- Oil return bung thread size
- oil return pipe. would this be suitable?
- tom scarlets s1 turbo
- New To The Escort :) Back to my Fords.
- First timmer. wheel bearings
- s2 motorsport edition
- Pic request please
- fuel tank
- possible efi?
- boost gauge reading when idle
- cliffs1's engine
- 2ltr zetec turbo
- s1 shell
- New escort mk4 from spain
- compression readings
- escort rs turbo smoking ...
- Which stage T3 and where from
- help escort rst hubs
- exhaust manifold
- anybody on softspokes?
- fan switch
- head linning
- Fuel Accumulator on EFI causing problems?
- confirm a few aux hoses please guys
- MK1 Fiesta Turbo "Field Motorsport" for sale on ebay
- two small parts needed guys.help
- 23.8 master cylinder will it fit s2?
- series 1 question please read and help
- RS Front Spoiler
- RS Turbo cross over pipe difference ??
- RS Turbo drive shafts difference ??
- Trying to find ebay seller-braided fuel hoses!!!
- Fuel pump connectors
- Urgent help required efi
- whats the size of standard rst boost hoses, id please
- filling gearbox up
- best way to stop the oil leaking from the oil cooler
- where to buy a rs turbo t3 oil drain hose
- for f**k sake
- Indicators stop working when i press brake pedal
- high idle on my rs turbo.why?
- Engine rattle at 2000rpm
- Oil?
- monte carlo cosworth alloys on s2
- corbeau revolutions/kirkey race seats
- Whats the better piston. C20XE or Accrilte?
- Dare I say it, I fancy some graphics
- 90 spec header tank on 88 spec s2
- Cosworth fan switch in S2
- gotech on s2
- series 1 radiator same as mk3 xr3i??
- 82oc thermostat for s2
- clutch
- What a shit day!
- s2 overheating
- gearbox
- Series 2 Speaker Sizes
- brake pipe set out.help please
- Pistons wanted.
- Change oil pump with engine in car
- comp on 300+ cvh
- PUMASPEED high pressure headgasket any good...?
- CVH bottom end
- Radiator Fan Problem!
- Reading fault codes from S2
- astra gte digi dash in mk4 escort
- rocker arm
- flocked dash
- 22.2mm vs 23.8mm Master Cylinders
- Mk3 petrol cap on Mk4?
- spot lights . Help needed
- Part number required. Crankshaft oil seal flywheel end
- rs turbo runing hot & holding back on boost?????
- Zetec Turbo pinking..
- s1 inlet manifold connections.confirm please
- rust bubbles on the roof
- MFI ---> EFI How much £££ and where?
- 3 x Electrical Problems
- boost tailing off
- Gearbox what choices??
- Red s2 h388 efd
- are they any good ERST
- Building a ZVH sump ?
- Loom for fuel trip computer
- Helix Paddle Clutch
- fuel tanks!
- why does this happen ?
- How to bypass my swirl pot as its leaking?
- possible bent valves??
- estimated vale of est s2 pace charage cooler?
- which engine oil
- Shock boots are all thats stopping me!!
- loving my rst on a cold morning!
- Oil leak in-to distributor cap?
- looking for pistons
- rs 2000 rear brakes
- ERST rebuild engine opinions need
- What is the correct
- s2 overheating
- ECU Mapping
- Difference between ofab and ofac?
- FUSE BOX
- cts gearbox question
- running in help
- boost controllers
- Fuel tank
- S2 Jacking Point Covers
- Escort mk4 xr3i efi
- escort mk4 wind deflectors s2 rs turbo where to get from
- Help with gotech
- oil cap blowing off
- bits needed
- my s2 escort help no spark!!!
- help!
- Megasquirt boostcontroller
- carbon fibre bonnet
- since this gets more intrest'' FRST advice.
- RST With rear disc conversion pulls badly when braking hard
- evo6 cailpers fit under 16"s,size of discs?
- mfi co adjustment
- Wasted spark question
- who sells payen on here
- fuel trip computer
- Where can i get the fancy heater box covers
- Where the feck can i get
- Fiesta Rs turbo Overrheating
- mercury grey boot decal
- aftermarket gauges
- actuator fitting..
- smokey joe
- actuator preload = approx boost
- Part no
- Best bodyshop in Blackpool Area
- Genuine tcas
- Different ride qualites in lowering kits?
- can someone help me
- escort panels
- boot latch
- ET25 too small??
- Best Head gaskit to use on a rst
- Turbo conversion ready, mitsubishi td04hl-16t from Volvo C70 T5
- Rear Spring Upper Mounts.
- gearbox mounts
- Whats this and is it useful??
- Where can i get one of these???
- Samco ancillries
- Fuel pump wiring on the pump
- whats next?
- Fuse box
- What Gearbox's will Fit a 80spec RS Turbo? without any mods
- s2 bumper inserts where can i get some
- engine rebuilds
- series 1 towing eye cover
- using water erst s2
- metering heads
- Clear front indicators....
- bailey oil seperator
- Dropping from 17"s to 16"s does it really make that much difference?
- Best wheels for s1
- rusty roof
- people running 300+ bhp...
- Fucking ball ache!!!!
- Broken dizzy
- newman cams...
- Problems fitting my pro alloy fmic
- Which head gasket and head bolts should I use?? Help please
- What Discs??
- Breaking a turbo?
- pro-alloy front mount intercooler
- good garage in maidstone
- engine oil
- S2 shows battery light when i switch the ignition off?
- how easy and long to take head off.
- Setting bias for rear disc set up
- wiring diagram help
- ditching oil to water cooler
- Time For Me To Go!!!
- engine fitting
- EFI Fuel Flow Sensor?
- -40mm springs
- fuel gauge
- Metering head
- black s1 turbo? genuine????
- Series 2 RST Bumper smoothing help please!
- GAZ Coilovers Slight Problem
- Fuel Gauge goes down when throttle is used?
- alternator help. wire's
- Slim line fans ??
- series 1 problem
- NSF Wheel working loose
- Rolling road help please!
- Removing Swirl Pot...
- Identify second tag on slam panel
- zetec turbo help
- RS turbo 0-60 times + Spec
- which newman cam!!
- Escort mk4 tailgate on mk3?
- single pass and double pass intercooler what is the difference
- whats the best shocks/springs?
- OZ Superleggera wheel bolts
- manifolds...
- s1 wiring loom
- big intercooer+spot ligth.Possible?
- setup at jamsport
- zvh exhaust manifold help!
- new t3 turbo (boost settings)
- cvh engine sensor gearbox oil
- jamsports rst demo car has he finished it yet?
- escort/fiesta rs turbo cams
- mk3 rear lights
- s2 runnin prob
- mk3 Escort Zetec alternator?
- Fuel Pump
- Jam Sport??
- HEADS
- Show me your s2 rs ride hight
- act sensor
- Custom s2 loom
- delocking
- Engine and Gearbox mounts
- act sensor
- Polly carbon slider windows
- black shit coming out of my exhaust ?????
- Fuel accumulator?
- whos got morette lights
- Rs turbo sump!
- escort not fueling properly!!
- G345 YHK
- S1 Fuel tank
- Car leaning out on boost? Rich on Idle? Fuel Surging
- s1 gearbox conversion to st170
- Inlet manifold studs
- Which intercooler
- fuel connection quickie
- NEED HELP AGAIN" rs wont strat :-(
- Megasquirt gurus, i need your help !
- help please?
- still LUMPY. any ideas what else it could be.
- new piper cam in s2 needing set up?
- Refurbishing Brembo calipers. What colour shall I do them?
- help... sensor plugs
- Washer jet wires
- TSW Stealths
- have a strange problem?
- "O" ring seal on MFi fuel meter
- s1 not turning over
- T3 Turbo Spares
- overheating!!!!
- T3 water cooling pipes
- escort cossie rims
