- What grade oil to use in gearbox?
- push down the engine power
- Rs turbo full bolt kit
- Differential bearing shims
- Finis codes WANTED
- boost help
- But of advice
- Efi, mfi
- S1 set up?
- Cooling system gurgle
- Low compression
- MPG
- Turbo water feed inlet metal pipe?, rst series 2
- Gaz modified rear top hats
- Turbo whining
- Oil leak on cvh efi
- carbon front wings
- Finally its on.
- cvh arp head bolts
- What causes bouncy needles?
- S2 full restoration
- can you?
- Really lost it regarding turbos
- 1.9 CVH help
- TURBO
- Rs turbo door handle
- Fuel mixture
- On the hunt, wondering if my old one is on here.
- oil pressure regulator in cvh head
- Does anybody have any info pics inside
- sandwhich plate of ebay keeps leaking
- rs turbo wont start
- Another Oil Thread - 10w60
- alcon 6 paddle clutch for bc box
- Gearbox Oil
- Mk4 interior door handles...
- what is the best cleaning product for rs7 diamond cuts?
- How can I get my s1 rev counter to work off my fiesta RS turbo efi engine??
- fiesta rs turbo zetec turbo questions/ clutchs/ manifolds?
- lifters?
- Water leak
- Help please
- Oil breather... Help
- suspension problem
- s 2 rs turbo
- Sunroof cassette...
- Won't start
- Engine oil 10w40 or 10w50?
- Will these fit
- Help needed! Zetec turbo sump?
- Escort rst efi conversion help (crank senser)
- Stage 3 hybrid turbo
- Will it work? ??
- Mk3 hydraulic clutch
- CVH followers
- Water coming out of turbo
- Bailey header tank width..
- F147CMS Anyone know
- Headlinings
- Rear glass tint percentage.
- Removing Erst fuel pump
- escort rs turbo Cylinder head has camshaft Bearings?
- zetec turbo on ofab
- comp brake adj track control arms
- Escort mk3 zetec turbo 400bph (what gearbox)
- head gasket escort rs turbo s2
- Anti Roll Bar
- Exhaust
- Ford racing water temp gauge
- possible motor sport shell ??
- not as fast, not boosting as smooth
- Cosworth turbo with rst housing
- Does anyone know this car f8370vw need to contact owner?
- Turbo refurb have you tried DIY ?
- flo flex poly bushes
- does anyone still sell smoked rear lights still
- afr limits for mfi
- gearbox mount help
- MFI set up advice needed!
- Yokohama tyres
- ht leads
- Erst oil capacity
- Wasted spark cos management?
- head gasket failure signs
- oil erst
- Need help!!! Brakes doing my head In lol!
- cosworth management conversion few probs (help)
- Newbie saying hello
- coolant system problem
- Rebuilding the steering rack
- Rich/Lean
- Drilled Numberplate Pic Request
- MFI RS Turbo Bottom End Wanted
- S2 washer bottle into mk3?
- Piper 285T camshaft sheet
- Buying Series 1 Need Help B23 GTY
- Starting problem
- misfire and white smoke ?
- S1 window help
- imperial blue escort rst reg e268ykx
- EDIS and Coilpack
- A little help if possible please.
- Engine Oil for around 210 bhp?
- Engine change
- Amal valve
- Escort RST S2 Standard Exhaust Help. Please!!!!
- RST Turbocharger
- Speedo stopped working
- C582 FWT location
- Rs turbo efi inlet manifold
- s1 rs turbo only runs with flap held down. ?
- series 1/2 rollcage ?
- Injectors
- Where an you get a seal
- Mtx clutch options?
- Indicators
- Loose turbo nuts
- Turbo gasket
- smell of burnt oil in car through blowers
- Which intercooler?
- RS16i rocker cover
- VDO sensor from Ebay
- Rose joints
- power engineering cam?
- erst running cossie management (top sensor)
- anyone diagnose?
- Inlet manifold wiring
- Anybody knows what is this?
- ib5 release bearing: RESULT!
- final straw
- best way to top up gear oil?
- ST170 gearbox conversion
- MTX conversion what linkage? more problems starter to?
- Series 1 and series 2 rs turbo gear linkage the same?
- Throttle position switch
- Heavy steering
- new handbrake cable who knowns it?
- Any body on here got this car ?
- Advice please...
- rs turbo alighnment measurements
- Evil mk4 escort
- rs turbo series 2 seat pans hooks?
- s2 rear glass, FREE to a good home
- xr3i to rs turbo??
- OFAC loom connector - have I got the wrong one? Pics inside
- Precision turbos
- spark plugs
- Series 2 turbo idleing issue
- Windows. Electric to manual...
- 88 spec boot decal from dmb graphics - good quality ?
- Brake question?
- Wheel stud conversion kit ?
- C909 wru s1
- would these fit
- Does anyone know where to get one of these?
- Rs turbo s2 turbo noise
- Steering Rack - Mk4
- please look at this.
- Loom Connector
- Zetec turbo alternator problems
- S2 rear compensators
- 2 questions Engine paint and coolant type
- Warning to all with oil pressure gauges and question
- help needed please,erst 2.1 zvh wont start
- Gear linkage rebuild, springs/blocks
- Setup in the northeast
- Which fuel pump??
- Help please! inner cv joint
- mk3 clock setting and mk4 trip computer
- Ofab injectors
- oil warning light!
- Adjustable Bias Brake assembly?
- S2 genuine exhaust.
- Cast alloy rocker covers
- What clutch do you use??
- Anyone know where you can get new RST bumper strips from.
- mfi, efi help ??
- Hazard lights and horn not working on Escort S1
- fitting gauges
- T04E Turbo?
- RST S2 couple of questions.
- New owner of escort rst looking for some advice
- Series 2 clear front indicators
- CVH equal length manifold
- Rs500 cooler?
- zetec turbo questions again and fiesta question
- Radiator
- Ofam ecu
- amal valve jet
- Boost problem blown turbo
- Help. Running lumpy and not boosting
- Spec one
- rev counter ??
- boot leak
- abs removeal
- S2 Accumulator pipe.
- s1 starts but dies after 3 seconds
- rear light lenses
- Aftermarket regulator on EFI Turbo fuel rail?
- H881akm
- need history
- has anyone owned this car in past
- Oil leak
- St170 wheels
- Chipping rs turbo
- omex 600 anybody on here using it
- best handling package opinions
- Sunroof doesn't open!!
- are s1 and s2 pistons different??? :O
- specific escort history search
- s2 watercooled turbo problem,help please
- newman solid lifter advise plz
- Mk4 rs2000
- someone give me a heads up on these?
- Escort S2 set up please read
- RS7 spokes
- noise at the clutch
- fez rst carbon fiber bonnet
- rs turbo MFI running issue
- Any ideas what stage turbo?
- Series 1 rs turbo seen it today in knaresbrough on comps
- Rs owners! Abs question! Help!?!
- non abs resovouir
- mk4 escort bonus rear quarter window seals
- Inlet manifold
- How easy is it to change 5th gear
- Lightened flywheels any good?
- boot struts on escort rs turbo
- Head Gasket and or do I have other porblems
- central locking motor
- Any one know ?
- Orion turbo
- s2 front brakes
- What fuel pump do i need?
- what to paint the floor of my rs turbo with
- Best clutch for 200-250 bhp??
- Best place to source crown and pinion
- Dta management map for 2.1 zetec turbo
- s1 ecu problems and tuners near cambridge
- parcel shelf?
- Rs turbo s2 actuator problem
- Rs turbo s2 31 actuator
- Mk6 clutch pedal
- few pics of my escort
- Oil pressure problem researched and finally seems fixed!
- WHEELS
- What's a T3 worth?
- no spark mfi rs turbo
- RS Turbo S2 Question
- polycarbonate windows what are they like to live with?
