PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. What Shocks???
  2. 1.6CVH solid tappets clearances?????
  3. Rear wheel drive S1 videos from Brunters.
  4. What fuel pump for 2.0 zvh
  5. Series 1 ecu
  6. Efi problem when cold
  7. new here
  8. fuel pressure regulator upgrade?
  9. rebuild gearbox
  10. Pics of s2 bumper lines smoothed
  11. Removing mk4 hood
  12. Cheapest and easy brake conversion...
  13. engines
  14. scorpion back box rattling baffles
  15. pec pistons and rods, any good?
  16. starter motor problem
  17. EFi conversion bits, identify please lol
  18. help needed
  19. S1 rs turbo
  20. FAO people with 4 pots on there turbos!
  21. who got pro alloy fmic
  22. roll cage in RST?
  23. Escort Rs turbo G/BOX
  24. T3 turbo help
  25. people who have adjustable tca's and front tie bars.....
  26. Wanted xr3 engine
  27. bonnet stay gromet?
  28. twin spal fans wiring
  29. airtec front intercooler clearance
  30. For those interested in MegaSquirt EFI...
  31. s2 TB Q
  32. mk3 front tie bars !!...
  33. boost hose clamp sizes s2
  34. noisy gearbox
  35. Fitting RS1600i front anti-roll bar to S2 ???????
  36. pik u brain plz lol
  37. front adjustable tca's....
  38. focus rs box in S1
  39. Cossie Brake parts
  40. Where can i get these from relatively cheap.
  41. My brakes are Fubared, which ones to get...
  42. sytech any opinions? gd or bad
  43. Urgent question please
  44. spark plugs
  45. Help ID this part pls. RST2 BRAKES
  46. Oil filter thread size
  47. what is the BEST turbo for a s2 turbo?
  48. what about this?....
  49. Master cylinder...where from??
  50. How much power rs turbo std. bottom end can handle?
  51. question about my full beam??? (flashing)
  52. EFI Accelerator Pedal??
  53. Bolt on wings?
  54. water to coolant ratio
  55. Any1 help? Need RS turbo bottom end complete?any1? please help!!!
  56. setup now runs worse
  57. mainifold removal on s2?
  58. brembo brakes
  59. takes long to start????
  60. 88-spec centre console
  61. efi misfire
  62. Pinn bolt question
  63. Whats this?
  64. 2wd front cossie calipers onto RST Help
  65. Fitting Gotech mini X
  66. paint codes
  67. S2 Windscreen
  68. You guys that rides with EFI
  69. ERS Spotted inGreece (Rhodes Island)
  70. Where can i get a carbon fibre bonnet
  71. Need a few things
  72. tiger stripes
  73. Carbon fibre rocker covers
  74. ESCORT RS TURBO compression too low!
  75. gear change is like stirring soup
  76. Where do
  77. People using omex
  78. EFI inlet idle adjustment
  79. RS Turbo VS Evo
  80. s1 intercooler pics
  81. what fuel pressure regulator?
  82. noisy fuel pump s2 rst ?
  83. engine out
  84. fule pressure?
  85. braided brake lines when you lose the abs
  86. Removing Interior
  87. rarest s2 colour?
  88. efi conversion help?
  89. relay location
  90. scorpion exhaust
  91. Breathe pipe 1987 rst
  92. a.b.s. light
  93. Rear Quarter Cards
  94. recaros
  95. Guys running 300+ bhp how are you putting down the power?
  96. Do you know this car.....
  97. Removing mfi loom for ofab help pls
  98. 88 and 90 Spec dash clocks?
  99. how much for a s2 shell?
  100. Oil leak after fitting baileys style oil breather...
  101. Valve stem oil seals
  102. Changed the engine..cheers bigrys
  103. sump gasket
  104. Will it fit Straight on?
  105. bailey breather
  106. ERST Project
  107. washer pump wiring
  108. 15" softlines on a s2
  109. Anyone flushed their heater matrix before??
  110. RS Turbo rear disc conversion problems
  111. oil out my dump valve
  112. gotech mini x
  113. Pulling.
  114. new clutch
  115. power steering
  116. standard or low?
  117. anyone in surrey??
  118. gearbox help
  119. Rear anti roll bar question
  120. sensor
  121. Oil Sandwich Plate
  122. Rear roll bar S1/S2 any differance???
  123. Escort & Fiesta Offset
  124. Need thread sizes please ASAP
  125. newbie and here my car
  126. Stage 2 T3???
  127. frst and series 2 altenator loom the same?
  128. ap clutches.
  129. Adjusting Metering Unit for 1.8 ZVH conversion help...
  130. bottom end
  131. how do i no when my oil pump is goosed?
  132. help with wiring to fuel pump relay please
  133. what are peoples thoughts on theses
  134. few gotec q's
  135. wat brakes fit behind softlines ??
  136. Replacing front panel
  137. Pic request please
  138. rear washer bottle S2
  139. exhaust valves
  140. front strut brace fitting?
  141. s2 cabby turning getting fuel,spark but wont fire
  142. Stage 3 T3?
  143. efi flywheel ? cps?
  144. help
  145. whats difference mk3 / mk4 shells
  146. Where to get nuts and bolts
  147. rs cabriolet mk3
  148. XR3i Block?
  149. mystery turbo housing A/R 0.48
  150. oil cooler
  151. anti roll bar question
  152. Running With No Stat
  153. Turbo Help?
  154. pics of my s2
  155. Old school TSW wheels
  156. Euro plates
  157. wheel bolts
  158. mr escort rst what u ppl think
  159. Somebody help
  160. Help needed on history of B867 RFH
  161. efi conversion help
  162. torque settings for head bolts
  163. Vdo gauges for escort rst s2
  164. more problems :(
  165. injector o rings
  166. st170 6 speed into s2
  167. amal valve
  168. Are these standard S2 Wheel Bolts
  169. braking problem, the story continues
  170. Anyone got a quickrack
  171. Car won't start...
  172. wheel et!!!???
  173. uprated head
  174. 6 point roll cages
  175. Battery lights stays on but altenator is fine
  176. my rs
  177. 40mm tyres for 15s ?????
  178. Best oil to use in 2.1zvh
  179. Boost Problems?
  180. compression struts for mark 4
  181. favor needed
  182. straight cut gearbox?
  183. mint xr3i. good for rs turbo conversion
  184. help needed with oil pressure and rev counter wires
  185. master cylinder etc...
  186. question about AP RACING CLUTCHES?????
  187. Fuel Tank
  188. series 2 sunroof
  189. MK5 Escort clutch quadrant replacement/Alloy quadrant
  190. does the mk4 fiesta master cylinder fit into...
  191. Lowering Springs.
  192. Facebook?
  193. s2 over heated today,please help
  194. s2 cutting out!
  195. TÜV for LEDA coilovers
  196. Head gasket advice please
  197. Anyone recognise this Immobiliser??
  198. 1.6 cvh rs turbo bottom end rebuild
  199. fuel presser
  200. rs leather 3 spoke steering wheel any one no what boss fits
  201. T3 Turbo Return Pipe
  202. rad help please
  203. s2 rattles when i take foot off throttle
  204. s2 smoking and no boost
  205. overheating, cant find a solution :(
  206. Injectors?
  207. Show me your inlet manifold setups please
  208. injector ?
  209. help s2 running troubles
  210. piper or kent
  211. would they be ok to use?
  212. Escort Rs
  213. s1 no spark
  214. fan fitting pics
  215. Cosworth brakes
  216. where can i get a polished oil cap from?
  217. dump valve dropping idle...
  218. does anybody now this car?
  219. st stripes on s2
  220. little help please
  221. I might be wrong but surely this is too much for this ?
  222. S2 speedo cable?
  223. Fan Relay?
  224. rs turbo in mk 5 van.. engine mount
  225. misfire!!!!!!!!
  226. 88 spec to 90 spec clocks
  227. 300bhp+ turbo's....
  228. Stage 3 Head
  229. fitting a bailey oil seperator
  230. gearbox mounts?
  231. What lights are these?
  232. a-post pillar seal?
  233. Powerchips EECIV Module identification
  234. ofab map sensor wiring diagram
  235. good fuel regulator/guage for the frst rail
  236. erst running problems
  237. timing cover
  238. timing piper
  239. Fan sender.
  240. standard cam with vernier pulley
  241. arrrr non starter
  242. Series One wiring problems??
  243. Cylinder head 'is this true?????'
  244. fiesta turbo shockers fit rs cab?
  245. Fan isnt working?
  246. is the timing different on a kent cam than std
  247. cams
  248. Fueling????
  249. what oil do u use
  250. Twin Fans
