PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. Fuel system!
  2. jamsport tubula manifold..
  3. Fuel lines helppp!!!
  4. clutch problem
  5. Co2 levels ?
  6. pistons again
  7. Turbo questions.. again sorry.
  8. good on line shops
  9. front uncle roll bar
  10. mk4 escort polybushes...
  11. What injectors
  12. bailey oil breather kit
  13. where can i buy a alcon 6 paddle clutch
  14. piston rings
  15. s2 into s1
  16. RS meets
  17. running lean under boost/load
  18. Mfi series 2
  19. Series 1 Rs Turbo Dump valve ?????
  20. who has the biggest power cvh now.
  21. crank journals
  22. Overboost
  23. cvh steel crank
  24. pistons
  25. Difference between XR3i and RS Turbo Radiators?
  26. 1.8 CVH Roller Lifters...
  27. T3 rebuild diagram
  28. 8x16 Alloys problems
  29. Another EFI Question...Fuel Filter....
  30. d799 bnv is it still about
  31. parts needed for abs removal
  32. Head Rebuild Advise Needed
  33. wilwood calipers
  34. Suspension upgrade
  35. Random question.... cvh block weight
  36. how to contact mef motorsport...
  37. S2 starting and running issues
  38. how cool is this??
  39. Omex 600 any good?
  40. wiring problem
  41. Running fault, maybe fuel meter?
  42. Whats needed for gotech??
  43. how often shud i get my mfi s2 set up
  44. difference in mk3 mk4 rear panels????
  45. t34 turbo what power...
  46. 16" tyres???????????
  47. blue smoke!!!!!!!!!!!!!
  48. WHat to look for when buying a Series 2 RS Turbo??
  49. Whats the best thing to use when sealing the sump gasket?
  50. arch liners
  51. s2 intercooler
  52. HELP where 2 get rear panels!!!!!
  53. replacement turbo
  54. Stage 1 Gearbox
  55. Standard Dials
  56. black headlining
  57. No feed to the auxilliary air valve
  58. Cooling system capacity?
  59. Ported Head......
  60. Ace cafe this saturday!
  61. Fuel Pump?
  62. Launch control
  63. Boost Control
  64. EFI Conversion whats this lot worth???
  65. bleading brakes on new system
  66. bonnet raisers?
  67. changing Track rod ends.
  68. Car Weight
  69. I wana turn my 91 xr3i efi to efi turbo
  70. Turbo bolts
  71. CVH on EFI
  72. D384 DAD What happened to it
  73. avo coilovers
  74. One quik question about coilovers
  75. Got to sort ride out!
  76. Anyone want a rear seat? (other free bits added)
  77. exhaust manifold gasket...
  78. Cosworth 2wd rear brakes set up
  79. does my cam pulley need modding for cosworth management?
  80. brake servo and master cylinder upgrade
  81. oil pressure light.!?!?!
  82. removing a rear wiper..
  83. Aftermarket fuel pressure regulator
  84. will it fit?
  85. Braided Brake Lines for Cosworth rears.
  86. t34 water pipes
  87. big spec 1600cvh oil WHATS BEST
  88. think my heads coming off again
  89. Millers Oil
  90. tyres..??
  91. Airtec front mount, 88 spec bumper
  92. bolt to stud and nut conversion
  93. For anyone interested in fitting Corsa D power steering... ON HOLD :(
  94. Can i run a mfi turbo lump using a n/a efi tank??
  95. T3 turbo rebuild bits
  96. what stage turbo?
  97. focus rs gearbox driveshafts
  98. What clutch for big power s2?
  99. s2 clocks
  100. can i mod the bottom pully to run cosworth management
  101. ZVH Head Gasket
  102. efi cabby turbo probs
  103. S2 sunroof rot - Replacing sunroof panel assistance?!
  104. would this cause me problems?
  105. camtec cams
  106. leaking rs turbo ready to pull my hair out!
  107. advice for a mate on tuning
  108. Cabby 3i turbo conversion - Lots of help/advice required. It is a running car!
  109. modified S2 dashboards
  110. Fuel meter pipe layout?
  111. priming new turbo
  112. Series 2 instrument panel - removing needles
  113. 2wd or 4x4 throttle body?
  114. how much is it worth?
  115. Help me figure this one out!
  116. How much are S1 opening rear windows worth?
  117. turbo
  118. Can anyone recommend a car alarm?
  119. tappets
  120. can you still buy window rubbers for mk4 escort ??
  121. ZVH question
  122. How Hard to Find!
  123. Bubbling cooling system
  124. just been to the paint shop to see my car and new wheels :D BACK TOGETHER MORE PICS
  125. fuel mixture too rich
  126. help bulkhead seals/boots
  127. RS Turbo to Cosworth
  128. After gear change car won't react on full throttle
  129. Turbo damage
  130. Rs turbo s2 boost problem, can you help please
  131. How deep??
  132. fuse box
  133. where to get a baffled sump ?...
  134. Time for a service
  135. Which starter motor for my zvh
  136. help
  137. best place to get rear arb links??????????????
  138. benefit of having ABS removed?
  139. Zetec turbo lads...What sump?
  140. mtx gearbox conversion with TT rollbar
  141. modified 90 spec front bumper
  142. RS Turbo build.
  143. Where can i get these parts.
  144. sytec fse fuel motorsport out of tank
  145. Headlights
  146. s2 starter motor weiring
  147. RS Turbo Cap Head Diff Bolts
  148. stange noise
  149. Mk 3 Bumpers
  150. Caliper colour?
  151. cvh supercharger eaton
  152. monster engine for sale
  153. ZVH Breather fittings
  154. anyone got one of these tubula manifolds??...
  155. FRST steering wheel on an ERST?
  156. what tuners in essex/london area?
  157. efi with mfi head ??
  158. anyone got focus rs mk1 disc's & callipers fitted to a mk4 escort ?...
  159. Anyone built a N/A ZVH? Results?
  160. After some panels.....
  161. Squeaky brakes
  162. Removing abs & how to make new brake lines help needed
  163. s2 gearbox cradle bolts?
  164. Is this normal?
  165. clutch problem
  166. what cam kit is best piper 285 t2 or kent cvh 37
  167. E325GAR anyone know this car
  168. Quietest s2 rst exhaust system in the highway
  169. wats a set of 17 inch rondells worth
  170. ZVH RS TURBO inlet manifold what one? & how to
  171. is it real
  172. newbie
  173. G865 BBH
  174. Rear drop links
  175. Fiesta recaros
  176. torque settings rear abr
  177. Best suspension kit for £500 ish
  178. few small problems. handbrake,abs
  179. Fuel sender
  180. Fuel tank question
  181. Remove water pipes on stage 2 t3 rst s2
  182. delocked boot
  183. escort rs turbo fuel pump allways running when ignition on
  184. B300fjh anyone know it s1 rs turbo
  185. are theese rst pistons?
  186. how good are AET stage 1 hybrid turbo
  187. 1.9 CVH
  188. HELP please??? cosworth leather interior???
  189. superchips
  190. turbo water seal
  191. good rs turbo mechanic in Birmingham
  192. Fan positions
  193. Leaking escort
  194. boost control best option on budget
  195. 1.8cvh wanting to turbo,advice welcome
  196. Any1 used c20xe pistons on zvh??
  197. dash remove?
  198. pics of GT30 on cvh's please....
  199. Early and late CVH block differences?
  200. Which boost controller
  201. Cosworth hoses on 2wd calipers fit mk4?? HELP!!!!
  202. siemens injectors 55lbs
  203. erst and sierra anyone interested
  204. HELP high temperature
  205. zvh block builds
  206. hi all !!
  207. Gt3071r on 2.1zvh
  208. correct offset for s1?
  209. 90 spec door card
  210. heat problem?
  211. About FRST engine loom in a ERST S2
  212. Cam belt cover for ZVH - modify or fabricate?
  213. t38 fit 2.1zvh
  214. how hard to find a good shell?
  215. rs 7 diomand cut s ? urgent please
  216. how much for at34 turbo
  217. 1.8 zetec turbo..but wat head??
  218. s1 rollbar set question
  219. Sitech Racing heads?
  220. what pistons do i want?
  221. idel speed control valve
  222. Carbon Fibre Roof...?
  223. Replacing front panel
  224. will a 200+ rst do a 150mph?
  225. boost controllers
  226. oil help please
  227. Few Q's please people
  228. Rst engine in kit car question.
  229. It's all gone a bit dark!
  230. Oil pressure
  231. what will a t34 .48 be like to drive 1600cc?
  232. New car
  233. Brake upgrades.
  234. what BC5 bearings do i replace with IB5 bearings? what other work has to be done?
  235. brake help!
  236. Pace intercooler
  237. series one questions
  238. thinking of changing management so gotech for sale
  239. help needed
  240. series 1 braided fuel lines...help!
  241. abs question
  242. azevs or turbo wheels?
  243. piston rings
  244. Simple question. RS Turbo glovebox lid, leather or plastic?
  245. rs needs help please
  246. equal length driveshafts....
  247. wastegate rod ends
  248. s2 fitting strut braces!
  249. would the t28 be less lagger then the t3?
  250. Sandwich plate
