- field motorsport
- Shiney Stuff
- Recon turbo
- Thermostat Housing Bolt Snapped
- help wth engine
- amal valve
- series 1 battery tray
- Header tank
- Chipped???
- Gearbox
- Loads of Escort RS/XR bits on ebay for y'all!
- both my cars r now on ebay
- Boost problem on series 1
- Which RS Turbo Do You Prefer
- How do you find out if a wheel is 15 or a 16 inch one
- lsd gearbox?
- Wont boost over 10 psi?
- buckerooing??
- ECU's
- Escort Cabriolet Turbo Conversion
- Alternator?
- car mats
- Best tyres for S1 wheels?
- TAS motorsport adjustable TCA's, views?
- Series 1 help needed.....
- Engine Refitting?????
- Lambo Orange S2 from the mags...
- Brakes
- Swappsies anyone
- s2 turbo exhausts?
- FAO ZVH owners
- SINGLE WIPER KIT!!!!!
- S2 Bodykit
- Repair panel?
- Throttle Position Sensor
- Some bits I picked up this weekend
- pic test
- In Car Bleed Valve
- running lean
- i/c, GRS or Pro alloy?????
- Fuel Metering Unit
- RS Turbo too hot?
- wot can cause pinkin?
- Any ideas?????
- FORD FAIR?
- Front suspension set up (S1)
- £2000 for tuning wot should i buy
- Nut on actuator?
- S2 Exhaust
- FUEL PUMP
- s1 wont start
- BOOOOOOOST? HOW MUCH
- Best shocks/suspension
- Cambelt Question............Help needed
- turbo
- what a find!!!!!!!!
- RADIATOR?
- TURBO ? ANY ADVICE
- WHAT POWER DO YOU NEED
- The heat is on.
- Ford series II fuel cap. where???
- WHAT DO I NEED TO DO A REAR DISC CONV?????
- 263.84 bhp !!!!! PICTURES ADDED !!
- air / fuel ratio meter....
- 120mph and hot temp
- Oil coming out of dumpvalve??
- WANTED: A LOW MILEAGE ESCORT OR FIESTA RST ENGINE
- Cossie rear discs for my S2
- 211bhp on Friday
- What is needed for a EFI conversion
- Standard Boost
- HOW MUCH?
- s2 engine oil which one?
- s2 rst any1 interested????
- zvh convasion
- WANT A 90 SPEC!!!!!!!
- sum pics of wifes car as
- rocker cover gasket ?
- MFI rev conter fix when converting to to efi
- ROLLING ROAD SESSION!!!!!! 195BHP
- Firing Order
- Rs Turbo S2 Running Problems
- Never made it to Kent RS meet !!!! Engine let go !!!!!!
- adjusting an ap 4 paddle clutch ?
- pls help me decide
- rough idle
- A Couple of Pods we've done for Series 1 RS Turbo
- boot spoiler
- MY RS
- GRS Intercoolers
- holding back and surging!!!
- Gearbox fittings??
- Water pump help???
- clear rear lights and acustic parcel shelf
- pics
- hydraulic - mechanical
- RS TURBO RADIATOR
- FUEL PUMP!!!
- bonnet raiser blocks
- Boost gauge
- series 1 brakes
- master cylinders
- bailey swirl pot ?
- fooked alternator ??
- Front cossie brakes on S2??
- Reverse charge pipe
- WHATS NEXT ?
- WHAT SOULD I DO?
- Help car keep cutting out!!!!!!!!!!!!!!!!!!!!!!!!!!!
- removing crossover pipe ?
- SUMP GASKET
- Car not running right and doesn't tick over
- Rev limit ?
- Brake servo question
- WHICH FUEL IS BEST? SAINSBURY IS AT 80.9 PER LITRE
- ROLLING ROAD BENIFITS!!!
- Low Milage S2 For Sale
- GRS i/c ????
- Main Bearings and Big End Bolts??
- anyone running a kent cvh 34
- wiring in gauges....
- WHAT CAN U RECOMEND?
- WHICH PUMP?
- S2 Rear disc conversoion
- Best suspension kit for Mk4?
- OIL PRESSURE GAUGE
- grey S2 at Stevenage Leisurepark Lst nite??
- fookin aRSe
- whats a good oil pressure for a s2 turbo
- Clunk Cluck Clatter Clatter
- pistons
- Lack of coolant pressure!?
- cosworth t3
- Full-face intercooler or Charge cooler
- what digits are stamped
- Stolen!
- MK 5 PEDAL
- pipes
- Anyone Selling PiperT285 Cam?
- Which Camshaft????
- who's got Koni Adjustables ???
- 3 gauge holder
- Water Cooling for Turbo
- quick question
- WHICH ONE? C/C OR GRS
- NEEDED URGENTLY
- LOOKING FOR?
- STEERING ? DOES ANY ONE HAVE THIS PROBLEM
- Letting the thumb/wife/girlfriend borrow the S2...
- help! I need an black S2 passenger door
- Can you still get standard ariels for the ERST?
- HOW DO I
- TURBO ?
- Scottish S2 owners
- Better braking on S2 Turbs
- Grey S2 TURBS
- heated front screens....
- ST170 Front Brake Convers 4 RST
- rsoc rs turbo display
- spot lights
- gasket sealant
- my new rst (ne prev owners about??)
- Does anyone know???
- swirl pots
- Mudflap's?
- S2 hot start probs
- Electronic boot release swtch
- check this
- SIG PLEASE.
- anyone running a newman cam?
- oh look what i found on ebay, for all you RST owners
- Whats this then???
- ECU'S
- ECU'S
- help
- rs turbo engine advise
- rst thermostat
- strange 'ticking' noises ?
- I want an Escort RS Turbo. Advice please!!!
- clutch prob :-(
- series II problem
- rs turbo fiesta and escort cyl heads
- twin 2wd vs grs 4
- want compomotive wheels
- My New brakes setup!
- s2 ecu box colours???
- Help! S2 rs turbo knocking..(pinkin)
- GRS intercooler cost? phone number?
- Good bit of sport
- 1.8cvh bottom pulley
- Series 1 pics
- pics of your front bumpers needed, (meshed up)
- Boost Gauge (information) please
- please i need help with a s2 rst, having big problems!
- s1 problem
- boost
- dumped my 17s for standard rims
- Running Rough!
- Carbon Bonnets
- s2 rst running problem /was pump,done for now!pics!
- fao a red s2 with chrome bumper strips
- Headlight Covers
- mk3 to mk4 rear head lamps
- relocating bleed valve hose to crossover pipe....
- temp prob??????????????
- any 1 got 18s on thr s2
- starter motor??
- 90Spec Front Bumper Wanted
- s2 engine help!!!!
- RS TURBO FOR SALE
- bleed valve
- Can some1 put some pics up 4 me!!
- HELP !! MY RST
- RED S2 on the A1198 to royston 2day 3:15???
- S2 CUTS OUT THEN BACKFIRES
- drop+wheels size
- Bodykit adhesive
- Turbo Conversion
- RAD OR INTERCOOLER
- hi im newm (pics?)
- seatbelt help
- Backfiring and cutting out...(Again!)
- starter motor
- does any1 know
- cossie 4 pot brakes in series one
- fan not working
- bloody car wont leave me
- Cossie or st170 brake conversion
- S2 Gauge Pod Surrounds
- My S1 in now on the road
- fuel pump??????
- Oil?
- fan override switch
- Anyone Sellin...?
- 205 tyres on Escort RS Turbo Rims
- idleing
- s1 custom project (bare shell)
- rst driveshaft oil seals
- having a turbo rebuild
- RS Turbo S2 Wiring
- wiring in a fan over-ride
- what gearbox??
- Cold Start
- TRACK (NATIONAL DAY) HELP !
- Got my 2.1 up and running
- help needed suspected headgasket gone
- boost pressure fluctauting
- 3dr front brake on a S2
