PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52] 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. To all turbo owners . . help!!
  2. Cooling system issue
  3. RS Turbo Radiator?
  4. con rod confusion
  5. My RS
  6. ahmed springs mk4 escort
  7. what cam
  8. efi what are the gains?
  9. smoking issue please help
  10. What for steering wheel
  11. my rst
  12. anyone got one of these heater vent gauge holders
  13. Rs turbo tuning
  14. Fitting a head and timing up with a vernier?
  15. Escort RS turbo 2.0 ZVH conversion
  16. window wiper mech
  17. Series 1 restoration C666SMX completed
  18. Coolant Sensor
  19. cross linkage
  20. t3
  21. GReddy Boost Controller
  22. My new S1
  23. std rs brakes, what pads are best????
  24. Inner arch covers
  25. Fuel pump relay bridge...how?
  26. what samco's
  27. overheating a bit
  28. series one injectors leaking?
  29. off for a rolling road tune on wednesday
  30. fcuking car
  31. raised bonnet opinions please
  32. MK5 wannabe rs turbo
  33. oil cap pops off
  34. carbon fibre
  35. inner wings
  36. B&M shifter problem
  37. brake loading sensors
  38. clunking noise from underneath
  39. headlight/sidelight not working.
  40. My new pick up
  41. Think my cam is worn?
  42. Making more power S1 RST
  43. Chassis legs
  44. escort rs turbo running problem...help
  45. starter motor heatshield
  46. Where to get uprated springs for zetec turbo
  47. Rev counter goes mad, cd player suddenly turn off. . .
  48. Advice About New T3 For Rst S2 Standard
  49. std oil cooler? limits
  50. anyone know a good tuner in my area?
  51. mk4 escort in preston area ?????
  52. turbo
  53. s2 not sure
  54. Windsceen rubbers
  55. new bonnet
  56. Who/where can convert Mk4's to RWD
  57. Pics of my RST now its alive again!
  58. oil
  59. zetec turbo torque settings
  60. Actuators & Tuning
  61. engine converstion electricans please help
  62. brighter lightbulbs
  63. head bolts
  64. zetec bottom end
  65. sorry zvh parts question
  66. Suspension with 17"s
  67. mtx 75 box in mk4 rs
  68. poly bushes
  69. Speaking of none connected wires....
  70. wiper fault
  71. S1 problems.
  72. parts
  73. What are these and where do they go?
  74. Heater blower motor problem
  75. Any ecu?
  76. put some new wheels on the series 2
  77. underbonnet insulation
  78. Horn Trouble
  79. bailey header tanks
  80. Dash/Clocks/Heater Controls etc..
  81. crossover pipe/inlet- heat wrapped or not?
  82. s2 mfi injector seals? Where from?
  83. rear wheel bearings
  84. thermostate housing
  85. Knock- is possible in this case?
  86. Shortest alternator Belt?
  87. fan switch i guess
  88. Oil Cooler Radiator On Rst S2
  89. Head bolts
  90. TPS - anyone got one?
  91. s2 temperature gauge not working help needed
  92. Hesitant Acceleration
  93. dumpvalve
  94. S2 final issues
  95. Amal valve problem
  96. cossie disc upgrade on a rst?
  97. Springs in Zetec Turbo head
  98. help
  99. off the top of your head
  100. Mk4 RST Suspension Alignment Settings
  101. water temp broke
  102. Vacuum/Boost hose to ECU
  103. engine oil for a S1 escort turbo
  104. No speedo?
  105. head gasket and cam info
  106. BUZZIN!
  107. mud flaps
  108. series one fuel relay help please...
  109. Fuel Pump relay
  110. Cooling problem for my Rs
  111. anyone help with missfire
  112. how much brake fluid?
  113. Huston We Have A Problem (again)
  114. gearbox oil
  115. What do you guys recomend?
  116. S2 Aluminium Radiator
  117. starter motor anyone? pmsl
  118. What will standard Rod bolts take?
  119. how many series 2`s are there left ???
  120. alternator issues
  121. leaks
  122. couple of pics of my s2 rs so far....
  123. Gear stick
  124. RST Battery, anyone replaced 1 recently?
  125. PACE Radiator replacement/repair question
  126. holy
  127. After 8 years my S1 RST will boost again - 2.1 ZVH - forged
  128. Springs
  129. rocker cover bolts
  130. lowering springs
  131. drive shafts
  132. bleed valve
  133. Engine bay pictures
  134. MFI to EFI fuel pump? Also rear Brake bias hanger thing.
  135. I have 270mm Vented Rear Discs......
  136. s2 dimension
  137. Fuel Pump Relay
  138. 16v complete zetec engine to S2 rst
  139. FTO, Christan, Tim, Oille
  140. ht leads
  141. fuel pump relays
  142. gearbox mounts both the same?
  143. RS Turbo Decal and Badge
  144. s1 wheel pic's
  145. who has water injecion
  146. rreverse problem
  147. abs
  148. rs turbo injectors
  149. what oil in a zvh?
  150. arp stud and nut kit for 1.6 cvh!
  151. Fuel Pump Relay Keep Blowing???
  152. wanted mk4 escort suspension tops
  153. Roof
  154. autospecialists water hoses
  155. oil getting everywhere
  156. oil getting everywhere
  157. Intermittent stalker
  158. cossie brakes on S2 under standard wheels?
  159. Light Relays Probs!!
  160. what exhaust for my s2 escort
  161. lowering compression, s2
  162. Bailey Oil Seperator/Breather Hose Size
  163. Idle Vacuum
  164. round caps for s1 side skirts???
  165. will a series 2 box fit a series 1
  166. baffles
  167. How much Coolant Water due to Replace Hoses
  168. Escos Monte wheels on an s2
  169. puttin new selector on my RS
  170. sometimes crunches in reverse?
  171. ive got 1 of these steering wheels
  172. Side skirt and widekit mounting for RS turbo
  173. Engine Convertion. 2.1 ZVH
  174. Adjusting linkage sticky???
  175. f1 cups and s1 arches
  176. junking ABS
  177. Anybody got any pics of a bladed antiroll bar setup for a ERST?
  178. fuel pressure
  179. HELP! setting gear linkage
  180. Just been to look at a s1
  181. Looking for CVH quality lifters...
  182. wot oil do you guys use?
  183. Zetec turbo breather help edit: more pics
  184. What Clutch????
  185. RS Turbo running on 3 cylinders?
  186. whats it all worth???
  187. S2 On A Classic Policy
  188. dashboard swap
  189. think ive had enough
  190. Breather Venting Help MFi
  191. Will i need a plate for my exhaust?
  192. where can i get....
  193. System 2 1.9 Power Engineering
  194. wipers wont work.
  195. car setup
  196. Freeing seized clutch - S2 RS Turbo
  197. Why is there a gap on my side skirts?
  198. S1 Ecu On To A S2
  199. why is my camber so out?????
  200. plastic windows
  201. Gearboxes
  202. using turbo diesel gearbox
  203. which exhaust makes more noise??
  204. 90 spec h plate rs turbo
  205. sunroof runners & efi clocks around norfolk/suffolk
  206. poor idle and stalling
  207. I hate fords!!!
  208. Fucking car!!!!!!!!!!!
  209. Im leaving the RS Scene :-(
  210. s2 keeps throwing out of gear
  211. Cosworth Managed Escort Turbos
  212. missfires
  213. Anyone else got something 'not working'??
  214. indercators
  215. temp gauge stop working?
  216. identifying a 1900 block
  217. Charge carrier advice
  218. pop out windows s2
  219. Cheapest place to buy powerflex full kit for S2 turbo?
  220. anyone got escort front screen laying about?
  221. rs turbo rear roll bar
  222. heater and fan not workin
  223. Rattles???????
  224. Rolling Road Tune, or actually rolling car
  225. Air Filter Help Needed
  226. escort mk4 lowering springs??????
  227. bigger brakes - whats can go on?
  228. anyone got an rst rocker cover they dnt want
  229. Oil leak.
  230. Lockable aluminium fuel cap
  231. Temp Gauge goes up when I turn the lights on!!
  232. Cosworth management question. I del control valve not plugged in?
  233. Series 1 Front tie bar
  234. MK4 rs turbo handles and xr31
  235. EvolutionChip how many Psi
  236. roll cage for series 2
  237. Priming an oil pump
  238. Focus Smell
  239. turbo spluttering and back firing ?????
  240. Im New So Dont Hurt Me
  241. how much for 2.1 engine?
  242. Gmax suspension kit
  243. Snap off boss
  244. MFi injectors reference?
  245. how do you make a mk4 handle?
  246. Where to buy a distributor?
  247. best suspension ?????
  248. Safety Devices Rollcage.....
  249. high idle
  250. EFI conversion price
