View Full Version : Ford Escort RS Turbo
- Another 'it wont start' thread
- lambda sensor fitment
- Servo upgrade
- Going efi - require fiesta turbo cross over/rocker?
- Turbo
- quick 90 spec front bumper trim question
- Some one nearish to Bristol to set up my RST
- S2 speakers
- Body kit removal
- Anyone got some damaged headlight covers they want to sell?
- Should fan wires be live?
- burton power high pressure oil pump?
- Edit! Anyone got a weld in cage? Need Pics?
- any body breaking a rs turbo?
- Can you see the spark with the plug out?
- rst s2 roof lining wanted/boot lock
- XR3i EFi - OFAC ... ?
- cambelt
- Replacing MFI injectors
- does a S2 exhaust fit a S1 ??
- S2 Fuelling Hell!!
- whate are these plugs for
- gear selectors.......
- HELP please!!
- focus rs gear knob on a s2?
- ignition map
- h301 gwc
- ecu identification
- help with rs turbo please
- erst fuel guage?
- not enough fuel / crap mfi / set up time again????
- Best exhaust manifold gasket?
- Oil Temperature gauge sensor.
- overheating s2
- For anyone interested in custom dash dials/gauges...
- Electrical problem with my ERST....
- Stolen : Rs Turbo Cab
- new looms for rst
- Rear Anti Roll Bar
- Oil Return, Elbow pipe.
- reverse light switch?
- I need Rear light smoked
- thermostat
- Replacing brake master cylinder
- Wheel offset?
- escort adjustable tie bars,
- Air intake on a Escort EFI
- help please urgently!!
- ????????? 500bhp
- Three button roof clock
- mk4 escort window seals.
- Dashboard Removal
- anyone know the standard bore size of an rs turbo please?
- Panel Prices?
- What radiator
- New sills
- High pressure oil light switch & Plugs
- which wires run to fans
- Turbo Psi's
- loom
- 1/4 mile times
- Can sombody reccommend a good tuner in the West Midlands area?
- which megasquirt
- Running lumpy when cold
- Who uses their rs turbo daily?
- amal valve
- intercooler or Pace Charge Cooler Kit
- looking for parts
- CVH34
- Plastic window people
- fans
- MK4 Escort Plasma Dials
- Anybody ever fitted a pair of rear opening quarters to a series 2 turbo?
- Wastegate solenoid / Amal vavle, advice needed...
- BP2 Cam? What is it?
- Rs turbo wont start
- metering unit
- Torque Settings??
- oily exhaust causing burning oil smoke??
- Mk 3 escort 1.6 ghia turbo conversion
- my car
- anyone ever heard of saab pistons being put in a s2 bottom end?
- frankenstein custom inlet?
- Need Some Help Please!!
- RS turbo cylinder head casting number
- cars hunting
- oil pressure and water temp gauges! fitting!
- -31 actuators
- 1.1 crossflum sump same as cvh
- anyone stripping a s2?
- T3 .48 Exhaust Housing
- ZVH Power Output?
- ZVH high pressure oil pump?...
- 2wd calipers
- Exhaust manifold question!
- How noisy is a CVH??
- not rs turbo but xr3i,need advice
- Scuttle?
- actuator
- blown turbo???????
- rs turbo dump valve question
- how much is it worth?
- Differences in S2 Turbo's and running issues (essay)
- What clutch too handle 240+ bhp
- These oils look any good?
- Does anyone know where to get hold of a proper wingmirror glass?
- Engine mounts?
- Heated screen issues
- Fitting a front mount IC, how do you secure the rad?
- What realy controls the FAN, HEATERS AND INDICATORS
- Little or No Boost
- Help, Electrical Fault, No fans, No reverse lights
- Help needed with setting boost....
- fuel pump s2
- F301 OEB anyone know this car
- help needed buying helix 6 clutch
- Buying a second hand chipped ecu
- fuel pump m development
- RS Turbo spark problem
- Running Problems with my RS Turbo
- Turbo actuator/wastegate set up
- efi engine problems
- Fuel pump from fiesta centre
- rs turbo problem
- fitting gauges!
- turbo bonnet
- single wiper conversions
- pods / gauges
- Is it worth doing Rear disc conversion on escort rs turbo
- amal valve jetting
- how do i wire these oil gauges up ?
- lambda fitting for wideband sensor
- oil pump and water pump
- which management
- how to fit boost gauge
- Just bought an engine....
- GRS or Pro Alloy FMIC?
- Little help from the experts would do nicely
- fans infront of intercooler or rad?
- fuel pump cradle rubbers.what size are they
- removing s2 fuel lines
- Speed sensor - Turbo timer?
- DJ Mixed Music Set 1991/92 Oldskool. Watch this..
- smaller alternator belt for s2 erst
- Slimline fans
- turbo
- torque settings? help please!
- Got me wondering..
- matt black s2
- Where to start making it faster
- What Gearboxes Fit The RS Turbo
- boost hose clamps
- MegaSquirt Experts
- Look What The Weather Has Done To My Baby :(
- zetec to cvh sump
- probaly look at twat afta this thread lol
- anyone id this bottom end? 1.9 tallblock?
- little help
- Painting engine parts
- mfi efi adaptor plate
- fiat/406 brembos
- RST Van pulling to the left when driving hard
- X-low apex springs
- changing camshaft - advice from tuners/those who have please
- Best place to buy rs turbo fuel pump?
- Advice
- What size master cylinder?
- My pistons are here!
- wanted perspex clocks screen only
- Recommendations for complete front brake setup..
- ebay ad bits for sale
- Bailey breather
- Helix 6 clutch (where to buy??)
- AutoSpecialists T3 "Tubular" manifold...
- What hose kit
- Is there a fuel cut off switch on RST
- Massively Let Down
- got this for my little one...
- B&M shifter anyone?
- rover inlet
- Where would I find this?
- rear adjustable tie bars
- 11mm Head Bolts
- underside tidy up
- GRS intercooler fitting + Kenlowe fan(s)?
- poly engine mounts
- Your boost graphs/tables
- rs 1600i rocker covers....
- Standard clutch
- Gearbox Help for ZT.
- Leaking windscreen.....
- series 2 a pillar drip rail
- Gearbox
- Toyo R1r's any one used them yet?
- Bonnet raisers Q!!
- does anyone no.......
- wat head gasket for 1900
- how do i test my shocks
- my series one turbo
- Dumb brake disk question...
- Escort RS Van G841 BLR
- turbo timer
- need a little help or advice please
- fuel pump???
- Weld in cage?
- no boost on s2,help please! PROBLEM FOUND!! 4TH JAN
- S1 Car and Engine loom ... ?
- escort rs turbo little boost and ratel
- S2 suspension
- 2.0l zetec turbo re bore question
- help s2 starts and runs for a little while then not start?
- Info/History of S1, C64 XLK
- Thinking of buying an S2
- Rst no ignition lights
- cos management
- Focus RS transplant?
- FTAO Karlos.
- Standard T3 Manifold - Wrapped?
- Ebay sellers to avoid.
- turbo oil return...
- rs turbo 1988
- which charge carrier fits this rocker cover
- can i have a manual fan switch and auto fans?
- Megasquirt and fuel relays,
- brake servo removal
- Rs Turbo not starting
- Standalone management question....
- Head Bolts
- ARP2000 Rod bolts....?
- Rough start knocking/ticking
- universal intercooler kit on rs turbo any good?
- sunroof drains
- wont start
- help please ,
- favour needed - re rear brake caliper brackets
- The Complete Zetec Turbo Bible - Ebay
- need new injectors!!
- turbo conversion on the cabby!!
- Will exhaust fit
- Vibration bad threw steering wheel when braking
- Erst knock sensor plug / connector needed
- Fitting gauges
- 1afa - ofac
- 5th injector kit
- 1.8 zvh
- G200LEG Series 2 RST
- millage counter
- Engine Mounts
- windscreen rust
