View Full Version : Ford Escort RS Turbo
- help choosing brakes please
- Help! keep blowing exhaust manifold gaskets!!!
- s2 fuel pump question
- series 1 turbo what is it
- Looking to buy
- what oil filter? 2.0 zvh
- central day
- Real Series 2 RS Turbos
- How many are left
- cam belt tensioner and inlet bolt?
- Narrowband 02 sensor
- Engine
- oil help
- strange S2 engine problem
- head bolts
- central locking issues, please help
- Wheels help for a S2 RS Turbo
- Fords bloody prices! oil pump needed
- HT Leads
- anyone stripped a metering unit?
- What do you think about new rs manifold?
- Is my throttle jammed??
- Name of a company?? panels.
- cylinder head rebuild
- MFI plenum on EFI manifold
- erst very strange petrol problem
- is it still around
- 1600i rocker, will it go straight on s2??
- can i use series 2 metering unit on s1?
- focus rs gearbox speed sensor
- megasquirt help
- Steering column
- crashed combi
- Anyone know what this is?
- Handbrake Cable....
- Gearbox mounts
- st 3 engine in a rs turbo
- Thanks national windows! (Photo's within)
- S2 RST On Escort Cossie Rims...
- Another dreamer 280bhp!!!!!!!!
- G17 RST plate any 1 want it?
- who's used 1 of these
- Understeer issues
- S2 rad wanted asap
- s1 alternator brackets differant from a s2??
- Spark problem need help!!!!!!!!!!!
- Some dreamers on ebay
- Has anyone ever built a n/a zvh
- RS Turbo final drive
- Yet more trouble!!
- Brakes
- cold start!
- meterin unit...
- Hydraulic lifters
- Defi gauges
- RST Nuts & Bolts
- valves!
- New roof lining
- Anybody got a wiring diagram for FRST engine loom into S1orS2?
- zvh for dummies!!
- thermo time switch on mfi
- Injector help.
- is this s2 rs turbo ecu chipped?
- Splitter for S2?
- temp??
- 10psi too low for my setup?
- Best coil over spring rate..... ***Help gay question inside***
- High pressure oil pump?
- brake master cylinder
- Can you fit new rs turbo engine with gearbox still in
- 1.6 rs turbo inlet manifold bolts and exhaust manifold bolts??
- Silver top zetec rods?
- Should i repalce this camshaft?
- escort rs turbo ecu,s wiring loom. (xr2t conversion)
- inlet manifold sensors
- Can I see peoples undersides (cars not them selfs)
- dane seeking more zvh knowlede
- Electronic Boost Controllers.
- VXR fuel injectors
- This months FastFord Mag.... RWD Mk3 S1
- what to do what to do????
- EFi wont run after 15mins
- anybody think this forum has gone sour?
- ferriday rover adapter plate help
- Cossie Calipers up for grabs/swap
- Rolling Shell, questions
- Dashboard removal, where the best place to start?
- your fav 16s on a s2
- Turbo elbow to downpipe stud??
- can anyone help???
- rear disc conversion
- wheel size for 1/4 mile
- fuel tank
- EFI/MFI Clutch
- Help please !!!!!!! Oil cooler pipes were do they go ?
- s2 petrol tank
- Last pieces of the puzzle are here!
- Boost solenoid valve
- mk3/4 inner wing
- autospecialist actuator??
- ford parts
- Efi beginner
- Can someone pls tell me where all the earth points on an s2 are.
- ARP Stud Nut's Torque Setting/Procedure?
- arch panel
- uprated rear arms
- focus rs engine an maybe gear box in s2?
- Pink relay! urgent
- oil breather
- replacement turbo??
- Wiringloom RST vs. Bonus
- turbo stud
- Standard T3 - max boost?
- anyone got a s2 88spec shell needing a home
- gutted! update
- Rs turbo LSD details needed, drawings, dimensions.......
- Advice please !!
- square dash blanking cap
- Anyone fitted a Bee-R Type B Rev Limiter before to an rs turbo?
- HELP! insurance.
- What Gearbox for my Zetec Mk4 Escort
- Electric mirrors for the S1; Do they exist?
- Silly question, how heavy is a CVH
- fao morph
- s1 pumping out black smoke
- s2 running rich
- I need to buy gearbox for Escort rst S2
- zetec turbo qs
- gearbox bolts missing
- Water temp gauge doing strange things
- 90 Spec RST Loom Decal
- Master Cylinders
- Question about chips..
- ACT Sensor and Knock Sensor???
- newman phase 4 camshaft ?
- headgasket for erst ?
- S2 sunroof drains leaks
- Nitriding and Nitrocarburizing kent and piper cams
- Well i think poss the time has come to move on .
- What Colour Are The Windows On A Black S2 RST?
- Comments on my handling spec ideas
- what hose to where???
- Gearbox question
- adjustable tca's
- Boost
- Does anybody know?
- MFi fuel mod
- lowered s2 question
- which box is best/strongest for a 300hp s2.mtx ??
- gear linkage s1/s2?!?!?
- What does a bolt standard s2 fetch now???
- Whats the trick ?
- Vernier Pulley....
- Help fuel accumulator leaking
- slight mishap
- flywheel
- rst engine don t start (VIDEO)
- Exhaust Valve must be sodium filled.
- best starter motor for rs turbo
- D433 EEG rs
- oil breather
- battery issues
- Are these plugs ok for my s2???
- full polybush set wanted
- HELP!!! fitting s2 final drive to s1 box???
- brake servo s1
- Gearbox probs anyone help?
- Exhaust manifold gasket
- Advice on how to sort out exhaust mani probs
- Manifold
- Engine rebuild questions....
- What is wrong here
- do you think im making a mistake
- spark plug 4 issues
- fao anyone with cossi managment and zvh engine
- airtec series 1 single pass fmic ??
- s2 radiator the same as s1??
- how to clean out rusty coolant?
- metering unit?
- Escort SE 500 pacifica blue touch up paint
- S1 RS Turbo With No Engine
- Ford Escort RS Turbo Insurance Group?
- Pace doubble capacity intercooler.
- How do i bleed my 4pot calipers?
- forge dump valve?????
- Where can i get a new rack from?
- cross member
- newmans cams
- Series 1 with 300mm discs and calipers
- not starting
- Will i need to rebuild my engine?
- EFI fuel pressure regulator.
- s2 sticker on a white 89 f reg????
- Taken the plunge!
- s2 swirl pot fitting kit
- original bottom end
- s1 arches on s2
- too much torque???
- nitrous oxide , Anyone using it ?
- gear linkage rebuild kits
- XR3i efi inlet same as RST's?
- 88 spec bits needed
- Wiring fault on high beam wire burns/frazzles out!!
- How can i tell which type ECU i need.
- mercury grey rst spotted
- erst engine needed
- Rear anti roll bar Shackles.
- blanking plate
- pipe and air filter sizes
- 1 owner from new, original Escort RS Turbo
- cooling system pressure
- what is a std block worth?
- brackets
- new s2 chassis number next to drivers seat
- Is it just me...
- brake brackets
- Sold my series 2 rst today!!!!!!
- thermostat
- lumpy idle
- fuel pump relay
- Escort RS turbo tunning - help please
- nutters corner
- IB5 Box transplant....
- B road blast
- Have a listen...
- dash board
- 4 Pot Cossie Upgrade
- White Is King... Let's See Red, White, Grey, Blue, Black, Red, Orange, Purple etc. S2
- Installing Top Mounts
- rs 7 refurb
- 700bhp CVH. It's on the horizon.
- H2 LGC
- Exhaust question,
- Lets see red
- 600bhp poss??????????
- Black rs turbo s2
- S2 dashboard loom wiring diagram
- Anti roll bar question?
- Lets see your s1
- fitting 044 fuel pump to s2
- 90 spec sticker on grey rst
- white rs turbos
- HELP!! fitting st170 6 speed to rs turbo!!!
- Pictures and advice wanted for rst buyers guide
- front number plate
- s2 sunroof advice??
- Metering unit!
- how much fuel
- Hey people, not been on for a while.
- fuel filter
