- FAO of anyone with comps!
- Camshaft leaking !!!!
- Car keeps cutting out
- how do i tell if i have a cossie turbo on my S2 ?
- Turbo elbow...
- COILOVER USERS !!!!!
- ECU swap...
- NEW MODS NEEDED
- piper spares
- CVH Lack of top-end power and/or rattling.....
- adjustable bottom arms
- no boost please help
- wolfrace voodoo alloys
- erst fuel prob
- Anyone got a Escort S2 Gearbox???
- block to head oil ways
- Anyone got a part number for the fel pump relay
- WHAT BHP IS MY CAR?????
- mk5 turbo probs
- what oil to use
- Converting a zvh to zetec ?
- 200bhp at the wheels, wot spec?
- REAR LIGHTS & 17" RS7 SPOKES
- FAO all those with wierd engine noises....
- HELP..........Please
- How to increase your final drive ratio??
- Oil Cooler - Mounting
- C210 MGB ?
- CV Joint *QUICK QUESTION*
- rs turbo cam? the same as xr3i?
- best turbo
- Oil gauge shows no pressure & overheating issues!
- wiring help urgently needed
- s1 turbo track control arm
- lowering....
- holding back????
- cosworth brakes no good
- does this spec sound anygood/ok to you
- Light grey smoke????
- Fitting a 5th injector
- Quick question asked at risk of sounding stupid
- efi flywheel question
- ERST S2 Chips
- Anyone with RST FMIC's, GRS, AS, RADtech etc etc?
- difficulty getting EFI conversion to idle and rev??
- 16" Alloys with 50mm Drop Pic Request
- s2 tapping and lack of power
- Big ends?
- ers2 tracking
- ignition fault
- fuel pump(cossy and rst psi?)
- mocal oil temp gauge
- help on s2 standard injectors
- Magnex exhaust..Scorpian backbox?
- Abit of help please
- Bottom end...........
- misfire
- Dash/Gauge Q
- Anyone interested in Steel CVH Rods £350 Group Buy!!
- Fuse for heater controls
- 17" Wheel Measurements
- Trackday preparation
- wheels on series 1
- Dump Valve
- rev counter fault
- fitting gauges in centre air vents
- rs turbo with cossie magement
- set up and tunning rs turbo
- Does SCC PERFORMANCE have an e-mail????
- anyone own my old s2
- steel rods
- 1600i rocker cover
- urgent help needed
- How Can You Tell If A Steering Rack...
- Torque of the devil
- best zvh compression ratio
- help with noisy cvh head
- Series 1 Indicators
- sump gasket
- tubular manifolds
- Series 1 ERST quick-shift / short-shift??
- Would you buy this S2?
- Starting probs
- Camshaft oil seal leak - help ??
- Quick Question
- Trackday RST's, what rad's do you use?
- fuel prob
- HELLO ALL IM A NEWBIE AND REQUIRE SUM HELP
- ???? how easy is this
- cossie brakes...
- bhp what mods
- Boost Problem
- Sunroof Cover
- RS Turbo aftermarket springs????
- Turbo oil feed part
- wossner pistons
- pleas help - speed sensor
- what is the best gearbox
- M I S S F I R E !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Help with fuel pump guys-BLOODY CAR!!!
- Valve Guides
- is a fuel pump linked to the headlight
- Changed Camshaft
- what is the gains from a 5th injector?
- s1 parcel shelf /radio
- series one rear brake conversion to discs
- Sunroof tore out this morning!!!!!
- de-flex bushes
- Starting car that's been stored for 7 months
- -31 actuator benefits
- 200 bhp
- EFI won't rev??
- 5th injector mount ?
- my shell
- poly bushes
- torque wrench settings
- Where can i get this style battery?
- Cossie fuel pump...
- 20" rims on an S1
- worn camshaft
- zvh 2.1 cambelt tensioner
- Rev counter (EFI) conversion
- T34 Turbo
- Fitting piston rings
- gearbox oil
- CROSS OVER PIPE?????
- No Power After 4000 RPM
- double valve springs
- drive shafts
- bias brakes
- will i pass mot?
- Zetec into S1 install
- Small Leak on Gearbox
- standard RST-does it alter the fueling itself?
- JAMsport
- Help Throttle cable.....
- my rs is running fine
- Why is it....
- 5th injector
- difference between Oil Separator and Swirl Pot
- non starter
- new bottom end
- mate needs help
- Non starter (S2) - help! NOW WITH PICS!
- Rev Limiter/Launch Control Rumor
- Megasquirt........Any good????
- FUEL PROBLEM!!!!!!!
- FRST motor
- Got another S2 !!!!!!!!!!
- best place to get my S2 setup
- koni adj lifetime
- anyone fancy fitting my clutch ?? pls pls pls ...........
- header tank
- big turbo lag-ignition timing?
- Compression Ratio Question...
- rear trailing arms
- Pics of my S2
- starting after standing question(pics)
- DEFLEX POLYBUSHES
- Less lag on my RS Turbo
- still wont start
- Might be selling up
- Flywheel Bolts
- OddKidd's Escort Mk4 RS 340+bhp STANDARD ENGINE!
- clutch help pls
- Where is the front exhaust mount?
- good or not??
- ESCORT MK3 OR MK4 SIERRA FLOOR CONVERSION PICS!! HELP!!
- rs turbo s1 inlet manifold ??
- Pop Out Window Chrome Circle Covers
- Zetec Gearboxes...
- Zetec Turbo Spark Plugs
- advice
- How wide are escort cosworth alloys???
- has anyone had any probs with . . .
- Budget Zetec turbo
- amel valve (sp)
- Roof lining
- Anyone got a 1.6 cvh on 2wd or 4wd T3 cossie turbo???
- PJ Motorsport!
- st 170 turbo vs silver top turbo
- Brakes Upgrade for RST
- Amal and bleed at same time ?
- for sale nokia n95............$300usd
- Just started my first EFI conversion job!
- suspension alinment
- anyone know of my car
- alarm siren help
- Chipp ECU question?
- Just Took The Series 2 For M.O.T
- A knock from nearside... Could it be a bush???
- rst is ROUGH AS HELL HELP
- Ignition Barrell
- any one else get worried wen going to the rollers
- Tax Disc Holder
- 5th injector kit
- which shocks?
- RANDOM QUESTION
- Boost Problems (Please Help lol)
- Random pics of my motor
- FAO lucid
- s2 bonnet
- rear disc question..
- muffler question
- Fuse Box
- pics of your S2 enterior styling
- S2 Rad's
- Any pics please of S1's or S2's with Mudflaps
- Are the S1 Tca's diffrent to the S2 one's
- Cheapest way to upgrade brakes
- fao people with removed abs
- What Nuts to use................
- standard intercooler
- whats the best running in oil????
- Cylinder head parts numbers
- FAO people with rear discs
- RST overheating when switched off?
- wanted series one rs turbo kit
- s2 coilover suspension kits
- alloys
- quick loom questions
- rs turbo any recent project pics or any pics
- starter motor heat shield
- coil pack conversion
- amal valve pipes-which way??
- Which Intercooler
- insurance, what a rip off !!
- Decompression Plates
- head bolt washers
- Squeaky, poxy, pain in the a£@e parcel shelf - help needed!!
- Shortened Dampers
- TACKY OR NOT!!!?????????
- Is this a limited slip diff
- a couple of things
- tap tap tap
- Help needed with this weird BOSCH part (fuel unit)
- 280mm or 320mm steering wheel
- weilding
- Seat Runners?
- Logo Escort RS turbo
- fitting anti-roll bushes
- fitting dizzy-fitting it and getting car running!
- best spark plugs for series 2
- the best after market management
- timing
- bricking it........MOT passed, woohoo!
- Esc cos rims are on the S1 **UPDATED WITH PICS**
- Magnex Exhausts?
- Help! Front or rear jacking point covers???
- Usual oil consumption?
