- Lack of indicators, rad fan and heater fan!!!
- Think i have met my match with the toad ai606
- Anyone done there own cvh head work?
- This Feckin car! now have Gearbox oil leak!
- just lowered my s2 50mm and she is riding arse high
- Recon this breather/ catch tank is any good?
- oil temp gauge
- Why does my oil cap blow off?
- Lots OF Grey Smoke At Idle
- Sloppy Gear Stick
- S2 rs turbo rear anti-roll bar bushes
- rs turbo adjustable anti roll bar rose joints
- Double Capacity Cooler?
- which turbo on escort RS
- anyone knows who owns this
- airtec cooler question
- rs paint
- Oil Pumps! As my last thread got WAY off topic!
- RS Turbo rear wheel drive conversion help !!!!!!!!!
- grs intercooler fans
- What do screamer pipes do?
- Installed boost gauge and am AMAZED at the results.
- dump valves?
- CVH Cams
- Engine advise needed
- Outer CV Joint info on 1988 RST
- Leaking sunroof
- High Pressure Oil Pumps
- Nuts and bolts help!
- ppls i need help!!!
- focus rs wheels
- how can i tell? pic added
- yipee
- Series 1 Wiring loom!
- bailey breather on efi engine
- I know these are rare but......
- s2 starting prob?
- do xr3i springs fit an s2 rs turbo?
- Anybody have a radio with 7 inches screen in a S2?
- Fitting a Bailey Oil Breather {Help!}
- What engine
- series 1 brakes
- series 1 owner
- need new reggy plates
- mk3 and mk4 boots
- starting problem help!! series one turbo
- 8v or 16v zetec?
- Anyone got an AVC-R?
- rear disc brake issues
- high pitch squeeeeeeek!!!!
- Fitting 170mm Speakers
- series 1 smoked lamps
- G677 XTN still around ???
- camshafts
- brake problem help!!!!!!
- Help! I've lost the clip off the throttle cable!!!
- zetec turbo project
- S2 Sticking wastegate......
- zvh turbo conversion kit.
- How to install seatbelts?
- ib5 with rs diff question
- Focus rs engine
- anyone dealt with chipped uk? They are good by the sounds of things.
- Pathetic Oil Pressure!!
- TROUBLE with Parts
- Gearbox differences Now with pics
- Where does this pipe go?
- where do these pipes go to?
- rare parts for series 2
- few problems with my new rst
- adjustable TCA's
- Ebay oil pumps
- would these fit??
- Bearing Caps needed!
- pre-turbo water cooler
- Engine Problem
- New project...
- Engine questions
- antifreeze stain
- I've tried everything but it won't start!
- Anti Roll bar?
- Headlamp block out??
- after some management for my s2 or should i buy a cossy
- running probs
- pace half width intercooler wanted
- Engine queries
- ignition leads etc
- Big Thanks to TWINS!!
- Right do i do it???????????
- uprated cossie brakes?????
- zvh turbo megasquirt question
- Bottom arms, same as mk3?
- zvh turbo christmas list
- I know this isent right forum but!
- is this ecu chipped?
- fuel pump question?
- bottem end?
- which oil pressure gauge...
- battery help.
- gasket between engine and box?
- fiber glass boot and bonet
- AP Racing 4 pot 330mm disc kit
- Adjustable TCA question's
- S2 running shite!
- rs turbo t34
- what engine oil should i use
- what do i do
- high torque starter motor???
- 1800 zetec conversion in to rs cab?
- need a induction kit
- series1 and 2
- Different RS Turbo Gearsets?
- rs stearing wheel
- oh no!
- clearances on soild lifters
- Are 88/90 Spec clocks interchangeable?
- Ofab chip on ofac ecu?????
- Temp. sensor
- MFI to EFI
- S2 Flywheel
- Baffled/gated big capacity sumps.
- Fuel computer on right
- starter motor connections/wires
- alternator works? tay the question and the problem
- in need of my rst getting a blow over
- poorley belly
- oil filter water cooled??
- Rear Anti Roll Bar D Bush Bolts
- series 2 rst smoked indicators
- oil pressure
- Fuse box leek!!!!1
- sunroof chanels
- Waxoil
- Engine bay cleaning and "pimping"
- Is it worth buying????????
- Pace intercooler
- head bolts
- brake bleeding wots the best way to do it
- Exhaust manifold nut.
- fiesta turbo & s2 starter motors, are they the same ?
- Zetec Turbo
- no spark help needed
- Bottom end removal?
- Clutch & flywheel choice for 300+BHP
- Top Series 2's
- 16's on a series 1
- coilover sleeve kits
- How come...............
- st170 callipers
- Any one up for a laugh?! ;)
- cream in header tank!
- EFI fueling question
- rs clocks same as efi clocks?
- indicator fault
- how much to lower by?
- T34 to elbow gasket
- ABS
- Rs turbo brakes..... Need help
- starter motor price ?
- roll cage
- R e performance centre
- I have been done like a kipper!
- MTX users...
- some advice please
- HELP HELP HELP!! RSTurbo engine knackered
- abs
- Quick abs removal question & more
- front lights
- estimated power output?
- Fuel pump still pumping/priming after ign off
- 5th Injector
- Polished Alloys???
- do dump valve's make a diffrence?
- gaz coilovers on series one?
- S1 escort turbo intermittent flat spot
- S1 S2 tailgate struts
- Loose piston???
- does anybody know where i can get a carpet for my escort rs turbo
- Quick tuning question
- Size of tyres to fit on 17" diamond cut for Escort Rs turbo
- Escort Cossie Wheels
- f ing head prob
- heater and water temp gauge not working
- Brand new windscreen rubber
- ignition timing
- S2 Clock wiring
- 214bhp on MFI but want more!
- what oil do i use??
- indicators working weird, help?
- efi vs mfi ????
- A different question
- Mintex or Ferrodo pads?
- S2 brake problems
- s1 parts needed please help
- How much boost to run?
- how to convert sierra 4x4 cossie interior in S2
- Fuel Relay effects
- Will fail M.O.T on 2 things
- mercury grey touch up paint
- Intercooler / radiator / fan arrangements
- turbo glowing
- would these fit an rs turbo
- oil pressure??
- Gearbox Oil
- T3 turbo problems
- What wire for power windows?
- Rear seat hinges needed
- conrod off piston
- cosworth fuel pump on a rs turbo?
- no ignition lights
- rst rebuild what headgasket?
- gaz coilovers where from???
- Tachometer under reading
- ZVH Flywheel help please
- Stage 2 RST.
- escort rs turbo 1988 mfi
- FAO Karl Norris
- Radiator Fan Question
- Just Wrote My RS Turbo Off
- guide to changing actuator?
- Help Guys S1 wont start
- Cosworth Fuel Pump
- Bigger injectors
- s2 rear poly bushes
- Cold start valve
- 17 inch alloys in RST S2.
- Simon Lardner's RS Turbo
- wanted s2 rs turbo brakes
- series 1 brakes
- Which Front Mount Intercooler to choose from?
- rs turbo fuel computer
- RS Turbo Cutting out when warm
- which coilovers/suspension?
- Which oil to use???
- rs turbo s2 1990 missfire
- Parcel shelf
- Starting problem
- bridge pink relay/fuel pump
- hammerite hammered gray
- Wanted boot lid
- how to check lsd gearbox
- External wastegate
- What puma linkage for s1-s2
- petrol cap broken!!
- intercooler
- can anyone help plz
- Jamie Going's escort in PF
- RS turbo brake disc size?
- Zetec turbo headgasket
- timing gun
