- a little help please...
- how much do RS Turbo's break for?
- s1 bodykit rivits avability
- who else is fed up of owning there ERST
- Think I have MAJOR problems.... HELP!!
- ESCOT RST HYDRAULIC TAPPETS
- 17s on my s1
- pic request
- ABS light
- shaky series 1
- Running Problem with Series 2 ***SORTED***
- Zetec turbo....
- Wilwood Brakes
- escort cossie wheels
- what power will i reach??
- WHO IS THE MOD IN THIS ROOM??
- Stolen!!! Black series 1
- Smoked mk3 rear lights
- my cars not right
- Any one here used to own B313 XKP.
- What Clutch??.......Recomendations please!
- Cool Down
- Modified throttle body on Fleabay
- Perspex rear quarter windows?
- best fuel pump
- breather problem
- alternator
- Intercooler Question
- mechanical window winders
- E603 VYG, anyone know it?
- RS parts in S.Wales
- Wont start when hot?
- S1 ECU colour code
- Rev Counter
- gaskets
- rear disk conversion.
- fuel problem (i think)
- 300 bhp on standard Exhaust Manifold I dont think so !
- mfi to efi
- Series 2 Turbo
- More of my series 2
- Gearbox's
- boost setting helpp please!!
- 17" AZEV A's on a S1
- cossie 3 spoke s/wheel
- s1 parcel shelf (quick reply needed)
- Escort rs turbo tuning companies
- grey rs
- oil for zetec turbo
- DO I HAVE PROBLEMS????
- Metering head question weird
- wastegates
- Cosworth Fuel Pump
- Adaptor plate for my turbo/manifold
- need relay advice
- your next s2
- Aerial Not Working
- gotech Managment
- trickle chargers
- Air pressures ERST
- test
- will these fit my s1
- Problems with polybushed rear wishbones...... anyone else?
- Pics of S2 with compomotive TH2s?
- Clutch!!!
- Cossie Brakes?
- idle prob
- hard steering
- Turbo Time..
- Size of series one
- Metering unit rebuild manual
- cossy calipers on an S2
- high revs on idle
- Distributor
- Dry sump kits....?
- Trouble gearbox MK3 <-> MK4
- T3 options?
- Whats the best RST after market exhaust, for BHP / noise?
- Fuel pump relay
- how many s1s left on the road
- braided brake lines
- any1 no c995xcs
- any 1 no c995 csx
- Omex rev limiter + launch control
- s1 rollcages
- s1 carpet
- Bumper Inserts
- Anyone using black samco hoses? pics pls :)
- Is this original ford Leather
- heater matrix
- the safest spec for 200bhp
- Allen bolts on exhaust elbo of the turbo
- Ignition retardation problem..... SORTED!!
- BLEED VALVES!!!
- 16" ????
- Cutting looms?
- What engine mounts ?
- my s1 prob
- s1 bodykit
- Where to get A pillar pods from???
- what front splitter do people have on there front bumpers?
- which is best to have???
- compression test
- mk3 escort headlights
- cossie t3 turbo
- APT/Passionford RR Day - CANCELLED :( TO BE REARRANGED :)
- Efi loom for Efi conversion?
- What a night last night!!
- winter!!
- quick question
- series 1 central locking??
- fuel pump hangers
- OFAB AND OFAC
- oil cooler???
- Car will only run on 3 cylinders
- HELP! MFi Metering Unit Question
- Whats the max for standard 1.8 zetec pistons?
- How can i tell if its from a turbo?
- Best place to go
- how do you shorten the actuator rod?
- brembo's on ebay!
- Autotech Power Module for KE-Jetronic
- Lincoln ERST Peeps where are you all??!!
- fitting 18's on my car
- Heated Front Screen Relay
- Turbo Time!!
- Possible starter motor fault
- radiator ic sizes
- Washer bottle pumps. . .
- Does yours do this ?. . . .
- Most powerful ERST's in this country?
- sierra cosworth rear calipers
- Very confused!
- rs turbo vernier pulley ?
- what sort of s1 will 3-3.5k get me
- low-cost brake upgrades?
- F55 SOY colour?
- some has a photo of this ?¿
- chatter sounding dump valves?
- top end misfire
- boost controlers
- escos alloys on a series 1
- bleed valve
- Oil cooler, where to mount one on S2???
- backfire on boost
- Series 2 Header Tank
- s2 heater matrix
- where is best to fit aftermarket sensors
- Mk3 bonnet on a Mk4?!?!?!
- TINTS
- its a girth thing
- *** RS7 Wheel problem ***
- Strange RR Results? **NOW WITH GRAPHS**
- turbo water pipes and 4x4 brakes
- What parts aren't avalible from fords anymore?
- GT25 turbo on a cvh
- norris motorsport
- Re-shelled S1
- horn
- Have i bought a white elephant?
- Cut out
- Which servos fit?
- tax out soon
- s2 will not start please help
- black alloys
- Cheap turbochargers good or bad?
- Anyone got pics of.......
- Engine out and re wiring?
- HELP!!! S2 is backfirin (not solved, still doin it)
- wrong turbo housing. Thinking of a new turbo?
- head bolts
- losing oil???
- what engine oil for s2?
- what boost can you run on 7:4.1 cr ?
- car was filmed today for itv
- Should i remove abs?
- 2wd cossie calipers
- need some pics
- rs turbo fuel tank
- probs with rst can any one help
- how to fit other ford wheels
- need help on my S1
- 5w/50 oil for a s2?
- got a clicking noise from cv joint
- oil leak on back of engine of turbo hose fitting
- s1 rad and cooler upgrade??
- scorpion exhaust
- S1 into S2
- uuuummmm strange one..help
- white smoke :S
- N/A CVH and RST CVH
- what are the differnces good & bad s1 vs s2
- intercooler jubilee clip size???????help
- Delocking my tailgate
- self adjusting clutch
- pr*ck
- Actuator?
- outer front window seals
- Cheers Radders :)
- Can an intercooler be too big
- Mongoose exhausts...
- boost settings
- early morning starting problems
- CVH head casting for big valves
- who has GRS radiator and intercooler
- Bottom End Wanted
- what is the yellow plug under the inlet on s2 rst
- wots it worth?
- whats the best suspension set up for a s2
- help with oil pressure
- Pistons........
- whats the best cam for my cvh turbo
- Transmitter in Efi. HELP
- Mfi injector upgrade?
- wheel nuts for diamond rs wheels
- Numbers on top of pistons??
- cheers jano
- AP Brakes
- turbo timer
- HELP ME PEOPLE---I REALLY DONT KNOW-SOLD
- anyone using st170 300mm brake disks and 2wd calipers??
- Help ASAP?
- Rs Turbo radiator in the boot mod
- S1 turbo question
- s1 panels
- Is my ECU chipped?
- FAO Dry Series 1!!
- Stack
- GRS or Radtec front mounted intercooler
- erst exhaust flange bracket
- headlights
- rear fog fuse??
- MFI to EFI
- insurance
- what have i done !!!!! 3rd to 2nd (update now with pics)
- brakes advice
- whining sound....opinions?
- NEW LOGO LAMPS.... GIVE US YOUR VIEWS
- Genuine s1 rs turbo front & rear repair panels on ebay!!
- radiators
- My new bottom end issues
- selling escorts?
- head
- shorten actuator rod
- Gearlinkage......
- Is this a con or not????
- Water pump......
- bleed valve
