drag RS
  238. Been a while!!
  239. What are these??
  240. C916 FKR
  241. RS1600i rocker cover on RST engine
  242. s2 rs mfi loom to OFAB
  243. ecu location using frst loom
  244. fitting electric windows...
  245. engine popped during boost!!
  246. pic request mk4 escort lowered 60mm
  247. Rs focus to erst.
  248. Advice on which management please
  249. 2.0 Zetec turbo or hi reving 2.0 on throttle bodies
  250. White smoke ..... Help
