View Full Version : Ford Escort RS Turbo
- ofab ecu
- Ford Premium sound system wiring pinouts.
- spal fans
- mfi & 3 port bleed valves.
- Still available ????
- overheating
- should i or shouldnt i
- best n cheapest way to get rid of sun roof??
- best way to get more torque??
- Rear spring caps?
- 200mm 220mm clutch plate
- Power charts
- intermitent missfire?? any ideas??
- motor and gearbox mounts
- part indentification
- sump plug size
- which spark plugs??
- Head Gasket choice
- Guys what is this
- Clutch slipping on boost
- Stuck bonnet
- Help with EFI conversion
- gearbox oil filler and drain plugs.
- s2 ecu's
- what hp do you reckon, ballpark?
- rst turbo control valve
- confused
- NUT
- S1 arches / kit
- rear shocks keep breaking!!
- newbee
- what wheels on black s2?
- alternators chargin at 16v?????
- running probs
- thankyou oil n filter change???
- what to use
- Rear screen
- boost problem
- rs500 style intercooler vs GRS
- rs turbo exhaust manifold gasket
- apexi avcr
- St170 bottom end for zvh
- Finding tdc?
- Electronic BOOST Control
- Turbo Oil Return
- will not start
- Aftermarket Adjustable FPR onto Standard EFi Inlet
- which ancillary hoses for mk4 escort with fiesta rs turbo engine in it?
- Clutch info needed
- roof grab handle locations
- Heads up..
- bad fuel pump?
- Few Questions??
- another fueling problem!
- what injectors fit
- Stainless Lambda Boss
- Removing rear screen
- Rear suspension problem, help needed URGENTLY
- fuel reg
- Best brake upgrade for s2 and prices?
- boost issue
- blue wire in back of clocks to alternator??
- Diesel Alternator
- pressure in coolant system
- escort rs turbo extra hp
- MTX rs 2000 box
- what handbrake cable
- central looking
- Uprated Rear Shocks for MK4 Van?
- Fuel Issues
- What BHP To Expect From My Cossy Managed Escort XR3i
- brake failure
- RST S2 mechanic
- Det Cans
- Thermostat changing..
- efi what bhp
- what fan size??
- Steering column bushes
- Reshell questions - ideas for paint?
- thread size?
- central locking for my series 1
- central locking diagram?
- fiiting ofab to mfi help needed
- Tyres for 17s
- Engine bay clipss
- magnex down pipe hanger??
- Sender question!!
- What Gear Box / Kid Should I Get ?
- rs turbo bonnet ??
- part number finder all fords
- rs turbo series 2 uprated brakes??
- 0fac ecu with 0fab map sensor?
- part needed please help!
- Rs. Turbo hydraulic clutch
- S2 Rs Turbo, fusebox / wiring help!
- urgently need pics guys!
- What clutch setup?
- no oil at turbo oil feed pipe, advice needed please
- carello spotlight with airtec fmic possible?
- Carbon roof
- Abs
- oil from dump valve
- Few Issues!!
- how hard to get a fuse box for S2?
- G777 Hum?
- G95 fct
- what alternator?
- 1.9 tallblock power engineering
- rear springs help please
- s1 opening rear 1/4 rubber seal
- Compression question
- Book Price
- HELP!!!!!!!!!!!!!! rs turbo hot starter motor problems
- MTX75 differances?
- Ford rs mudflaps
- help please
- Black top head using ST170 springs and 3mm spacers help please...
- is this chipped
- RST Interior LED Bulb Size - Speedo, Dash, Interior & Numberplate Light
- Comp test from cold, plzzzz help
- S2 Suspension wanted
- IB5 Ratios
- roller rocker arms
- zvh
- What size disc?
- MS2 i need some help!!!
- standard rs turbo rods
- damn turbo lag!!!
- Cracked block advice
- any pics of peeps s1,s with rl7s
- Ride hight measurements still needed!!!!! Anyone....
- Weird clutch... Stumped
- Breathers on ZVH EFI?
- MFI-EFI Cossie Management
- HELP !!!!!!!!! rs turbo cutting out
- best wheels for an s2..opinion and pics?
- New member from Dublin, Ireland
- 2.0L ZVH Oil Gallery Blanking Plugs
- Braided still brake lines
- Map sensor
- Does this price seem too high?
- series 2 set up
- pics of grey s2's please!
- HELP fitting escort cossie wheels on a mk4 escort rs turbo
- pics of red s2's plz
- Spot light
- Escort rs turbo seats
- Windscreen
- grey s2 on black comps pics?
- rs turbo long journey
- bad misfire
- fitting a double capacity pace intercooler!
- Zetec power steering pump and bracket
- overheating
- Gotech mini x ?
- Fitting a Magnex system
- Where can I get metering unit reconditioned
- Wheel Size / Offset help needed
- Escort rst S2 gear knob.. is this right??
- Fitting Saff Recaros into Mk3 ??
- strange car is not at the same hight
- MegaSquirt Learning the Basics
- Help in desparate need of a escort rs turbo s2 fuel metering unit?
- Gear stabiliser rod wanted selector rod
- 3 cylinders now 4 now now 3??
- ST170 gearbox vs MTX75/ Cradle Mounting ?
- New release bearing
- turbo cooler fitting kit
- brake upgrades
- Cutting dash board
- Fitting 2 front wings to Ford Escort S2 RS turbo car.
- koni suspension top thread length now with PICS!
- arb
- track car pics
- cosworth loom on rs turbo
- Help with these pictures!!
- engine bay wiring pic resquest
- Threads asking for Car Stereo codes are not allowed.
- CVH Dipstick tube
- fan fuse keeps blowing!
- G407 OKM or G972 RUF Looking for my old Rs turbo
- cossie 4 pots
- Koni suspension top thread lengths
- adding the optional fuel computer?
- brake pipe help please guys
- OPIE Oils Advertising in Forum
- strange windows
- brake master cylindre
- what benefit is had from fitting a big valve head?
- looking for a genuine front wing..
- Air Filter
- Winter prep??
- MK3/4 widearch kit
- Bogging out, lost loads of power, smoking????
- S2 Brake upgrade
- URGENT!!! part needed
- brake servo
- correct rear decal
- problems after rebuild
- ke jetonic boost sensor pipe
- stage 2 turbos and 5th injector
- revving itself!!
- Injector sizing/flow rates
- Zetec turbo boys. What turbo you using ?
- little help here please
- A few problems
- heater not working..
- rs turbo
- Intercooler choice
- oil pressure on zvh
- red E plate s2 spotted
- piper 285t cam lube.
- rs turbo series 1 exhaust
- S1 & S2 light rubbers
- Head mods?
- My new S2, and a few questions!
- EFi What year?
- Alloys
- Rs turbo set up
- s2 escort rs turbo rack replacement
- S2 metal fuel lines
- IB5 bearings in BC case..
- £2500
- winter resto in my s1
- escort rs turbo
- Track car build
- (Wanted) s1 body kit
- Arp con rod bolts
- fitting a new oil pump?
- Xr3i cabbie efi to frst engine?
- No spark (Sorted!)
- you opinions on a new turbo engine build?
- aquamist mf2?
- steering column wanted
- going for a spin
- white smoke
- Is this hoofed?
- turbo knowledge needed!
- rst mfi metering units
- AEM vs Innovate
- 90 spec S2
- scuttle panel
- f*cking tin worm :(
- Banjo bolts metering unit
- Zetec sumps and flywheel question
- Inlet manifolds as on main room
- screen pillar
- Throttle cable
- Another cold start problem
- CVH wossner piston rings help
