View Full Version : Ford Escort RS Turbo
- budget gauges ideas!
- Megalog Viewer ( Megasquirt )
- i'd just like to announce that...
- Does anybody have or know where i can get a rst master cylinder
- Innotec paint for dashboard?
- Stage 3 T3
- injector question for megasquirt users
- some people don't know what there selling
- Steering racks- whats best replacement one to buy, they seem too cheap
- think ive had enough
- relays
- Lowering???
- Front Mount Intercooler
- For those still on wank MFI (like me)
- Starter motor help
- over heating
- T34 running 2 bar of boost.. what actuator??
- S1 body kit on S2
- What HP should I expect realisticly?
- what size socket/spanner for anti roll bar mounts bolts?
- track car.
- Racetech gauges, any one use them?
- Wet drivers side carpet...
- Where is???
- what are the differences..................
- Those that have moved fusebox and/or battery tray
- head lining question
- How to remove my fuse box?
- oil coolers...
- removing the steering wheel :S
- Is the ratois to short in mk4 fiesta 1.2 gearbox?
- Fuel pump cradle polly bush mounts, where from?
- clutch slip
- Coilover Spring rates
- Oil pressure surge!
- oil presure xr3i
- PAINT
- ticking over @2000 rp. when warm
- Brandshatch videos and pictures.
- "RST Recommended Oil's"
- gearbox oil ?
- what oil is best
- custom inlet and exhaust manifolds where from and how much?
- Megasquirt MS1 V2.2
- thinking of starting a engine resto thread on here?
- rattle when pulling off in 1st gear
- Spark blow out on boost?
- Help needed, Car not starting
- oil seeping from dump valve? help
- Tyre sizes
- Series 2 setup
- in block oil return
- pic request
- Fitting a RST LSD into an IB5 box help..
- Whats best for MFi setup?
- i'm buying some 17" comps (mo's 5 spoke)...
- Retrimmed Doorcards
- Anyone know how to remove the abs crap from my brake system? Help please.
- Wing mirror pics please...
- koni suspension stickers
- Been thinking about my brakes again
- Relocation of Fuse Box - UPDATE: Trial fit
- What do i need to do?
- oil cooler stack
- N/s indicator does not work
- actuator adjustment??
- got a problem!
- Gauges in dash above glove compartmnt!?
- dials !!!!!!
- People with stud (wheel) conversion.
- Where can i get these parts?
- Coilovers topmounts
- Removing abs
- dials?
- wastegate!
- brakes
- s1___s2 gearbox
- kent cv37 VS piper 285t2
- Fan fuse melting?
- Problem with reverse lights.....
- Rust Treatment when fitting bonnet pins
- OFAB Ecu engine area?
- accusump?
- Rover-zetec adapter
- steering wheel boss ..?
- well it looks like it may be nearly finished
- crack in block ??
- problem...
- Putting the power down.........!
- steering rack bearing kit mk4??
- Something about fog light
- quick one peeps
- ESCORT COSWORTH ht leads for RS Turbo MFI
- abs
- few pics of the old skool "hocks" on S1 & S2
- s2 sunroof!
- has anyone retrimmed there own interior!
- Oil Seal?
- Mk3/Mk4 Steering racks the same?
- battery charging system & starter
- Brake question
- afr gauges what u got ?
- 5 paddle clutches??
- what gagues ??
- MFI injector rail mod for Bosch EFI injector
- s1 fuel pump
- Am i right in thinking....
- tuners -nms/jamsport etc
- are standard rst pistons forged or cast?
- Headlights wont work
- whats people plans for there rs turbos this winter?
- Omex 710 ecu
- one thing after another!!!
- Some EFI questions
- pis request please, front bumper cut outs
- What clutch?
- erm.................wtf
- what would happen if my gearbox didnt have enough oil?
- mods mods mods sticky for zetec turbo section
- Black top or Silver top Zetec Turbo?
- Fiesta rs cam
- black relay under the drivers foot well.
- What do you think?
- s2 rs problem/s
- Can a fst engine be used on mfi???
- Rs turbo buying advise ???
- Cambelt picture...
- Anyone got...
- Head gasket
- Zetec turbo questions.
- Compbrake pedal box question
- MTX75 box S2 turbo conversion help please.
- Please Help :(
- Pics of replacing rear arches please.
- Injectors, fuelling need advice/help please!
- Blowing fuses?!?!
- 2.0 zvh engine with rs turbo box, what flywheel
- Clock/s problem
- engines
- ADJ pully
- Tinted tail lights question ???
- Good carbon deposit remover?
- Ignition timing map
- 98 Escort Sport/ Focus ZX3 engine swap...
- B&M fitting and a few questions
- Fuel sender wiring loom HELP!!!????
- zetec head - spec? and from whom?
- recaros rattling
- rs turbo lsd
- Aftermarket Fuel Guage / Standard Tank Sender
- At last it works
- MFi....EFI STILL NONE THE WISER!!!
- road tax price
- gearbox/crap top end
- has anyone got the alum parts that the speedo cable goes into? need one asap
- wossener pistons, anyone had bother with them slapping?
- God my electrics are a mess.
- S2 to Fiesta RS
- Got her finished and she breaks
- Rust round windscreen wipers...
- coilpack
- rs turbo gearbox
- S2 drivers seatbelt...
- Correct Spec
- gearbox
- not had a good day
- adjustable track control arms ?
- rs turbo series 2 uprated brakes??
- converting an s2 to s1
- rs turbo gearbox
- smokey joe
- series 1 metering unit fixings bolts same as series 2?
- brake compensators
- help please
- Millers 10w-60 oil
- VI Performance OBD Monitor & Fault Code Reader
- Injectors for 2.0 zvh turbo?
- dash2 or stack ST700
- sad times
- Collins/Pectal/Powerchips monitor. Where have you mounted yours?
- Servicing Electrics...
- Which oil for Rs turbo?
- Quaife gearbox kit
- Not boosting properly
- what do i have to change to fit a cossie t3 to my s2?
- Chargecooler Resevoir Cap Is Seized On
- the wheels on my s1
- Standard recaros with harness
- S1 intercooler?
- series 1 and series 2 inlet manifold, the same?
- Adjusting clutch arm
- got a resto thread in the resto room
- It actually runs :d
- diffrent options for clocks in a series 2 dash ???
- speedo problem
- Name that wire ???
- head bolt washers
- Uprated BC box mounts
- steel rods an forged pistons
- Crank Position Sensor Bracket Pics
- conversion MFI to EFI (MS2-Extra) problem run engine :((
- Oil Return Leaking
- new to the scene.....
- we need a good mod for this room
- ET20 wheels?
- my old car b88 eeg
- been asked many times, ABS removal slight issue
- stuff it time to break it up but im keeping the shell
- Xr3i 1.6 Mfi to RS TURBO Mfi
- Changing gear - HELP!
- Mk5 servo and master cylinder conversion pics and question inside
- S2 wheel bolt torque?
- is there a water way that needs blocked on a zetec block to make a zvh
- radiator fixing problem
- mahle pistons
- Rod bolts
- Anybody have spare Recaro runners?
- who wants st170 discs spacer kits...
- Are the following worth buying??? re: insulation
- Dump valve chucking out oil????
- Few problems with my RST - only owned it for 2 days
- what should i do with theese pistons
- yet more problems, need some help please
- piper cam
- Interior seats
- Cam belt and tensioner..
- Cutting out MFI engine loom?
- spax vsx kit for fiesta
- Fuel tank or cell
- fao crazycage or rick
- pic request
- can anyone id these cams??
- engine mount
- Sunroof Seal
- Changing steering colunm?
- Turbo refurb?
- best gearbox upgrade for 2.0 zvh
- dipped and main beam headlamps, indicators not working. HELP.
- Bucket seat
- Converting zvh back to zetec?
- Newman or Kent Mecanical followers? :-)
- changing ecu
- 20,000 threads in here
- EFI Help needed
- new favourite pics
- Anyone know if this is standard??
- Pics of MTX boxes in ERST's
- Big brakes to fit under standard wheels
- grs intercooler
