- painting my engine
- Fan Size for GRS Front Mount
- Brake padsss
- Brake master cylinder
- reliable RST!
- what chip for spec??
- esrt tail light seals
- new EFI sensors?
- braided brake lines
- Testing throttle switch
- any advice on gauges
- Anyone going to Ignition Xtreme?
- northwest passion ford meet
- Front bump stops
- escort rs turbo getting hottor than normal :-(
- why wont my rs turbo time up? weird problem
- roll cage???
- has anyone owned my rs turbo
- F118 FEC ERST Anyone here know any history??
- my escort rs turbo d418 nkj has anyone owned it
- reborn
- holed intercooler
- a few before and afters
- Stage 2 t3
- Hydraulic Lifters
- dodgy fuel gauge
- which brake reservoir?????????
- Metering head problems... maybe ??
- diagnostic plug/socket
- woooo hoooo another 1
- Piston sizes
- help with cossie brakes on m4 rs turbo
- ZVH Tech Questions
- escort Cosworth wheel fitting.
- E325 KST
- ecu problem
- Going for a setup
- An other question about temps..
- how can i tell
- Dirt cheap rods
- S2 standard trim from the factory
- To break or not to break lol...
- Front window
- wont run right/help
- XR3i MK4 Cabriolet - Servo
- Fuel Injection Module Relay
- Anyone had a BC.box rebuilt by CTS
- Replacing the amal valve with a bleed valve?
- What alternator???
- worried about getting ripped off!
- engine bits help
- another boost problem!!! should i adjust my actuator?help please
- Efi
- new cam going in tommorow. running in advice needed.
- Help needed with boost problem! PROBLEM SOLVED!
- Oil Pump
- 90-spec inner wings
- 300hp gearbox
- new turbo
- Good looking s2 for sale here...
- Fuel pipe to metering unit
- Help boost gauge reads 10psi dump valve goes off but no power?
- what oil breather are you using? what way have you plummed it in?
- oil coming out of rocker gasket
- tuners.
- One of my dashboard screws is rounded off, what can i do?
- got an alternator that fits!
- got it
- oil in breather setup
- replacement starter motors
- Wheel pic request please
- fiesta rs turbo engine
- Slight Cracks
- change of turbo
- Re-fitting clutch and flywheel. New bolts needed?
- suspension question
- Lowering
- Hammerite paint still soft after 3 days!?!
- smoking turbo
- Help with wiring loom
- Piston rings
- £190 for a new oil pump? does that sound about right?
- Engine noise need help asap!
- Been on the rollers today
- blown my turbo
- Where can i get rear quarter and back pannel for mk 4 escort????
- Bit of info required please.
- Valve Clearences with Newman Cam
- efi charge carrier
- turbo seals
- Old Skool RS vs New Skool RS!
- which cam???
- Changing oil and running in
- Help someone
- fuel gauge problems please help
- Magnetic Oil Drain plugs
- newbie with a question or 2
- mk6 clutch pedal
- Hose cutting?
- FAO Electrical guys
- GT 30 on S2
- Sold my inlet
- Is it possible to fit a longer 5th gear?
- Tony's escort,did he sale it?
- 90 spec sunroof bronze tint or green tint?
- Kiln springs??
- Escort RS Turbo Tuning
- ECU fried
- what colour clutch quadrant
- rs turbo s2 roof
- Mercury grey s2 bonnet
- Idle problems?
- firing order
- Fecking car
- Help needed, non starter.
- efi misfire
- Free Stuff to collector
- oil drain hose
- Whats the difference between these two?
- looking at going downt he cossie managment route
- IB5 Hydraulic clutch question!
- is N/A 1.6 cvh head the same as a rs turbo head?
- little ends?
- Cossie brake problem advice please
- Blue smoke after rebuild??
- (ofab) what chip's are you's using?
- How much power can a standard S2 box and clutch cope with?
- S2 RS turbo on ebay
- Tunning escort rst takeing to nobles
- restro thread had enough going to brake it
- i want a sreamer pipe for my s1
- Coolant tamp sensor plug problem
- double capacity intercooler fitting??
- efi idle
- fao anybody using electronic speedo
- best place to buy new oil pump?
- flexi or no flexi
- cvh flywheel
- piper cams, buying online ?????
- smoking
- Need parts!
- Escort Turbo Smoking PLEASE HELP
- What turbo and housing is this? (pict attached)
- COMPANIES to uptrate RST 1.6CVH MFI to EFI COnvertion - NEW PROJECT
- escort running hot
- Fed up with my car keep breaking gearboxes.
- another alternator question
- Metering unit help S2 rs
- anyone that know's EFI rs turbo blocks, can you help me?
- oil cooler hose
- Engine management question
- Apex lowering springs???
- s1 arches on s2
- Another s2 heat problem
- running hot
- Fan switch plug
- cheapest place to buy new mahle pistons standard CR?
- Amal valve clicking with hearts ecu & msd chip
- what power should i expect from my car
- what mm is a standard 1.6 rst bore?
- Which cheeky feck is selling this :) link fixed
- Big power rst? want a gearbox that lasts??
- S2 amal valve
- thinking of selling my field motorsport inlet
- Metering unit for RS S2
- mk5 escort pedal
- Shed rst
- metering unit s2 rst
- meter unit
- Lost my Header Tank Cap
- Some times feel a little in over my head.
- alternator help
- No Idle After Bailey Fitting
- so any news on this BC 5/6 speed box?
- Gearbox has started jumping out of first gear
- cheep insureance erst
- whos got the most powerful/fastest rst
- Newmans Cam Fail!
- Venoms
- Turbo needed non smoker
- Think My Turbo Blew!! Help
- Turbo help
- Black Series 2 E76 JWP
- Rs turbo shaking steering and almost everything renewed.
- EFI Throttle body to MFI crossover pipe reducer
- ZVH Breather Return
- has any one got a fuel sender for a s1
- fuel tanks question please
- Results are in!!
- changing suspension - tips and advice
- Cambelt question... how often and how tight?
- RS turbo s2 brake calipers same as XR3i ?
- HELP!! Which Hoses For Cosworth 2wd Calipers?
- rolling road session spoilt, boost tails off at 5000 rpm, CAMS FAILED !
- Cvh tappet touque setting
- Pic request Please
- Almost DD Day!
- Gauge Pod
- Who was it that told me Wilwood Master Cylinders are crap? Muz maybe?
- clutch pedal/cable
- Low oil pressure
- place for getting a forged efi conversion s1 set up???
- Amal/Metering/Breathing Help
- Best turbo for the job?
- what chip is this????
- whats the going rate for an rst at the moment?
- decent spec
- does any 1 no of any rs turbo speacilsts in newcastle upon tyne that r gd and cheap
- APEXi-ATS-Active-Tail-Silencer
- Standard to 200 bhp.
- Rear wheel cylinders question
- series 2 rs turbo panel trouble HELP PLEASE!
- favour needed, torque setting
- Where can i buy bonnet stoppers? and best place for Vin stamp
- S2 not boosting at all!!!!???
- 1900 cvh turbo bottom end
- Amal Valve RST/Cosworth?
- Voltage drop
- Stage 3 t3 help
- Anyone have back to back comparisons of Cosworth downpips compaired to Escort ones?
- Searching for new sliders for erst s2 brake calibers
- How much should an engine breathe?
- Autospecialist oil breather kit
- Sudden misfire?
- Seen these alloys in the for sale room...
- Cracked Exhaust Housing...
- T3/T4 any better?
- breaking issues???
- efi throttle cable?
- cvh oil pressure querie
- Zetec thermostat housing
- gearbox oil level
- want to change escort s2 rst to ofab
- s2 front anti roll bar
- Where to get rs turbo bumper strip
- Am i retarded
- cosworth managemeant running problem??
- Rev counter not working
- oil return
- My new wheels on
- Fuel metering head wiring plugs
- Fitted my brand new cossie brakes tonight
- Rocker gasket
- Wheel sizes?
- Gearbox help
- Panic help - part needed asap
- EFi crank position sensors
- throttle sensor
