View Full Version : Ford Escort RS Turbo
- fuel pump needed
- Gaz coilover kits
- cvh starter motor needed asap
- S1 gearbox's
- Starnge Request. Diameter of MK3/4 Escort wheel well
- Gearbox - how much oil?
- XR3i / RS Turbo S1 / S2 seat runner questions
- Back box pictures,
- Steel Braided lines, fuel and brake.
- cts gear oil?
- spot the problem
- What bolts for front seats??
- RTTS
- who makes/sales engine bay decals and dealer number plates
- Central day
- Escort gerbox mounts
- anyone had a faulty newmans cam
- running without D/V
- RS Turbo metering unit needed
- rs turbo series 2
- Hey there!
- Wiring diagram
- For anyone interested in MSD's magnetic sump plugs..
- Washer bottle????
- cheap but sweet mods
- Comp ratio??? new boost ??? help...
- whats my s1 worth?
- This place is back on form
- RS Escort cab
- What starter for 2.1zvh
- RS running too cold
- ZVH 1.8 conversion which oil?
- where does this hose go
- Massively overfuelling and missfiring s2
- Gearbox Problem, Oil Temp?
- whats the symptoms of.....
- Engine won't run at full power
- Well........
- New Member with Problems (car wise) ;)
- conversion question
- setting solid lifters (newman)
- Are 88/90 spec spoiler caps the same?
- rs turbo cutting out at traffic lights
- Amal Valve
- Exhaust System
- mfi bottom end to efi??
- can i get smaller wheel bolts?
- Knew it wouldn't be long...
- HELP What Brakes lines?
- Colour code
- The strongest & quietest RS turbo gearbox!!
- fuel pump
- smell of fuel from no2 cylinder
- Snapped tensioner bolt
- fueling problems
- Silicone hose v brake fluid
- metering unit
- Ford Escort RS Turbo s1
- Exhaust bits
- RST Single seat race car
- smoking issues!!!!!!
- HELP rs turbo not boosting
- My S1,
- Show us your zetec turbo thermostat housing...
- Anybody know this car- my new project,,,
- suspension set up
- temp gauge not working?
- Brake fluid DOT 4 or DOT 5.1
- are these rare ? rs turbo s1 anti roll bar ?
- Cosworth Management/Loom Question
- not sure what trottle bodie to use
- Red 90spec front bumper needed!
- s2 clutch removal?
- custom bias peddal box
- Series 2 ecu
- welding up a s2 rs turbo,advice please
- collins powerchips monitor
- all nice and shiny
- FRST - Oil light / Pressure Switch
- I Need A S2 Loom!! Anyone Got One?!! Cash Waiting!!! PM Me ASAP!!! :)
- efi engine oil return
- amal valve restrictors?
- bought another one!
- anyone know what these do?
- tartin up under the car
- saw this earlier anygood?
- Help s1 rs holding back on boost(under load)
- Need help wit escort rs turbo s2 mfi
- FRST ACt sensor
- which clutch is best?
- Tips for removing fuel filter
- bit embarrasing!!
- Best intercooler for my s2??
- Rear inner arches?
- MS and EFI clocks Rev counter wiring
- AP Racing CP2000-8
- would this be a good spec?
- another bull SH*TTER
- Rst Reshell
- Washer jets and pipes
- s1/rs1600i mint dashboards
- showtime
- would i need............?
- Escort hubs
- s2 paddle clutch sliping i think
- what does the throttle position sensor do?
- s2 airbox
- 40mm springs
- Eibach springs
- Inlet hose
- Recommended oil for RS Turbo
- Just a little update....
- HELP rs turbo radiator needed!!
- it will not idle under 1500 revs plus when up 2 temp starts pulsesating
- AE Map based or TPS?
- Welding....advice please
- s2 rs turbo wont turn over by key but bypass/bump starts first time
- starter motor needed
- Engine won't run properly.
- Blue smoke when pulling away
- Floflex
- Removing waxoyl
- does anyone have a erst shell?
- Got to try my Quiafe ATB tonight!
- Another Ebay TO**ER
- Rs turbo running poor
- -31
- How to lower my seat?
- just a quick one! more help please!
- what do you think? compression test done today
- Non starting turbo!
- Turbo Options
- h510 aec
- is there a gasket (efi inlet)
- How to clean inside Bailey oil breather
- Ford Night Ace Cafe London 6th April
- -31 actuator
- s2 heater blower
- best suspension set-up
- zvh to full zetec turbo
- were could i get a t3 stage 2 from?
- water pumps and oil pumps
- standard airbox
- non abs brake fluid reservoir
- head gasket! AGAIN!
- stage 3 t3 or t34 what would be better
- how much bhp roughly can i get from my setup?
- Rear hub and swing arm problem.
- Under car colour coordinatoring
- My s2 rev counter has stopped working??
- Suggestion on what wheels ??
- cheapest place to buy a cam / camkit?
- show us ya pics of 4pot cossie brake conversions
- thermostat housing (bufty)
- to much oil pressure
- Where to Buy Rubber Ford Escort RS Turbo Mk4
- inlet manifold studs?
- no fuel
- Standard air box
- Handbrake cable
- G221 tmv turbo cab
- Bit of a long shot........
- Front suspension question
- 15" Ronal Turbos
- 'another' Whats it Worth..
- Series 1 purchased yesterday
- weighted my car
- opps just spend 3k lol should be able to get 250bhp
- Dumpvalve (loud)
- 2l zetec in rs turbo
- whats it worth?
- Help please
- h352 gec red escort
- Cruise AFR's?
- What EFI inlet?
- Wrong camshaft?
- Fuel Pump Floor Mount
- Thinkin about another S2
- Steering lock?
- whats involved in runing a yb engine on a front wheel drive set on a rsturbo??
- what would you do..
- turbo coolant pipes
- no oil light or handbrake light on dash
- 8j x 16 wheels
- This gearbox any good then???
- Removing dump valve
- S2 Bumper trim
- Missfire on boost
- Hub question(painting)
- need help findin a good place 4 a set up!!
- Need an LSD box...
- A few ZVH questions...
- RS Turbo problem
- Anyone know where my old rst is????
- Oil temp and pressure gauge
- Which Rad
- zvh
- New Servo or upgrade?
- Rev limiter?
- Crank position sensor holder EFI rs turbo
- oil cooler thingy?
- fuel pressure
- Removing locked petrol cap
- engine mount ?
- Car is finally MOT'd and on the road!! Also some mapping info!
- Bonnet raisers yay or nay and do they actually do anything??
- turbo
- 40mm gmax springs
- What Breather?
- Who is hiding all the recaros??
- gearbox problems
- the s1 is staying ... would like a big spec engine.
- 1.6 Carb and XR3i fuel tank differences?
- part to repair collapsed recaro?
- what sort of compression for a 1900 cvh
- 0-60 times and power/torque no bullshit please
- S2 Polybushes
- what paint, matt or gloss for under bonnet parts
- Electr. mirrors removal in rst and fuel pump cradle question
- what would cause pistons to crack?
- cosworth disc and caliper question sorted
- Adjustable fuel regulator on mfi?
- inlet manifold for zetec turbo help
- rough idea of powdercoating prices
- escort RST bump stops?
- Fuel pump cradle
- Efi block. Whos a lucky boy?
- s1 rs turbo gear box
- Are these rare?
- mk4 cards on mk3 doors
- FAO D4RST
- is d4 going to come up with the goods?
- Fiesta brakes on an ERST?
- oil filler cap!
- Some EFi fuel system questions
- will a piper 285t2 cam be alright with a standard cam wheel?
- how do u tell the diference between a single piston bailey dumpvalve+a twin piston dv
- 8x16" comps
- Tony turbo selling his legend of a car..
- (HELP) ANY1 in the southend on sea area
- series 1
- fiesta rs fuel pump s2
- 10/10 gutted
- do the pins come out of the door or do i have to take the door off?
- Drove my car for the first time today!!
- header tank
- Drive shafts
- G25 UUE , anyone know this mercury grey rs turbo???
- rs 7 spokes
- Turbo spec any good?
