View Full Version : Ford Escort RS Turbo
- 4000 rpm limit
- 2.1 ZVH Setup In Midlands
- tyre pressures on a s2 with 17"s
- picking up a mercury grey rs turbo tonite hopefully
- HELP! Rear quarter panel 4 my rs?
- In-Car Detonation Detection
- cossy management parts req'd, where from
- Wanna turn up my boost
- stolen RS turbo in the netherlands
- Focus RS brakes.....
- Escort killing clutches
- break servo master cylinder problem
- S2 Gearbox
- escort cosworth wheels on mk 4 rs turbo? how to make fit??
- Stainless exhaust's
- cossie brake upgrade?
- front damper
- Hose clamp
- Current market price
- tcas mk4 fit mk3?
- erst stem seals
- Problem with cold start injector
- EFI S1 - Hoses
- what do i need to wire a oil pres gauge.
- how do i change a fan from a sucker to a blower?
- Brake system removal
- Anyone thats took a dash out
- new on here were do you post parts for sale
- Exhaust manifold
- ZVH BHP. What is the most power?????
- Powder coating a fuel tank
- Wanted: T3 turbo & escort cossie pump
- will this actuator be good enough??
- help needed, no spark on S2 rs turbo
- Powerflex strut top mounts
- ht lead heat protection sleaves???
- Stud and nut kit
- I'm selling up :(
- Flywheel MFi to EFi
- Parts wanted for my escort rs s2
- New tcas not adjustable
- piping up brake lines after abs removalca
- Power curve explanation
- Turbo Cabby Exhaust
- Got my roll cage back today
- backfire
- fuel regulator
- cossie management
- turbo direct
- mongoose exhaust
- newbie saying hi
- Inlet manifold studs
- rear inner wishbone bushes size
- Fuel pump relay wiring
- escort cab turbo £600???
- Does Anyone What This Is
- adjustable track arms, make front end light?
- faulty lights
- sensors
- help please cvh block
- What do you think of this?
- Inside diameter radiator Pipe
- How do I set the ignition timing on my RST?
- Head Gasket???
- Loom troubles
- Fitting fuel pressure gauge on rst s2 metering head
- how much is it worth...
- escort rs turbo need speaker covers & door cards
- S1 replica arches?
- Little engine help please?!!
- acutator
- for people with airtec mk2 coolers
- gear box
- gearbox oil
- ERST setup
- My 1/4 mile times
- datapost wheels s1 any body got any for sale
- recaro seats
- Running troubles on newly fitted RST
- RST Management info?
- s2 the deck protrusion??
- Horn not working
- how much to have s2 tuned
- fuel tank
- Samco/roose coolant hoses
- rear disc
- rs turbo cam???
- What colour plug goes onto the cold start valve?
- Quick help plz as to where plugs go in engine bay
- shitty rs turbos !!!! clutch mod req
- fuel lines
- S2 cosworth
- door speaker covers
- Cossie Brakes
- New PF member first RST, fuel metering problem
- Cossie TB - what cable?
- best oil for rst???
- advice please
- How much co2 does a rs chuck out?
- fitting oil breather tank... '''help'''
- What turbo hoses?
- runnng in oil
- gave the rs a good clean today
- What way to go with the escort
- Mouldy Series One !!!!!
- My new intercooler airtec
- car batteries?
- roll cage
- C471 AVR Series one RS, anyone know it???
- 1.3/1.4/1.6 cvh sump same as rst?
- S1 Bare Head vs S2 Bare Head
- Brown rear windows in S2
- Some help please - running problems
- fuel adjuster on meetering head s2 needed
- roller rockers for cvh
- s1 dials ???
- will beiges be alright?
- roller rocker to cvh
- Another boost problem
- disc's to drums
- motorsport rocker cover
- Valve spring seat pressure turbo application
- Where to buy this ???
- Quick re-shell questions
- Clutch.. CP2000-8 or CP2000-35 for 200-250 bhp?
- h577hhp
- pulling to the right ????
- Engine running again!
- How do you bleed the abs modulaters
- escort pop pop turbo conversion
- Engine breathing a lot of oil!!! WHY???
- decent set of black leads?
- chassis number in floor
- s2 rebuilt block
- Anyone know what size manifold studs are?
- intercoolers
- Final drive ratio
- Pudding Stick!
- please i need pics of the firing order
- quickshift and wheel bearing
- Rear hub nut size
- ABS removal help!
- turbo timers
- Co2 Adjustment Sensitivity S2 Turbo
- Need one front braided steel hoses
- seat covers
- my cars ticking over way to high 3000revs
- injectors and ecu
- need coilovers for series 2 rs turbo.
- rs cabriolet pictures
- Head work....I'm confused......
- Mk4 RST original Wing
- How reliable can an RST be?????
- Turbo recon
- headlights
- 1900 CVH
- engine block
- which one?(Omex)
- Standard 1.6 CVH bottom end same as Turbo?
- xr3i inlet manifold
- S1 pop quiz
- cossie management question
- Uneven front braking
- best place for new gearbox
- Wolfrace voodoos
- newbie alert!!!!!!!
- ford badges
- plug on the side of the head
- s2 on compomotives
- need adjustable track arms
- front disks warpped
- escort s2 hubs have play
- running in new cam
- need a turbo for a series 1
- standard suspension, opinions please
- mk3 dash carpet and what to treat them with
- RS Turbo Fuel Tank Help
- s1 and s2 bottom end help please!!!!
- For you S1 fans!
- Decal Question
- Std Dashboard Picture
- ABS removal
- Rear brake pipes
- WANTED
- ST170 rear discs and calipers over S1 7spokes?
- would this fit?
- Diff sun gears
- rs 2000 turbo ?
- Where have the Threads and Posts gone????!!!
- Wheel catching caliper?
- HELP, rs s2, starts like a dream when it get warm cuts out
- Cosworth inlet on CVH?
- Plz settle a bet !!
- clutch change and abs question.help please!!!
- Gearbox Question
- Breathers?
- How long will it take me to swap engines?
- Fueling prob with s1
- Just a quickie, aree head bolts re useable?
- newbie hi all
- Lambda probe help please??
- Suspension Interchangability
- how to wire, Air/fuel ratio gauge in a erst
- Help needed with engine!!! Please look
- rs doing my nut in
- Powerflow exhaust
- brake problems
- wheel offset and size
- New engine help
- rs turbo cills
- lowered pics?!?
- cts stg1 box
- Oil choice??
- How Hard Isit To....
- cooling fan idea.
- Ap Racing Clutch or Helix Clutch
- Wheels
- Carbon heater fan cover?
- laguna spliter
- cossie greens
- mfi to efi adaptor plate
- intermitant braking - any help please...
- Cheapest place for bits?
- tuner
- Rebuilding my old bottom end, how do I know what size con rod shells?
- how much brake fluid is needed?
- overheating/idle control
- oil help!
- Trim
- electrical gremlin
- Mk5 disc's on a mk4
- Can I get my engine out the top?
- drive shaft nuts
- braided brake hoses???
- temp guage help
- Gear knobs
- MFI and Boost
- running issuse
- Looking for a garage
- running problems
- Irish racing RST's
- Brake upgrades?
- do these sets fit into a fiesta
- fuel pump issue
- which handles better
- How do i fit afr gauge?
- complete sunroof removal`
- linking clifford alarm to central locking, S2 ERST
- mpg
