PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. Cylinder Head building!
  2. post your s1/s2 rs turbo!
  3. What bhp should I get
  4. f831 lev
  5. Escort s2 / Orion mk2
  6. which rocker gasket 2.0 zetec (silvertop) ?
  7. sense/advice
  8. Ford Badges..
  9. compbrake pedal box ?!
  10. front coil over pic
  11. Series 2 Oil Pressure Problem?
  12. vernier pulley and cam
  13. S2 Tuning help !
  14. mk 3/4 window rubbers
  15. water issue again
  16. Mtx again
  17. what tyres for 16" wheels on rs turbo
  18. i think wee need a real STICKY thread about MFI setup tuning
  19. Cam and follower issues
  20. anyone using a mk1 focus rs gearbox ?
  21. Airtech intercooler
  22. New intercooler
  23. Central locking issue.
  24. S2 fuel
  25. St220 engine in my mk4??
  26. best way to wire gauges
  27. Conrod bearings
  28. owners of s2 turbos
  29. Anyone know the servo pipe thread size?
  30. Need help with a fuel pump
  31. 1.8 zvh
  32. What grease for
  33. Just got a set of Mondeo calipers
  34. Cvh block cracking
  35. Interior Door Handles
  36. Yb into a mk4 estate??
  37. efi vacuum brake servo pipe
  38. MFi 3i manifold on turbo?
  39. escort mk4 rs turbo firing order
  40. Piston rings
  41. Gearbox Prob
  42. Powerflex 'Black'
  43. Has anyone got pics of
  44. Hot starting
  45. Does anybody rate this clutch?
  46. How to identify an escort rs turbo head
  47. Exhaust bracket.
  48. Zetec turbo conversion
  49. fuel pump problem
  50. My Cab so far.
  51. Rear light and dash light.
  52. hybrid turbo
  53. Whats the difference S1 & S2?
  54. group A ignition coil
  55. Converted to efi
  56. Rs turbo pistons
  57. Escort S2 water leak from turbo *video*
  58. ignition timing
  59. Mk4 rst van
  60. servo
  61. Abs removal
  62. 2.1 zetec turbo what cams for 400bhp ?
  63. My series 2
  64. Gotech no spark?
  65. s2 rs turbo fuel pump relay
  66. quaife quick rack fitting, help please
  67. RS Turbo problem in Tenerife
  68. mtx box
  69. eBay
  70. Avo help
  71. Trying to track down S1, reg C56 LAW
  72. Would anyone be interested in my tubular manifold and downpipe?
  73. Sound deadening
  74. rs turbo cradle
  75. Help. Misfiring
  76. tyres
  77. Anyone seen this break here before in the head?
  78. gearbox finally let go
  79. Aerocatches
  80. getting an urge for a escot rs turbo
  81. Boot decal
  82. Zetec Turbo Flywheel & CPS ?
  83. Gear linkage woes
  84. Cleaning Bosch EV1 injectors
  85. EFi base idle issue
  86. Who is best to build a Zetec Turbo for me?
  87. Series 1 rs turbo cuting out when starting from cold!
  88. to mutch BOOST???
  89. Pace intercooler
  90. What tires for escort cosworth wheels for good grip
  91. What max power to expect from the escort Rs turbo t3?
  92. Rev counter
  93. No boost :(
  94. rs turbo ratling noise
  95. escort rs turbo s2 wheel colour
  96. GAZ top adjustables9not coil overs)
  97. No fuel to injectors
  98. Big favour if anyone is near there Escort RS Turbo
  99. Injectors
  100. What are these driveshafts for..
  101. S2 loom
  102. oil cap
  103. cabby turbo
  104. Load vavles
  105. Zetec turbo !
  106. Performance Upgrade Escort
  107. Anyone riveted Series 2 arches on?
  108. No Spark Help!!!
  109. Central locking
  110. Central locking
  111. S2 tapping with misfire
  112. 1987 escort rs turbo cold start problem
  113. Which ib5 box?
  114. Rs turbo charging problem
  115. Rs turbo charging problem
  116. Amber indicators s2
  117. FAO karlos g..... Black top inlet
  118. Petrol tank s1 and s2
  119. Rear wing..
  120. Brembo brake kit
  121. front calipers rs turbo
  122. Rs turbo s1 starting fault
  123. Quick one, removing engine
  124. bubberling in thermostat housing
  125. EFI S2 won't start, no spark!!!
  126. Haynes manual to download
  127. clutch for 200hp ish
  128. Help with identifying brakes
  129. Want to make an rs turbo van
  130. Gearbox Output Shaft
  131. How much roughly for someone to fit a new battery tray
  132. my series 2 turbo
  133. ISCV issue Cossie Mangement s2
  134. jenvey inlet
  135. conveting MFI to EFI
  136. my rs
  137. Mk6 Zvh rs Turbo
  138. Water cooling pipes on turbo
  139. Yellow relay burnt out on my s2 rst
  140. Fuel swirl pot on s2 rs turbo
  141. lightened flywheel
  142. HELP Wilwood 4pot brake conversion on s2 rs turbo
  143. Fuel Pump
  144. Track control arms still available
  145. rs turbo bits wanted for cabriolet
  146. Which coilovers are best?
  147. Problem with AP CP2000-15 Clutch Kit ĦĦĦSOLVED!!!
  148. Zetec water pump impeller
  149. Can I fit an RS Turbo exhaust manifold to 1.8 xr3i?
  150. Rs turbo hard to start
  151. 1.6 cvh non turbo
  152. Temprature problems
  153. Swapping the fuel tank on my RS
  154. mk4 escort estate
  155. Rs turbo zvh conversion
  156. New Rear shocker mounts...
  157. s2 brake hoses
  158. Black top zetec inlet conversion
  159. Engine Still Tapping After Cam Change...
  160. Australian owned Series 2 idles but wont drive! HELP :'0(
  161. Paint Code?
  162. zetec turbo oil and plugs
  163. my new red s2
  164. what sort of price....
  165. Wipers and heater packed up
  166. Quaife diff??
  167. Rs1600 Motorsport rocker cover
  168. S2 supsension help.
  169. Cam Wear
  170. Lean everywhere
  171. where is the fuel filter efi?
  172. Mayo Sludge In Breather
  173. LSD gearbox
  174. Standard oil cooler for escort rst
  175. S2 with standard wheels
  176. cut out when driving?
  177. seat belt extender
  178. Escort cosworth wheels
  179. My engine number??
  180. manifold gasket
  181. Fuel Pressure Regulator
  182. motorsport devloppement evolution chip
  183. S2 zetec turbo????
  184. cosworth management s2
  185. escort rs turbo spark plug gap?
  186. problem on rebuild engine
  187. Anybody tell me what this is for?
  188. puma gear linkage
  189. Running help
  190. Quick question regarding vibratechnics mount
  191. S2 rst been sat for 18 months now won't start
  192. Coloured ht leads??
  193. s2 stud conversion
  194. Carbon fibre arch protectors for s1
  195. Mk3-Mk4 roof skins (different or not) ?
  196. need pics and advice
  197. Will S1 suspension fit S2 rst
  198. mtx speedo
  199. Battery light...alternator???
  200. Injectors
  201. Help and ifno as normal !
  202. Motorsport developments feedback
  203. Escort RST Out In The Sun
  204. dodgy fans
  205. boost drop at 4000 rpm
  206. turbo rebuilds ?
  207. aubergine RST!
  208. Head gasket?!?!
  209. will cos 4x4 front brake set up fit straight on escort
  210. T3/T4 turbo rebuild kits?
  211. Roll cage in my s2.
  212. zvh conversion
  213. Dash brake warning light not coming on
  214. Ht leads
  215. a bit of advice needed please
  216. Location ?
  217. Rs turbo breakers
  218. Whats the story with the mk2 FRS box?
  219. Airtec Turbo Cooler Problem
  220. any help?
  221. Stupid mistake with main cap
  222. Brake light fuse keeps blowing
  223. Reshell
  224. S1 rear window hinge
  225. fuel problem
  226. Bonnet lock/catch
  227. looking for my old s2
  228. Abs Removed & Problem with flaring new copper lines
  229. t3 turbo
  230. Abs light after removal.
  231. zetec wiring
  232. My RS
  233. Pictures of washer bottle
  234. bc box and puma shifter
  235. brake help
  236. Turbo elbow studs keep snapping
  237. Gears difficult once car is warmed up?
  238. 5th gear who jump out
  239. gearbox has shat itself
  240. Please help, S2 captive bolt repair on front bumper
  241. clutch release bearing
  242. tank sender
  243. S2 upgrades
  244. help needed
  245. fan switch connector?
  246. Power tailing off with too much boost!?
  247. Stereo falling through mk3 dash
  248. brake caliper nipple size?
  249. 88 spec turbo
  250. Heated Front Screen
