View Full Version : Ford Escort RS Turbo
- repairing a series one body kit.
- boost controller, bleed valve or amal?
- stripping a series1 recaro
- Mk4 Escort Wide arches wanted !!!
- 0psi oil presure
- escort rs fiberglass bonnet
- Shocks n springs
- Instrument Cluster Help
- Karlos G - AKA Frenzy Performance Tuning (FPT)
- Glowing battery light.
- Noises...
- efi setup where?
- zetec turbo idle problem
- More advice for a late night thought Ive had.
- Exhaust Pipe
- S2 rs turbo wire looms
- RS turbo engine timing, doing my head in
- Series 1 value
- rs turbo oil dilemma
- downpipe issue
- Need help finishing my XR3i to RS Turbo conversion
- Braided brake lines from the Master Cylinder
- How does this spec sound?
- exhaust manifold gasket
- Who to use for carbon fibre ? Who takes on custom work ?
- Think I broke my piston :)
- Efi 1.8 zvh,turbo replacement options?
- racing puma box?
- Series 1 engine
- Rear strutt tops
- Do mk3 door handles fit the mk4?
- Any CVH exhaust manifold pics (pref over gbox)
- New noises and vibrations
- Standard rs turbo breather set up
- New wiring loom
- RS turbo service
- Injectors
- Engine management
- Gearbox options, st150 gear set ?
- Front bushes, rare part now?
- First time owner
- Flocked dash
- fuel pump problem
- Rear wheel arch trims.
- standard s2 turbo's
- Pic request of your intercoolers
- HT Leads firing order position
- Ofab or ofac?
- wired up some gauges need a dice on ground and ignition
- s1 and rs1600i warning ecu
- Fuel flow rate
- Help identify my shocks
- Rs turbo fuel pressure problems
- Master cylinder/servo upgrade
- what are the symptoms?
- psi std conrods
- escort rs turbo s2
- S2 help
- For anyone interested in fitting Heated Seats...
- breather
- strange air leak
- Car paint stripper
- Oil separators ; What do they do and which is best
- Cosworth management conversion won't start HELP
- mk2. FRS engine?
- Leak water
- 89 spec S2....stereo wiring
- Anyone own B88 OLM Series 1 Custom
- Looking for my old RST, G667 PDH
- renew brake pipes and connectors
- what gearbox
- trying to trace my old escort rst mk2
- Master cylinder/brake servo S2
- Coilovers
- T3 Turbo Rebuild...
- Radiator help
- Water temperature sender
- Fitting bailey breather with cossie management
- Mk5/6 servo
- zetec head spec for 500+
- Changing management
- Janos new work address
- Clutch bedding
- mfi-efi adaptor plate stud length
- dashboard modifications
- newbie here from scotland
- Ford Orion EFI…makes things easier to turbo/Zetec?
- S1 Suspension
- RS Turbo requiring some bodywork, Any Bodywork recommendations BARNET/HERTS Area
- Looking for G306FNO
- S2 fuel pipe
- Missfire.
- 17' RS7's
- turbo identifacation / spec
- ST170 Brakes under std RST wheels???
- my Ported Polished Cylinder Head
- MFI Wiring Help
- Battery keeps going flat
- Re trim
- Missing Pipes/Parts
- Transmission crown wheel
- little knocking about
- Magnex, Mongoose, Scorpion the best is...
- Rs turbo in oz
- Engine modifications before dyno
- safe boost on std pistons and rods?
- charging query
- Rs turbo diagrams
- lean on one cylinder (mfi turbo)
- newbee here, hello all
- Morettes
- Spot light fitting
- Conrod bearings and bolts
- Burton valve springs & ford finis code
- Advice on brakes please !!
- S2 Calipers
- Is mine the right big end.......
- S2 otto/mini champs
- Dead dashboard on S2
- Brake booster S2
- Hello
- New mats
- Loom question
- Mtx shifter in rs turbo pic please
- turbo exhaust housings (t3)
- Xr3 Camshaft fits Rst?
- Hello from Germany
- Which release bearing for an IB5 in an S2?
- trigger wheels tacho output loom
- heated front screen
- FRS gt25 in escort s2
- setting up timing with lower cambelt cover missing
- 36-1 trigger wheel
- Hot start enrichment
- zvh
- Rollers in 7 hours then croft in 2 weeks....
- bolt sizes for seatbelt mounting points
- excess vapour or white smoke???
- Washer pump problem
- Standard pistons with forged H rods?
- Help please on brake servo
- weird coil wiring
- Spec afr numbers
- vernier pulley
- EFI running issues...again
- Breather oil return
- Heater matrix outlets
- Boost hose clamps...
- S2 sunroofs
- maxspeeding H conrods on std piston
- Efi inlet....?
- flushing my ford escort 1.8d heater matrix
- Alloy quarants
- when have to use low comp piston
- melted piston
- full mfi conversion
- Seat belt
- bigger throttle body in RST IMF
- inner cv joints
- Engine conversion choices
- WTF help please
- Sort of a Noob! Back with White Lightening
- Think im seeing things
- Wiechers Strut brace.
- Latest comprssion results, major advice needed please guys.
- T34
- AFR system
- new member - new toy!
- Actuator to weak?
- Any good?
- Front and rear strut braces.
- mef motorsport coilovers
- 2wd cozzy turbo fit
- Another FRS brake question
- open my engine (scratch picture)
- Cozzy blower or not to blower............
- Avoid avoid!
- Turbo unit...........suck, smoke..... £
- S2 heavy breathing
- Cvh exhaust manifold gaskets
- mtx gear tooth per revolution
- series 1 servo problems
- Booked in for setup but they dont adjust the fuel ?
- ISCV and fuel pressure reg on ZT
- K&n induction kit
- got mondeo mk3 callipers struggling with bolts
- S2 rear anti roll bar
- S2 fuelling issue
- fuel pump
- ib5 gearbox for our s2
- mk4 efi fuel pump max bhp
- best cylinder head stage (setup)
- 2.1zvh no spark
- Low temp thermostat
- Carb conversion on an S1 RST???
- Long winde question
- advise please
- Turbo just died :(
- Knacked valve and next step advice.
- Thermostat Choices on a ZVH?
- which way round do you fit lowering springs
- rs turbo cutting out
- Suitable for a zetec?
- Boost Gauge
- All the gear no idea......
- Tickover.
- Problem and question
- can i just adjust the actuator for 10psi??
- Yet another Clutch Thread; Choices besides a 4 Paddle?
- what next step engine modif
- S2 Fuel Pressure Regulator
- A R T in Wakefeild ..............
- Fuel computer MFi or EFi
- Help: steering column bushes
- Vintag for S2
- Rear brake shoes
- what contains asbestos in engine
- boost controler ?
- Not Another Biting Point Thread - Low point on S1 RST
- Help pleas
- Transit connecte starter motor
- Lucas or Bosch Alteranator?
- Indicators
- Oil cooler short water hose
- Washer pump earth
- Turbo conversion
- Help with management for converting my s2
- Sensor help PLEASE
- On the rollers
- Steering column help
- Bailey Breather cleaning.
- Washer pump issue
- Rear tie bar removal.... Thickie moment alert.
- which ignition advance ?
- air filter
- efi conversion help fuel pump
- Focus rs box into series one.
- tca's
- Vibratechnics
- Help, memory's shot!
- Megasquirt question regarding VE table
- Compression test results advice
- S2 wheel casting
- Overheating
- Best gearbox?
- Ap clutch finally fitted
- Fiberglass Tailgate
- Dashboard screws
- Rear brakes
