- What colour for my S1?
- Pics of the M-Tech Megasquirt ECU
- stack rev counter help
- How long do i look before i give up ?
- Efi Turbo Cab
- ABS Removal/MOT issues
- escort rs turbo
- runnin EFI
- Black ECU
- BHP Estimation & chip spec??
- Vsport Boldon North East
- Car running very very hot with GRS front mount cooler.
- Blue Wire To Alternator, no battery light
- Front Crank Shaft Oil Seal
- Help Fitting New Exhaust
- s2 fuel gauge
- Double valve springs for floating valves?
- Tuners in Somerset area
- S1 Advice
- exhaust manifold
- Can I weld the wastgate shut for an ext one?
- 2 litre zetec
- "black" ecu
- Best Cams For Zetec Turbo
- piston prob
- are xr3i/or any 1.6 the same as a rs turbo oil pump
- conrod end caps
- Stalling problem
- what strut braces are you using?
- 9" rear drums/ wheels offset
- Turbo pipe that fits ??
- clutch pedal adjustment
- Poorly RS..Please help...
- roller bearing turbo
- boost limit ???
- Carbon Fibre Door cards Fiber
- turbo limts?
- Turbo best for the Erst?
- Is an ERST radiator the same as a standard 1.6i
- can i just change my crank?
- safely adjusting boost?
- Airtec intercooler
- corrado vr6s
- Overboosting!!!!
- my bird new rs what ya think
- 2 stage boost
- Gearbox bolts/ juddering
- help needed
- rod bolts ??
- RS Turbo (S1) racing gearbox
- motorcraft clutch
- mk4 rs turbo
- Dump Valve Help
- radiator
- Springs!!!
- Oil return hose?
- cossie management on rst
- borg and beck
- need some help with my bonet
- thank you M-Tech Automotive
- Series 1 c242 aec anyone know it?
- another s2 problem...NEWMAN CAM???
- Ignition sequence on S2
- S2 electric windows
- fuckin s2!
- clutch
- Problem with Boosting - possible turbo death?
- Geabox limit
- Wiring In Gauges
- bottle cap of the brakes & Wiring loom
- eeek! bleed valve!
- Temperature gauge not working?
- S1 Airtec Front Mount Intercooler
- Battery trouble
- v tight plugs
- boost problem
- cold start and sensors
- S1 engine mounts. Uprated???
- red silicon boost hoses full set
- Cossie Wheels
- I awake the question again
- allen key size for gearbox (filling it with oil..)
- needs setting up
- camshaft help
- rear chassis leg questions
- ZVH problem - car will not start !!!
- Silver Top Or Black Top?
- 2 stage boost switch?
- what is a bleed valve?
- whats best oil for my rs turbo?
- wheel rubbing
- how many s2 left?
- is it just my rs
- Side skirts
- clutch
- Differences between S1/S2 Metering Heads/Air flow sensor?
- Rear disc convirsion-bias valves?
- escort rs turbo fuel pump fit xr3i efi?
- having suspension rebuilt,where?!
- Cosworth brakes
- exsaust problem
- sloppy rs turbo
- help needed pls
- megasquirt help
- Parts no longer available . . .
- Relay or fuel pump guys ? . . .
- helix paddle clutch
- rottern rst estate
- blue smoke?
- Camshaft problem
- series 1 bumper stops/ over riders
- Smoke in The cold
- EFI Conversion
- inner wing for mk4 escort
- I found steel conrods for £215 delivered :-)
- How to fit adjustable bleed valve?
- Steel Conrods
- compomotives what colour???
- st170 gearbox conversion
- escort mk3 and mk4 wings
- Which comrpession ratio?
- This will probs help me out abit more.
- series 2 clocks
- s1 gearbox in a mk4?
- Which pistons & rods???
- can some one me on advise on changing my crank please
- Hi new here need help....
- where to buy konis?
- Is this turbo any good???
- series 1 cossie turbo!
- Turbo Advice
- ERL MF2 5th injector
- Carbon bonnet on a red series 2
- Indicators, dipped and full beam not working
- recaro moves on its own? help
- Mongoose tail pipe 3.5" or 4" need advice
- S1 Stolen !
- Changing heater matrix on s2 rs
- How many teeth
- organic or 4 paddle clutch?
- What’s the best suitable Chip for my rs turbo?
- Nicks mfi rs turbo engine fitting to mk3 escort technical queries post...
- paddle clutch slippin!!
- ford motorsport s1 dtm thingy
- Advice on ecu chips
- Boot struts.
- Airtec turbo cooler
- ECU/Management Adivce Plz.... Mfi Vs Efi
- did they make a 60mm koni kit?
- A basic setup
- what brakes?
- st 170
- pic of murcery grey mk4 escort rs turbo
- Help please
- omg please help (front mounted airtec cooler)
- windscreens
- Fuel line thickness ?
- how easy to change front wheel bearin?
- Anyone heard of Turbobuildz???
- 300mm discs and 4pot
- 14 psi what bhp?
- RST Rads
- Wheel refurb
- front knockin noise
- nomad 3 gauge holder
- Turbo Advise
- Rear Bearing sutck on Axle.
- Which head gasket St170 Turbo?
- series 1 turbo front suspension bushes
- amal valve used to make noice now it doesnt now no boost
- side light bulb holders
- what wheel bolts?
- which head gasket????
- need rs turbo diagnostics
- any one got morette lights on their s2?
- series1 clutch bearing
- hissing from metering unit
- Air Injectors?
- HELP! Rattle noise,What is it?
- set up at jamsport
- cheap brake upgrade, i know its been asked before!!!
- rs bonnet needed asap
- **updated**no juice 2 injectors
- Alternator help please
- whinin noise
- ?? Cigarette Lighter wiring ??
- series 1 rs turbo brakes
- Do i still need these when going EFI
- shocked
- any one know where to get cheap bearing sets..?
- Tappets on S2 Rs Turbo
- manual fan switch
- Megasquit base map for RST
- big end bearings goosed!!
- just joined
- wont start
- Woodruff Key needed
- Rs Turbo Conversion
- Brake pipe diameter
- suspension
- fog lights
- my fuel pump prime sounds weak/non runnin rs
- torque setting for the front hub nut..
- What injector?
- ajustable suspension
- High pitch buzz on boost!??
- Lads and lasses
- fiesta rst rad fit a escort s2
- Speakers
- MFI XR3I Mk4 to MFI RS Turbo Engine
- S1 Parcel shelf colour
- Anti roll bar
- Morette headlights new indicators required
- cosworth manangment
- Where to get s1 tie bars???
- ZVH finaly started
- 3 way bleed walve
- Are cossie brakes on a s2 really much better?
- fiesta ecu on mfi? will it work?
- RS Turbo headlights not working !!!
- high volume oil pump
- Advice please
- Whats involved, s2mfi to fez efi conv
- stainless manifold
- missing !!!!!!!
- efi or mfi??
- fans not workin?
- interior
- zvh in escort
- concours s1
- fuel pump
- Tony Turbo's fan club
- rs not firing
- mahle forged pistons..
- air leak?
- rs turbo series 1 engine problem
- Brake pipe clips!!
- what cam
- New Engine what can a safely expect to push BHP wise?
- What are the best rims on a black S2?
- tyre sizes again !!
- Factory RS Turbo Fuel Computer
- replacement flywheel
- adjustable TCAs
- rs turbo colour change
- heated windscreen
- Front link kit?
- Poorly running RST...
- easiest way for efi
- What size tyres do people with 16s have?
