PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. Underside resto
  2. EFi turbo crossover touches bonnet :-(
  3. RS Turbo boot struts....
  4. rs turbo id
  5. Mfi unusual idle
  6. Pace Charge Cooler?
  7. Floor mounted pedal boxes. Tilton Etc. Anyone got pics?
  8. Zetec Turbo - Thermostat and Piping / Hosing Options
  9. Zetec Turbo T34 Turbo Mounting issues
  10. rubbing arches
  11. XR3i Cabrio conversion questions
  12. rs turbo cvh knock frequency
  13. Spec help on mfi
  14. mk 5 escort 1.6 cvh engine swap to 1.6 rs turbo
  15. Mega Squirt Help Needed
  16. Driveshaft differences
  17. negative camber
  18. S2 speedo & ABS
  19. Wheel colour thoughts
  20. Brake master cylinder overhaul
  21. Opinions on my spotlight options
  22. Twice in a row now?
  23. 300mm brake upgrade
  24. knock monitor/detector
  25. focus rs my s2
  26. spring issue?
  27. anyone used a new fuel tank with the metal swirl pot
  28. Cam belt timing marks and ignition timing
  29. 2 different guide shaft for bc gearbox. why? please help.
  30. Tps not working, suspect wiring?
  31. Found this on my gearbox support
  32. fuel pump cradle s2 alternative and bobbins
  33. Want a zetec turbo!!
  34. rear bumper rubber moulding black
  35. Help
  36. T34 Turbo - Spinning Housing and best Actuator
  37. Gearbox speed sensor signals
  38. s2 rs turbo springs
  39. Help on what to do with my engine
  40. G401 yan
  41. Airtec
  42. Which Fuel Pump??
  43. fitting oil pressure & oil temp senders
  44. S2 Turbo Speakers & Wiring etc
  45. Wandering Issue..
  46. Couple of questions
  47. RST clocks
  48. What a difference
  49. standard cam with hydraulic lifters
  50. Series 1 advice...
  51. Zetec Turbo Gearbox Issues (Have I bought the right one?)
  52. Best head gasket?
  53. remove the header tank
  54. Looking for a brake reservoir cover
  55. Sunroof Removal
  56. bailey oil breather
  57. standard cam replacement
  58. Part no's for suspension rebuild wanted.
  59. S2 wont start
  60. S2 Horn Relay
  61. Series 2 90 spec h reg rs turbos
  62. front spliter
  63. ht leads
  64. Cossie 4 pots under 15" flat face comps?
  65. Anyone know what causes this to happen??
  66. Cable,pipe layout round petrol tank
  67. What's this
  68. series 2 Sunroof required - Resto project
  69. Escort RS Turbo suspension kits?
  70. Zetec Turbo Clutch Recommendations
  71. Roof lining
  72. Starter motor
  73. efi turbo tps issue
  74. Timing Belt Cover Screws
  75. a long shot but.....G432SFG RED ESCORT RS TURBO
  76. IB5 Gearbox Options
  77. Couple of questions
  78. efi turbo tps issue
  79. Water running 120 degrees
  80. help! ke jetronic question
  81. help needed ref track control arm lengths
  82. Inner CV joints
  83. Help
  84. MFI over fueling
  85. eBay fron indicators
  86. Newman solid tappets
  87. cp racetec braided brake lines hose pipes
  88. Running hottttttt
  89. Ka gear box
  90. Track car advice
  91. Who knows these cars and can answer this one .......
  92. Steering Column Bushes
  93. car security tracker stolen locator
  94. Holding back/boost cutting S2 RS Turbo
  95. S2 Drivers door lock
  96. Any one put puma rear seats in a mk4?
  97. petrol keeps clicking at the pump
  98. Are these the correct ones?
  99. Brake problem!
  100. looking for my old rst's
  101. Fusebox repair panel help
  102. Front wiper nuts and covers.
  103. Cosworth management s2 no spark no fuel pump priming?
  104. Info on a s1 RS turbo please
  105. MK1 FRS mtx75 speedo drive conversion ?
  106. B&m shifter knob thread size and pitch
  107. Some New RST Parts
  108. Rear load proportioning valves
  109. Brake servo/master cylinder up grade what's to use
  110. T3 turbo downpipe sealing issue
  111. Car Wiring Looms
  112. Zetec conversion
  113. Escort RS turbo Fuel Tank
  114. Brake line set up?
  115. Help needed!!!
  116. Starter motors
  117. frst engine and loom into erst s2
  118. cheapest place for door weather strips (outside)
  119. Front hub dust covers?
  120. C430 SOY series 1 is it anyone on this forum
  121. Helpppppppppppp :)
  122. boot liner for RST/MK4 escort
  123. Escort rs turbo starting problem
  124. S2 fuel lines
  125. Strange engine problems
  126. Turboing an EFi cabby, confimation questions???
  127. carbon fibre roof wrap
  128. S2 very slow windows and wipers
  129. Calling All Brake Nerds
  130. Sun visors fitment with a cage !!!!
  131. s2 water return pipe
  132. Pink relay
  133. Compbrake lower arms
  134. Inner cv Joints?
  135. Elbow to downpipe studs & nuts
  136. people with cable gear linkages
  137. Fuel tank pipe?
  138. whats that car show exhibition called
  139. Annoying rattle (well the most annoying one anyway)
  140. Restoring RS Turbo S2
  141. mfi drilled block tps sensor question
  142. Injector and Throttle Body advice for Zetec Turbo
  143. CG Motorsport clutch
  144. f100 dba
  145. BGA or Febi oil Pump?
  146. G798 XWC
  147. front panel x member
  148. who has Turbo Technics Front ARB today
  149. ideas please, ongoing problem
  150. power engineering system 2
  151. engine swap
  152. mfi to efi conversion issue
  153. Help with Coil Spring ! Thanks
  154. dump valve
  155. Rubbers bleeding
  156. go-tech pro stand alone management...
  157. Ignition lights 1st click
  158. Track car question
  159. gearbox gear jumping out
  160. Advice on uncut radio/cd player loom
  161. Wind deflectors.
  162. Engine management
  163. Which wheel nuts for cosworth alloys??
  164. Mk4 power hood hydraulic help
  165. Head gasket problems
  166. Instrument panel bulbs
  167. Cut out front bumper
  168. zetec alternator
  169. Coilovers
  170. Series 1 Gearbox/clutch question
  171. Not an escort
  172. rst stereo wiring
  173. Ofab problem
  174. mfi question
  175. zvh fuel pump query
  176. Series 1 Radiator on a Series 2?
  177. s2 replacement sump pan, where from
  178. sounds lambda for mfi escort rs turbo s2
  179. mfi to efi loom question
  180. how to identify bosch fuel pump
  181. air-fuel ratio gauge
  182. Banjo washers.
  183. Manual boost controllers
  184. ofab ecu dead?
  185. Big misfire
  186. Mk3 mondeo caliper st170 disc setup!!?
  187. track car rear suspension set ups what are you running ?
  188. rs turbo non starter
  189. Fuel cut symptoms in fifth only?
  190. Couple of questions (Possible Blond Moment)
  191. Steering Vibration.
  192. yes another No Spark From Coil problem.now stumpted
  193. Heated front screen
  194. Idle problems
  195. Efi cosworth management
  196. Advise needed clutch slips when boosting
  197. Mk4 Escort green tint opening rear quarters
  198. RS Turbo EFI - Boost and Idling Issues
  199. S2 RST .. Novice Concourse Winner
  200. information on dropping in an efi turbo
  201. super slim fan for rst
  202. Fuel pressure regulater
  203. My Dyno result
  204. Stainless back box onto stock middle section
  205. Brake calliper
  206. oil pump
  207. Fuel tank
  208. B&M Quickshift thread
  209. Modified Series 2 running temperature.
  210. ignition coil
  211. Power engineering system 2 inlet valves ?
  212. Rear discs
  213. St220 lump in mk3/4 escort?
  214. Single silicone boost hoses
  215. Pics of cosworth management trigger on cvh
  216. head "done"
  217. f866 pvx?
  218. I need help, engine broken
  219. Is this right?
  220. Boot lock question
  221. s2 overboosting
  222. ..still available ?
  223. Pics of a moonstone blue rs turbo please.
  224. Need Help from Italy,Coil Spring
  225. megasquirt in combination with rev counter problem
  226. fueling issue...options?
  227. Windscreen wiper issue.
  228. Do I? Don't I Situations.. HELP.
  229. Reuse Cometic head gaske
  230. inlet valve escort rs turbo
  231. urgent! forget conrods
  232. Series 2 injector plate removal.
  233. Megasquirt VE and Spark base table request
  234. Ib5 gear box starter motor
  235. Upgrading my brakes...
  236. S2 temp sender thread size.
  237. Few photos of the car at the cumbrian RS show
  238. Window Regualtors
  239. Rocker cover gasket and sump
  240. mechanical cam followers
  241. Drivers headlight dull
  242. What cam to buy for a S2 RST
  243. Show us your gauges
  244. Rs turbo chatter
  245. Megasquirt coilpack capacitor wiring
  246. Tuning / Setting up
  247. gearlinkages
  248. sunroof seal
  249. new speedo cable - where from
  250. f reg sunroof seal
