PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. boost and revs
  2. Dead Master Cylinder?
  3. Problem with steering axle bearing
  4. worried and dont no what to do
  5. series1+series2 front discs
  6. Anyone got a spare loom? Need a plug!
  7. series 1 overiders
  8. sqeaking brakes
  9. Problems with sunroof trim sliding too easily front/back
  10. s2 efi running problems
  11. Chiped ecu
  12. FAO Christian - help me out here please?
  13. Zvh people with modded conrods
  14. Genuine 200bhp - 0-60 times etc
  15. START UP
  16. identifying rs cranks
  17. keep killing number 2 plug after zvh build
  18. My escort rs turbo cabby 1990!
  19. Dirty header tank
  20. problem with rear lights on ERST
  21. hesitant rs turbo on boost
  22. Brake specialist
  23. newbie clicking noise from amal valve
  24. car wont fire up! start problems with MFI
  25. Knocking noise
  26. fuel pressure
  27. bottom end
  28. Have I munched a cam??
  29. ERST Head
  30. Max width for fans between rad and GRS front mount on S2
  31. ecu s
  32. bottom end?
  33. Release bearing
  34. **HELP** RS turbo EFI OFAC Revving its tits off!
  35. ester oil any good?
  36. Camshaft wanted
  37. local help!
  38. S1 gearbox
  39. Differences between ecus chipped by superchip, collins and bayoo
  40. cossie managment
  41. Lifting a CVH
  42. What boost gauge????
  43. I have as much power with this.......
  44. rod bolts?
  45. Where to get Show finish Vin/colour tags
  46. Scorpion 4" tailpipe query
  47. Random Idle?
  48. idle!!
  49. HKS Turbo Timer
  50. Rear Disc Conversion - brake hoses ???
  51. Getting rid of...
  52. Windscreen
  53. Oil Leak
  54. group a coil pics
  55. turbo water feed pipe
  56. best way of removing a fuel cap without the key?
  57. Bias Valve on my PERSONAL set-up?
  58. Metering Unit Rebuild Kit - Still Available?
  59. rs turbo running probs
  60. rs turbo taps a lot
  61. Heated seats?????
  62. New S1 Member
  63. fitting new cam price ?
  64. irish escort rs turbo owners?
  65. Wheel studs.
  66. timming piper T285 T2 please help
  67. timming!!!!!!!
  68. what to do?!
  69. Turbo advice
  70. motorcraft battery
  71. wobble!!!!!
  72. Afternoon People!
  73. Driveshaft Nut
  74. How much power from mfi???
  75. How low is this?
  76. Boot Brace / rear strut brace?
  77. Nitrous Oxide good idea or waste of time?
  78. ported and polished throttle body ???
  79. erst turbo leak
  80. radiator?
  81. FAO Karlos G.....
  82. Any pics of front strut braces installed.....
  83. Right place to fit fuel pressure sender for gauge on mfi
  84. What Coil?
  85. head gasket
  86. car body repair/sprayers in shropshire
  87. coilovers
  88. the efi plan
  89. intercooooler
  90. head ???
  91. most cost effective managment for a series 2
  92. blue smoke on start up?
  93. abs light
  94. hyperthetically speaking
  95. S2 ecu on a S1
  96. S2 master cylinder with ABS 25mm bore
  97. Are rst stub axles handed?
  98. !! Ignition problems !!
  99. Dont be shy show your fellow rs owners whats under your hood
  100. Front panel
  101. how much power from a standard cam
  102. RS Turbo ABS operation
  103. Whit my mods what do u think my bhp could be??
  104. what clutch
  105. Metering unit
  106. Turbo noise?
  107. Gear stick wobble!
  108. New stage 2 turbo
  109. Fuel Sender/Float Question
  110. Need one of these asap
  111. Manifold cracks?
  112. New rs turbo in the maken
  113. ZVH camshaft pulley spacer
  114. Nitrous oxide
  115. ap racing
  116. Engine problems...
  117. s2 colour code for red
  118. Oil/petrol in boost pipes...
  119. Rear wiper coming on when lights turned on?
  120. What do Rs turbo cosworth pistons look like
  121. Front seat mounting?
  122. autospecialists cvh exh manifold
  123. FINIS CODE for Escort RST T3 Coolant metal pipes
  124. Front crossmember removal
  125. track control arms????
  126. poly bushes
  127. just seen this on ebay
  128. S2 90 spec Mercury grey rear decal colour?
  129. Gutted, My New T3/T4 Hybrid Wont fit
  130. Cooling hoses Zetec turbo
  131. pics of brake pipe route
  132. efi 7 wire plug ?
  133. No dash/ignition lights or rev counter?
  134. AMAL valve
  135. Rs fule tank
  136. what symtoms does a fooked dizzy give?
  137. Rs smokeing
  138. mk3/4 sunroof deflector ID
  139. Accralite pistons
  140. removing S1 Rs Turbo rev limiter
  141. what ARB
  142. Inlet Sensors
  143. parts!!!!
  144. boosting problem
  145. Rip off?
  146. rs turbo keeps stopping!!
  147. what size clutch release bearing?
  148. rolling road monday (problem)
  149. driveshafts
  150. what size wheels are best for a track RST
  151. Over-Ride fan Switch LED question
  152. zvh
  153. Anybody need some body parts?
  154. Can anyone sort my timing out?
  155. pulling my hair out ? help needed
  156. Gearbox?
  157. Engine mods
  158. Power boost valve
  159. Forged pistons...
  160. show me your standard fuel cap
  161. plumbing gauges in (cvh engine)
  162. std airfilter
  163. Spigot rings for Series 2, What size?
  164. Water Spray Intercooler
  165. rst running coilovers
  166. rebuild the 1.6cvh or go zvh
  167. what is difference.
  168. help please????????????
  169. Full body respray
  170. Standard Cam?
  171. rs turbo reshell
  172. Engine set up.....bournemouth
  173. Ford part numbers...
  174. Hello Boys and girls, another s1 project, big brake questions!!!
  175. wow,,, you all need a cvh head like this...
  176. mf2 5th injector question
  177. woodruff key
  178. Ford Escort MK4 1989 Project
  179. people that have rear headrests
  180. pi or jamex springs
  181. minimum head thickness for CVH
  182. can uput the engine and gbox in together?
  183. serria cossie turbo will in fit erst ?
  184. Question about clutch and gearbox...
  185. frst air temp sensor fitting
  186. Wat oil?
  187. Pro alloy turbo cooler?
  188. Cossie compressor wheel
  189. escort cos wheels on series1
  190. brake pipe length
  191. Sump removal
  192. brake pipes
  193. Brake Master Cylinder
  194. powerflex top mount.sorted now thanks folks.
  195. newbie
  196. driveshaft wont come out.
  197. head puzzler
  198. all you efi guys.
  199. Best intercooler/rad/fan set-up + spotlights
  200. hi all brake problem
  201. Cam shaft recomendations
  202. S2 electric window switch location
  203. electric windows mechanism
  204. stripped....
  205. F114 BKY
  206. Stage 2 turbo
  207. turbo problem
  208. Turbo spares?
  209. FIXED!! Intermittent Boost leak?! Tried everything!!
  210. Gearboxes?
  211. erst lowering
  212. Clutch Problem
  213. Spark plugs
  214. boot decals
  215. Anybody Interested....
  216. Offset on mk4 rs turbo rims
  217. AP Clutch?
  218. Help please!!
  219. Struts
  220. Vacuum hose
  221. Mk3 Escort
  222. More clutch problems!
  223. window thickness
  224. Oh dear lord
  225. buyers guide/advice
  226. What to do???
  227. Sump plug problem, new gasket and still leaking..
  228. ERST Cossie Management issue
  229. Headgasket replacement
  230. Oil pumps
  231. MFi engine build questions
  232. series 1 rs turbo
  233. brake fitting sizes.info needed.
  234. no number plate / fine/ points ??
  235. twats and total twats
  236. gutted !!!
  237. Will a Piper cam pulley fit a kent cam
  238. bonnet spacers
  239. Adjusting MFI?
  240. minimize torquesteer
  241. Cone filter or panel filter?
  242. finally had enough
  243. Clutch's
  244. Lost my keys
  245. Check my new blower out! :-)
  246. Mickey, ref GRS...
  247. help needed plz!
  248. how bout this for a 1.6cvh????
  249. gearbox oil
  250. Fuel return to tank...
