- judder in reverse
- stupid pipe question
- Manifold
- mint rs turbo s2
- best stainless exhaust for CVH
- impreza seats into an rs turbo
- any help here is greatly appreciated!
- Rarest s2 colour???
- rs turbo oil pressure
- Baileys inline oil turbo filter
- Smoked rear lights who sells them still
- engine re-build on my erst
- Wheel bearing dust seal
- RS Turbo owners, Fan Switch news!
- Omex 600 and loom for S2 EFI 1.9
- Thinking of swapping my s2 for this what do you lot think???
- Focus Wheels
- 1.8zvfiring order??
- erst engine needed!!!
- rear abs shackles
- carbon roof
- Bad Boy Bonnet??
- What is the best 0/60 rst
- what power can i get???
- timing cover
- Is this ecu chipped?
- How deep in are you!
- Rear Disc Brakes
- It's that time again!
- ATT of Karlos low comp vs. high comp
- escort RST series 2 starting problem
- series 2 exhaust systems
- boot water
- metal clutch quadrant
- Is It Possible To reach 500BHP +
- Inlet manifold question
- idle bit sticky
- Rev gauge
- whats peoples thoughts on woodford garage totnes ??
- wen a garege does a set up with out a rolling road what does it involve
- erst engine rebuild
- Radiator top hose diameter?
- How to fit an oil pressure gauge?
- Omex rev limiter
- wat does RS stand for ???
- think im goin to take my car to alan jeffreys to get setup
- been out for a rip in the beast and it reved out
- Desperate for rear hub!!! S2!
- Alloys and brakes
- poorly erst!!
- Front Mounts
- where can i get window rubbers
- Removing ABS
- converting s2 wheel hubs to studs & nuts
- wen do u no its time for a set up ?
- just a quick 1 on boost
- washed my rs today and its bit wet inside
- s2 battery tray repair panel
- Water temp gauge help?
- cold start valve on an erst
- mfi unit blocked????
- Rear quarter windows.
- putting on the gearbox
- RS Turbo standard wheel width
- none starting rs.!!
- INTERNAL v EXTERNAL WASTGATE
- 1.8 ZVH piston to cylinder wall clearance
- Blue Relay?
- blue wire on starter
- is it dangerous?!?!
- gearbox oil
- G65 AAC????? White S2
- boot lock question
- FAO morph
- brakes on s2
- Hi Spec brakes...will they fit?
- Stud Pattern
- Series 1 rs turbo front screen
- Windscreen from where?
- series two intercooler on series one?
- Lucas headlamps
- cossy brake question
- alternator problem
- stainless steel bolts for s2 underside
- Quick ZVH question
- c820 lvk where are you?
- Rear disc
- locks
- G5 too & g407 okm ?????
- Xr2 turbo trackcar brake upgrade!!
- where can i fit my fuel pump?
- where can i get engine mounts
- change ECU or not?
- body shell
- engine for my rs
- grs intercooler on s1's
- Cams....?
- Rear axle track car
- Where can i get.......
- Brake Advice
- S2 Problem
- Possiple to Buy a decent Escort RS for £1500?
- MTX+ Hydraulic.
- D100 MBU is it still alive
- opening qtr glass green
- upgraded suspension bushes (TCA)
- What do I need?
- what too look for on series 1???
- Rear wishbone??help
- EFi Running problems
- how to fit T3 manifold heat wrap
- Name that cable and plug AGAIN!!
- Which head gasket?
- seats
- R/S 1600 i seat cloth
- wheres my rs
- Questions about ecus...
- Cold oil worries
- s2 white paint code
- How much for S/H OFAB 195 chip
- How to tell difference between s1 and rs1600i alloys
- Alloy radiator
- Spark plugs and engin flooding ?
- Name the cable ?
- any body want a swap
- How much does skimming the head and decking the block effect your CR?
- replacing boost gauge.
- zvh to zetec
- dizzy
- where to get these S1 style stripes
- radiator relocation brackets
- buying a t3/t4 turbo
- cosworth management
- GT2554r on 1.6CVH
- focus rs alloys
- its alive!
- center console with amp
- rear wiper blade sometimes slow- quick
- One thing after another!
- Car wont start ( video inside)
- Inovite st vi wheels??
- how easy to change steering column bushes?
- ecu
- mk6 pedals in a s2???
- REmoving the interior and where to get sound deading ??
- erst which injectors
- RS Turbo transplants
- Series 1 vin plate
- engine cutting out
- where's my chatter gone!
- head light problem?
- gearbox + lsd questions.
- borg n beck
- Recaro Seats
- dealer logo
- Seeking my old S2 RS Turbo F293SJM
- Why chase 300hp ?
- RS4 steering wheel fittin problems
- Electrical problem
- Still no spark.. EFI
- Some a-hole has nicked me jacking point covers!!!
- few pics of my s2
- mfi metering head help
- engine rebuild, spec help needed cam, head, management and turbo choice
- mk3 escort rs convertible
- Choosing colour of my rims...
- cossie radiator.
- a few problems!!!
- new lifters on old cam
- gear selector rebuild kit
- anyone selling a turbo
- Help please! My vents are leaking!
- what's this spring for
- Fitting cossie t3 or T34
- best suspension set up
- Timing belt
- just found my old cab on ebay... gutted..
- Clutch upgrade price.
- Replacing a sill in Essex
- 90 spec spolier
- Rs for sale Guy off here..........
- This is off a rst i know that now
- FORGE ADJUSTABLE ACTUATOR Any good and will it fit ??
- Stupid question has my alternator gone?
- Anyone in essex breaking a rs turbo please??
- alot of smoke coming out exhaust
- rs turbo over fueling?
- just a lil one on my rst
- best efi cvh inlet
- front seat winders
- zvh turbo.....
- S2 calipers and disks
- Smoke, and plenty of it!
- fuel pressure regulator
- 2.1 ZVH How is it done.........
- boot pop
- Rocker cover does S2 fit S1 ?
- Best place for........S2
- Draining my battery on start.
- Heated washer jets!
- s2 rst still wont start HELP!!!!!!!
- fiesta rs turbo HELPPPPP LOL
- needed studs to fit gti wheels
- altenator wiring
- Fastest car for the money?
- mud flaps
- rear brake conversion
- xr/rs metering units..
- idle issue with fans on
- Cheapest place for...
- Black smoke and weird boost.
- S2 Just wont run!!!
- Whats the perfect reciepe for the top speed record?
- is there ment to be a starter heat shield? Hot start problem!
- Few questions...
- Whats the biggest amp battery for rs turbo you can fit?
- Pads
- heater matrix
- what clutch for big bhp
- help fitting powersteering to a RST
- equal length driveshafts
- best non-standard mirrors for S2
- s2 or s1 rst wanted???
- bigger/beter injectors?!?!
- new crank/shells (do i run in?)
- core plug sized
- swirl pot/breather
- std turbo
- Fusebox on a s2
- Anyone fitted Xenon HID kit on their rs turbo?
- Model Cars
- turbo
- Good ebay buy!
- tall block cvh
- Running an engine in
- s2 rst... Anyone got it?
- rear chassis rails need welding
- fueling problem
- Gaz normal coilovers or Gaz Golds?
- do i need a efi adapter plate?
- Bigger brakes on S2
- standard t3 turbo pic wanted
- Is there a difference between 88spec and 90spec clocks
- strut top poly bushes
- problems with exaust amnifold gasket
- diff bearings?
- oil breather
- Speedo cable
