View Full Version : Ford Escort RS Turbo
- Gasket?
- any1 know how to get the whole dipstick and tube,out of a cvh?
- if i buy a zvh ready built will it fit strait in my s2?
- Gearbox
- Crossmember where from?
- PLEASE HELP IMPORTANT (gearbox oil)
- boost problem.. confused
- Electrical prob! Battery
- Feul pump help
- help! help!
- Power Steering Equipped RS Turbo on Ebay!!
- Wastegate sticking
- got my rolling road printout!
- shorten gearlever
- escort rst mfi spluttering
- cold air feed ?
- Swirl pot
- anyone know where i can get a set of headbolt washers for my s2?
- dreaded brown stuff
- MEF rear arms
- Top end rattle
- boost ecu
- Knock Sensor
- S2 headlight wiring diagram
- Tracking
- Anybody converted there S1 to OFAC EFI?
- cold start valve
- RST S2 parts required please!!
- various probs
- boost problem
- Whats best to use to cut bumper?
- zetec mounts for a mk3
- rs turbo fuel tank
- rear chassis rails help please.....
- Magnetic sump plug.. Thanks MSD...
- s2 turbo wont start (again) :(
- i just blew my s2 engine up!!!! metal and oil everywere
- boost problems
- OMP brake pads
- Help please gearbox
- Name where that hose goes!
- Has any one managed (EFI question)
- Changing timing belt?
- how do i put some pics on here
- Bottom end
- Fuel pressure gauge
- battery light staying on when keys are out of the ignition?
- Feed for oil cooler
- Thinking of selling.
- efi turbo
- Fitting a new cam
- getting it set up (update not good)
- frst still scrubbing
- fibreglass boot lid
- Thickness of body metal?
- manifold stud and nut set
- Bottom end bother
- Who leaves their mk4 outside all year round?
- few pics of mine
- Breather Help...
- Help needed
- what clutch
- Burbling/popping sound
- Maram shaft
- orion ghia efi to ofab wiring help please
- Quick question about B&m shifter
- My S2 Turbo ??
- adjustable tcas
- Low idle.
- remind me (boost gauge fitting)
- Bad Day Today :(
- Running in / Oil change / Engine Flush????
- Possible stuck lifter?
- Frantic clicking noise from light stalk
- Misses, Cuts Out and wont start all when warm
- removing rear springs
- Clifford G5 and central locking not working...
- Washer pump relay???
- Drive shaft nuts
- pic request rear handbrake shoes
- Fuel Surge?
- steering
- adjustable tcas
- pics required please
- fuel pump cradle powder coating?
- handbrake cable
- Fuel pnmp cradle rubbers (mounting to car)
- max power on 2.0 zetec with decomp?
- ignition timing! what should this be set to?
- black aux air unit
- Goodridge rear brake hose's...
- MOT'd the car today, which can mean only one thing.....
- Oppinions ?
- 2.0 16v turbo on mfi. Am i seeing things
- s2 turbo charger
- How much is this turbo worth?
- Airtec/AS Turbo Cooler Pre Rad
- help im at a loss
- Injectors
- Aem wideband...
- Fuel Tank Breather
- Getting me car mapped :-)
- Intermittant wipers not working
- Can anyone help me with a part number for this steering column part?
- How do you connect heater control cables?
- Dark green 803's
- Single or twin pass coolers better for RST's?
- -31 actuator
- Cutting clutch quadrant (more than 10 teeth)
- Try new Armor All Wax, FUCK OFF
- Slimline Fan wiring
- front suspension
- iv fitted a collins 31 acuator what shall i use amel valve or bleed valve?
- s1 coolant pipes
- EFi Mangment??
- Clutch problem (making a hell of a racket)
- Views on heat wrapping........
- Fiesta xr2i cylinder head on s2?
- Mk6 clutch pedal (are the teeth needed?)
- Trigger wheels
- Anyone raced another car and surprised themselves?
- aney one got headcloth mk4 escort rs turbo for sale
- Upgrading turbo........
- st170 gearbox on s2,,
- Mega Squirt advice please.
- s2 wiring
- Jubilee clips
- ERST LSD Gearbox.....
- megasquirt help, started wiring! MS1 to MS2......
- cvh fuel meteriing unit problems
- is this cam standard or a preformance one?
- going rate for a good s2
- 1.8 zvh to a 1.8 zetec?
- rs wont start when hot help please
- Trip Com
- intercooler
- ECU pin diagram
- Escort xr turbo does any1 know what this is
- braided fuel lines.......
- big power gearboxes
- HT leads
- how much power on efi?
- bike carbs
- swirl pot
- S2 missfiring/backfiring over bumpy roads and potholes
- rs turbo drama
- Views on these bolts.....
- anyone know the torque setting for the shells in s2 bottom end?
- 4 SPOKE
- wiring help please?? :(
- Xr breakers?
- S2 Driver/passenger lower window rubbers anywhwere????
- mounting a oil cooler.any pics?
- Wheel bolts???
- name that wire
- Shes runing at last
- how do i remove my sunroof????
- what gearbox ?
- boot struts.. whats the deal??
- s2 boot ram options?
- Indicator Relay....Where?
- Best paint for protecting battery/fuse box tray
- Cleaning thread.........
- s1 / 1600i arb setup on s2
- s2 is a bitch too start when cold????
- window wind shields
- Please help s2 mfi running prob. Heated seat fuse stalls car
- best place for a set up
- bufty session
- Guide points on the block......!
- Brakes upgrade problems. Please help
- new guy needing wiring help
- Help needed asap plz!
- What Rims For My S2 ?
- no oil pressure impossible timing adjust...(BIG problem inside)
- rs turbo missfire when cold
- Torque settings
- the best inlet manifold debate now fact not fiction
- Plug leads keep melting on tubi manifold
- got it running but only when i hold flap down
- Tuned, or not tuned.....whats worth more?
- Indicator lights stuck on....HELP
- Problem with KE-Jetronic after engine rebuild
- can any 1 help me out
- Head bolts....
- Fuel cut off switch
- How do i get my RST Lower
- has anyone?
- My mate D4 rst recieved a call from...........
- Where to connect my turbo gauge vacuum tube>
- Need a couple of bits
- Baileys oil seperator
- 1.8 zvh
- rs turbo heat shield, hows it attached?
- how many d reg s2 are there left ?
- fans switch
- My Series 2
- Boost tailing off...
- didnt really need another RST!
- FAO anyone with a bolt in cage which sits in front of the dash...
- sensor identification
- abit of help needed
- s2 wpnt start after new fuel pump fitted! help
- why is my escort rs turbo engine blowing the oil filler cap off but wont suck ?
- Actautor Question. Which rod length?
- QUICK ANSWER NEEDED> Intercooler hose size?
- People that post clips to YouTube.....
- idleing issues doing my head in
- Pictures of boost gauges and possibly where you got them from?
- overheating
- Can't get a gear :(
- where to get fuel pump relay midlands?
- Does anybody know anything about S2 F843 MPB?
- Fuel pump relay controlled by ECU? which one?
- erst bottom end
- Air Filter confusion?!
- air charge sensor plug
- MFI to EFI sandwich plate any good?
- Xr3i efi looms?
- efi hunting
- Clutch help!!!!
- metering unit
- Show us your...steering wheels
- I'm Stupid
- turbo restrictor
- Buying a S2 Escort RS Turbo
- S2 Turbo Thermostat hell
- S1 bodykit on S2
- Right need a bit of help, pulling my finger out!
- 2 stage boost control
- some 1 help me on message blow
- ARP Rod bolts torque
- tailgate enquiry
- not starting plz help me out lads
- help turbo wont start!!!
- FAO anyone who has done the clutchpedal mod
- inter-coolers
- bottom pulley/ crankshaft pulley
- zetec head difference
- Speedo sender / Fuel sender.....
- my first rs turbo
- will series 1 steering wheel fit series2?
- turbo timer
- newbie
- Info Needed on Series 1 C637 BHV
- ignition barrel
- Lost my spark
- pedal box
- removing brake bar, and servo mounts?
- injectors
