- anyone had there motor broken into
- ERST Radiator size? Need dimensions.
- Brake pipe union size
- tappets
- saph cossie clocks in my s2
- What is this?
- mfi -2-efi loom switch
- Fitting rs clocks in base spec mk4
- Cam kit
- Radiator Fitting
- RST gearbox clutch release/thrust bearing sleeve.
- AP 4 pots
- Does anybody know?
- Flushing Baileys Breather - how?
- XR3 efi system
- mfi to efi
- adjustable tca pictures wanted please
- GAZ Coilover rear springs - fiesta turbo
- maybe a daft question
- cossie managment
- mfi xr3i rs turbo conversion wiring
- Paddle plate
- B594 DEV S1 Old Owners?
- How can I tell the different?
- 88spec door card price
- where i can buy rear brake shoes & fitting kit (drum brake) for S2 RST?
- Yb S2 fwd
- 250 bhp +
- Fiesta turbo brakes - focus rs brembos
- 17" Diamond Cuts on S2???
- stage 3 cts big bearing box
- Fitting a new speedo cable
- whats a b&m quickshift worth?
- momo arrows on a series 2
- Piper Valve springs with stock cam shaft
- escort value
- why has my rev counter stopped working?
- Gearbox probs
- s2 heated rear screen problem
- Jam-sport
- rst conversion
- Flywheel in a zvh?
- Hello & help to make a new engine!!
- mk3/mk4 master cylinder query
- road v track interiors
- heated front screen
- RS turbo intercooler
- Does The S1 And S2 Share The Same Engine?
- WHAT COLOURS DO YOU GET S1 TURBO's
- What fuel pump for biege injectors?
- keep s1 stripes or take them off?
- speedo reading wrong mph
- Why is it going flat?
- meatering head
- Bodywork question?
- battery drain
- efi running problems
- how to make a d.i.y flamer kit??
- Big power....breathing
- fuel filter pipe to meter unit
- Gaz Coilover problems. :(
- Breather fitting Kit: What do you use?
- Fu**ing RS Fu**ing Turbo's!!!!
- calling all people..i need some advice!!!
- s2 brake pipe/system questions...
- Smoke when I back off?
- efi conversion
- zvh conversion or zetec turbo
- Front suspension on GAZ coilovers
- Starter Inhibitor Switch ??
- car is over cooling
- rs turbo bonnet vents
- baileys breather system
- S2/3i Sunroof......
- What would u fit intercooler or chargecooler on ur s2?
- where can i get a fiesta rs flywheel
- Turbo Transplant To XR3i Cabby
- red/clear rear lenses
- Finally!
- ive seen the light!!!!!!!!!:)
- 4 pot cossie brakes
- Collins -31 actuator
- Heater Matrix question.....
- oil pump.
- actuator rattle
- S2 Cam
- boosting problem after 50mph!
- safety devices
- Advice - puttin rs turbo engine in xr3 convertible
- EFI-MFI head different?
- Should be interesting...
- advice on rear brakes.focus to escort
- Tyres
- changing to stud and nuts
- any one had any experiance with INTERPRO?
- Hello
- series1 intercooler
- water pumps
- Worth fitting justnow....??
- MFI: Remove Oil Cap, Still Idles.... Bad?
- still got miss fire
- Power estimates?
- Kent cams question
- rs with rear brembos
- rear disc conversion/rear hub question...
- s2 start problem
- rs turbo holds back afta 65mph+ ??
- Perspex glass
- lets see your 15's with HUGE brakes
- Engine options
- Cossie Alloys or RS Softspokes???
- Manifold adapter
- cold start
- headlining differences
- Mk3/Mk4 door difference??
- cambelt cover
- 90 spec rear spoiler
- Series 2 issues at the moment, any ideas ?
- where to buy from
- tubular manifolds which one to go for???
- Can you still get new thermostats housings form ford?
- valve ontop of lsd box?
- Crossover pipe
- pic of s2 fuse box with efi loom
- dump valves
- S1 vs S2 LSD
- boost problem??
- where to get my s2 set up?
- rebalancing turbo
- S2 smoking since Bailey Breather fitted??
- Anyone doing or done an underside resto on a S2 ???
- I need you help and advice people.
- rs turbo cutting out
- wheel bearings
- No oil pressure
- how 2 fit oil/air cooled turbo??
- what is the best suspension for S2
- Dont you just love RS's!!
- Rev counter problems when converting to EFi?
- Drive shaft lengths?
- paddle clutch
- EFI injectors
- s2 help
- ARP conrod bolts over torqued?
- Cold start valve-EFI
- front spots..........
- loud clicking noise when change gear
- running problem
- starter not working, no feed at soleniod
- Gearbox?
- dash flocking
- ets for 17's?
- scuttle panel
- Fitted my AVC-R!
- Problems with s2.
- quicky
- Pics needed of dizzy/ht leads
- biggest brakes under 16's with brembo calipers
- Please help s2 rst playing up
- mk4 escort wiring problem
- air temp
- How much is an s2 shell worth nowadays?
- exhaust hanger
- Air filter or induction
- removing abs on s2 rs turbo (sorry if this has been posted before)
- tie bars
- brake pipe snapped!
- scuttle panel
- Advice needed on a clutch?
- front end resto help
- running hot typical rs!
- Fuel tank
- will these fit?
- Alternative FWD chassis setups?
- replaced engine and a few teething problems.
- when it get hot it..........
- quick question about hubs
- Brake upgrade
- Heat Wrap.
- What the hell do i do now!!!???
- Fitting kit for gpa coil magneti marelli for s2
- whining noise when foot on clutch
- how much to recondition gear box?
- efi dumpvalve
- clutches
- wanted; s2 rear hub, and brake transfer bar part..
- blue smoke and rattles
- oil pumps
- Back spoiler
- Smoke on boost, what does it mean?
- efi?
- Afr readings
- what are the best brakes to upgrade to????
- how do u check a coil on a s2
- Fusebox
- HELP!!! missfire
- samco hose
- Been offered this...What do you guys think?
- s2 sounds like a diesel
- mfi inlet
- throttle position sensor
- rolling road near oxford?
- oil leak crankshaft
- Show me your white Escort Rs turbos!
- lets see your installs
- where does the water pipes go
- EFI
- Blue smoke at idle?
- Standard wheels?
- Vauxhall LET Engine in Escort
- best place to have omex 710 set up
- focus rs engine in a rst ?
- samco hose
- mongoose or scorpian exhausts
- Rs problems
- which flexi pipes for a mk6 escort with cozzie calipers
- basic setup for rs escort
- Couple of q's!!
- s2 rs turbo wont start
- Cmpression struts on ERST
- Double capacity to FMIC
- Hydraulic Clutch.....
- Anyone built there own sat nav dash mount?
- black lip on the spoiler
- ABS on S2
- ARP Big End Bolt Lube
- fitting gauges
- What would happen if I removed the ABS belts?
- Wanted si turbo project
- Dump Valve Spraying Oil
- abs removal
- How does this sound??
- Head trouble
- Escort Antiroll bar to outer lower arm Nut
- not amused !!!
- Car down as stolen??
- Car down as down stolen??
- Trying to trace my old car
- best brakes
- rs door pins query?
- boost not coming in till 4k?
- Problems intermittant running on 3!!!!
- wheels for my car?
- whats needed to put my engine and box into an xr2i?
- Painting engine components
- running problem
- S2 gearbox question
- cheapest way to a reliable 350bhp
- Rs Turbo rear light problem
- differences between 2.0 and 1.8 zetec
