- 8" kenlowe fans
- gearbox oil grade series 2
- Brake pedal feel...
- Zvh headgasket
- Earth strap locations - S2 Turbo
- Help me identify this engine / head plz
- Just fitted a paddle clutch
- What to do about engine!?
- Fuel pump wiring
- injector clamps
- How is the S1 intercooler mounted?
- which oil???
- oil pump advice,cheers.......
- Exhaust Manifold?
- new wheels
- Toyo proxes t1r 195/50?
- help please smoking
- what track day road legal drag tyres
- can you make zetec turbo using mfi?
- Timing setting
- should i make me s2 rs turbo rwd?
- help with standard pedal box
- Series 2 Header Tank Bolt
- S1 WHEELS
- 15" steel wheels
- Distributor cap.....
- What et comps do i want?
- Boot decal, update new question!!
- Wat Kind Of Cam
- Hit the limiter in 5th tonight!
- DIY head build and porting pictures inside **UPDATE** finally started
- HELP ST150 Brakes
- metering head!
- advice needed
- camshafts
- rear perspex window with vents.... how rare are they??
- Does anyone know a good bodyshop for restorations up north ??
- repainting/ refurbing coilovers
- i know its not a turbo but WTF
- Groaning sound when bringing up clutch..
- help urgently required please
- New clutch!
- colour change moonstone blue/ diamond white
- RS Turbo Concentric Slave Conversion
- not priming anymore
- FMIC
- Wheel bearings.
- can i make s2 turbo an xr3 again
- rst mfi injectors
- ib5 gearbox help please
- GT28 Range...
- ZVH Head
- efi turbo problem(injectors not firing)
- how to quiet lifters?
- 5w 50 fully syn oil????
- fitting new cam question
- Won't idle
- WHeel bolt size!
- Brake Pipes
- none starter
- Intercooler question
- Cabriolet rear speakers.
- S1 Timing Question/Cos Management
- still smoking!!!!!
- Nice looking s1 for sale
- its getting there ......
- rs turbo clutch
- Headliner
- Exhaust question
- cosworth brakes on a s2
- This guy loves his s1 lol
- Rs xr3i clocks ?
- engine breather system
- an abortion of a rst
- rear strut brace
- Thinking of going 16" alloys, what do you think of these?
- Fitting a Front mount
- whats the best cam choice for my car and spec
- Am I going to have problems mounting an actuator now...?
- Ford EFL oil filter number for RS Turbo ???
- Best Intercooler for me
- 16" mondeo alloy wheels pics
- no ignition??
- whats the best engine oil for a rst 1987
- charge carryier pipe and dump valve
- windows stuck down
- Fuel return pipe
- hard to start
- a big hello
- gold membership
- Head experts update block help
- engine and gearbox removal
- 63 People viewing this room!!
- S1 on ebay
- mercury grey bonnet needed
- tyre size on 16 inch alloys
- boost advice needed
- cam belt change
- Charge cooler?!
- Series 2 copper brake lines - does anywhere do a kit ?
- strut top poly bushes
- Dunlop D40 tyre - are they original spec for Series 2 ?
- Rear lower arms
- what colour are your calipers?
- Glass removing??
- Pinking?
- What can i heat wrap
- Engine bay resto, advice please?
- Fuel Pump Connectors help!
- Is it safe to heat wrap my tubular manifold??
- how much to do a mt75 conversion on a s1
- Steering rack for RS 2000
- Phoned ford today
- How much??!!
- How should a RST be painted and finished
- Advice needed
- bottom pulley's with trigger ring
- wtf fuel??
- my untrusty rusty ford!!lol
- service time
- You who run EDIS Ignition
- RS Turbo Starting issues when warm
- Out of interest
- what wheels on rst2 -35mm lower
- Overheating?.....
- Which management????
- ib5 gearbox from a 1.8 diesel escort
- rst and xr3i roll bars
- blue smoke
- Turbo question
- fitting a s1 body kit to a s2 rs turbo
- washers that go on the rool bar???
- B&M shifter mod
- Seriously considering Zetec Turbo conversion
- Master cylinder / servo help
- Gaz Coilovers
- s1 to s2 turbo change
- rs turbo boost problem
- Boost Hose collapsing? How to check?
- need help with my s2
- Rear strut brace
- S2 distributor needed
- FTAO Rick and any other MS users with Bosch 403 Grey Injectors SORTED NOW!
- Clicking fuel pump
- cross hatch cylinder number i have the number.
- Lazy starter???
- heated windscreen wiring
- Master cylinder - ABS
- Does this mean i have to get a new headgsket ??
- Boost controllers
- Fitted my new wheels today!
- This is what happens when your lambda loom gets cought round your wiper motor...
- How to clean roof lining??
- wont start!!!!!
- No fuel ?
- help! parts wanted
- Help regarding efi rev counter
- Suspension Advice
- Another engine rebuild
- Lost spark, and got +12v at both coil terminals!???!!!
- brown gunk in turbo pipe
- Parts and prices questions
- new build/non start HELP!!
- 1.6 escort rs turbo cvh s1
- Cross hatch cylinder head???
- Bhp reading ...
- help?whers the idle mix screw?
- Help!!!
- Seriously considering breaking the Series 2?
- Pod vids of the collins 350+hp Rs Turblower!
- bottom end
- Stolen S1 RST
- ofab management or L8 cossie management
- Clutch: AP CP2000-35
- Carbon bonnet
- What camshaft?
- Braking Escort RST-upgrade
- Wot power???
- Fuel rail
- Rs Turbos Abroad
- Insult or not?
- can anyone tell me what this is!!!
- Rst temp gauge on zetec
- can i put a private plate..G2 ROC on my d-reg rs turbo?
- Love this s2 thats come up for sale...
- Ofac loom same as ofab
- How much oil does a standard S2 gearbox hold ?
- d cup mirrors
- Newman cam and double valve spring question
- ecu output votages
- advice
- escort not starting when its get hot
- water temp sender position..
- mercury grey paint code
- Clutch Release (Thrust) Bearing
- tubular manifolds
- braided brake lines (full car)
- Help with turbo
- Fuel Pump
- Drove with my XR3i box in today...
- mk3 escort introduction !
- mk4 escort introduction !!
- Rear brakes?
- info needed on 195 ofac superchip
- Whats the limit?
- oil preusre gauge
- fuel in boost pipe?
- OEM Replacement Discs
- rs turbo accralite
- In need advice on changing a CV gaiter on my S2!!
- I need help with springs
- Strange fault/problem on S1..
- 1.8 ZVH conversion
- Anyone else running a non rs turbo loom in their efi/cossie managed rst?? help please
- heater not working getting no power help
- Converted To Ofac Efi Wont Rev Past 3000 Revs Help Plz
- Fuel pump
- Amul valve ?
- HT leads.
- fan switch
- PICS! If your going to break a gearbox......
- its alive
- 30mm s2 springs
- Speedo not working
- where do these bits go??
- wiring fans help please
- still smoking!!!!!!
- Central Day = Fail! What IB5 box do I need?
- I will make central day !
- porsche brakes on an rst
- Bottom end rebuilds
- Help with Turbo needed!
- Had a bit of a heart stopping moment tonight!!
- s2 ancillary hose kits
- factory built escort rst 4x4
- Turbo oil return pipe
- Please help you clever people here!
- Radtech intercooler
- diagnostic plug?
- what wheels for an s1
- Alloy wheel fitting kit Team dynamics
- Need new suspension! what to choose?
- fusebox
- Central day, cars and who racing?
- black or white
- Accralite pistons + CR lower(about 7,50:1)
- OMEX wiring help Needed
