View Full Version : Ford Escort RS Turbo
- Anyone? Pics of FRS Gearbox in Escort RST?
- Removing window glass from S2 RST
- Oil cooler S2, fitting and plumbing help?
- S2 welding
- brake pipes
- full cosworth brake setup on erst ???
- Brake Reservoir for Non-ABS
- mk3 bumpers
- EFI/ MFI Loom????
- Apex springs
- WANTED ASAP. CVH camshaft woodruff key
- brake lights stuck on?
- Gmax -40mm springs
- Bucket seats on std rail
- Rear swing arm bushes
- oil....mobil 1 15/50 fully syn.
- help with lights....
- boot floor removal/ spare wheels well
- Cold start/Hot start
- Alternator question
- Alternative to kenlowe slimline fan/s ?
- rs needs help please
- who can modify a inlet for fuel rail
- blocked waterway
- series1 wheels..
- zetec turbo temp sender problem
- rs turbo wont start wet plugs:(((
- knocking bottom end
- rs turbo s2 bonnet wanted
- Paddle clutches
- Cam kits
- Pistonheads problem?
- zetec turbo questions help
- Carbon bonnet
- mk1 grs intercooler
- HELP!!
- man i think i am going to call it a day
- brake question on a 1.3 shell
- rs turbo crank!
- s1 kit?
- -34 actuator 14psi min?
- front footwell speaker cover brackets/fittings
- what power would i get with my new turbo
- rst engines...
- Brake Pressure
- Cracked windscreen while on track..
- Mega squirters
- Rear brake set up (new Question)
- too cage or not to cage lol
- Mk3 escort gen ford wings
- Ecu
- wot wheels?
- what turbo
- Fuel Pressure Regulator return hose ID size?
- Speedo problem...
- ofab map sensor
- wideband
- b and m quickshift
- wheels options
- S2 wiring loom rebuild problem
- f**k efi
- Whats the ultimate???
- Alloy Quadrant
- Suspension advice
- Newbie
- Ford Fair track videos...
- idle problem
- Fuel surge
- What clutch is best 224bhp
- removal of oil pump s2
- genuine????
- engine loom multi plug
- no dash lights or pump priming
- Boost Pressure!
- anybody in birmingham ?
- Corner weighting
- Piper 285t2 cam timing?
- Wheel bolts for 17' softlines
- head bolt question
- Turbo rebuild questions
- now that iv strip the box, what can i fit/do to make it a bit stonger?
- whats the best s1 gearbox on a budget
- gear bx rebuild
- s1 side repeaters
- smokeyyy
- turbo options....need your help please!!!
- zetec turbo
- its fighting back
- oil pressure
- grs cooler
- Carbon fibre door handles and wing mirror mounts?
- lsd gear box
- super chip
- Its finaly running lol
- HELP! Engine cuts out when revving
- flywheel help
- just got 2 more questions
- 17" rs seven spokes
- oil light
- Tin Worm, on my roof
- engine to box plate
- have u seen this type of Anti roll bar??
- MAP sensor
- Electrical probs on rst
- a few efi questions
- Anybody used gaskets for classics?
- fuel tank pluming, whats what (pics)
- ht leads
- bonus differences.
- MEF Motorsport
- I need some help please
- intercooler, bigger always better?
- base settings
- Organic clutch
- Rocker Cover Gasket
- selector shaft
- twin fans
- Spark plugs
- mk3 escort brake upgrade
- Escort RS turbo........
- Heated mirrors?
- Whats the kerb weight of an Escort RS Turbo
- brake woes,help!!!
- l6 with pectel board cossie managed
- Where to buy...
- Polybushes
- Is this a standard turbo?
- Discontruction off MK4 S2 1990 with 300bhp+
- how can you tell if a super chip is a 165 or 195?
- carbon door handles
- water temp guage
- someone told me
- 90 spec rear badge location
- is this right?
- looking to sort out a few problems on my rst today!
- Who's on track at Ford Fair...
- Battery Light stays on constantly
- anyone have 1 of these fitted????
- yellow sensor
- rS turbo oil light
- s2 engine
- simple onee.
- can anyone pleease help????
- Bonnet Hinge Measurements
- zetec turbo in to s2 rs question
- st170 wheels what bolts?
- relays
- Removing heater box from Escort Turbo S2
- urgent help required!
- rear wishbone
- ofab ecu
- clutch problem on 87 rs turbo
- BAD EARTH?
- starts, runs stops?
- horn
- loom
- Bargain Zetec turbo inlet manifold on the bay
- idle/running issues
- alternator wiring
- What to take to Ford Fair!
- Water problem
- tappets on start up
- Still f'ing smokin!!
- GT 3076
- vid of my xr3i!
- Series1 starts then dies!!!!(HELP)
- wiring loom and ecu question.
- rs turbo gearbox oil level
- CVH Bearing clearance
- s2 horn
- atc fitting
- ERST feature in Max Power, when?
- Where to get new fuel pump ??
- zetec tappets
- Can you still buy new...
- Vehicle Speed sensor
- E444 AVX previous owners
- 0-60
- engine mount..best way to change front one?
- Series 1 head!
- efi to mfi sandwich plate
- turbo help urgent
- Piston and rod package, any ideas?
- Snapped dizzy bracket!!
- does anyone know f477 udd
- Wheel Bolts!
- Anyone got a Pedal Box fitted?
- accelerator pedal
- What hose clamps do I need/ recommended for a series 1?? Help!!
- Exhaust bore size?
- Quaife straght cut gearbox
- tips/advice needed please
- want a good tuner near notts?????????
- frount mount...
- Electric window loom
- dump valves
- erst downpipe
- can i use a chipped s1 ecu in my s2/chip question
- charging issues
- injectors
- rover turbo inlet adapter plate
- Running problems....
- removing rev limiter on s2 ?
- got some bits
- Pre-load
- Zetec turbo problems
- anyboby used motorsport developments nr b,pool
- turbo upgrade
- Fuel needle
- 16i anti roll bar on s2 rst
- What Brakes?
- efi flywheel
- Is it possible to fit??
- what to buy
- Braided lines
- Double Din Head Units...
- Steering wheel wobbling
- mega squirters, need your advise.
- Help con rod torque to bolts
- S2 boost problem
- Turbo gone?
- DIY All aluminium radiator Conversion
- How to adjust rear camber
- Wheel Well
- RS Turbo conversion .... drives fine wont idle
- turbo to rad clearance
- EFI Rebuild.....
- what chip is the best???
- now i remember why i dont bother with my shed
- someone kick me up the arse to get my s2 on the road
- help rs turbo floor pan needed o/s/r
- Noisy fuel pump!!!
- downpipe on s2
- how do i poly bush inner tca
- Oil leak???
- running problems
- Camshaft Specs
- Setting up solid lifters
- can anyone pleeease help??????
- Can you buy new brake servos?
- anyone no if you can buy s2 headlight ducts?
- Bournemouth RS Parts
- Small front Reg plat pics?
- ARP Conrod Bolts
- Clutch Release Bearing
- good engine rebuild
- largest twin fan setup on standard rad
- Engine switch
- RS Turbo Needed to TEST NEW GEARBOX
